Results 1 to 12 of 12
Thread: Sunroof rubber accordion gator part number?
    Virginia
    1999 540i sport
    Hey,
    Does anyone know what the part number is for the bellows looking rubber cover seen when the sunroof is tilted up?
    Can't seem to find it on realoem.
    -Anson
    1999 BMW 540i Sport
    Sep 2015
    Chambersburg PA
    2018 F80 M3; 2017 M240i
    Don't know the part number, but in my Bentley manual for my e39 540i the diagram name is a gasket.
    I am having my sunroof not venting- the motor comes on, can hear it seem to lift, but the sunroof won't lift up to vent. It does open/close and there are no leaks when it rains. Any ideas on a DIY solution?
    San Jose, CA
    1997 BMW 540i 6 speed
    Alpina540i: It appears to be item 12: http://www.realoem.com/bmw/enUS/part...BMW-540i&mg=54
    Bullwinkle628: Search on sunroof repair. There are two plastic parts that break and prevent tilt. Also, browse "E39 Common Problems and DIY Fixes," at the top of the home page.
    Los Gatos CA
    1987 325is, e34, Z3, e39
    The two small plastic parts that are likely needed to fix the problem are available on eBay for under $10.
    It's possible that other parts are broken. But those are significantly more expensive and unlikely enough to be broken that it's not worth buying first.
    The DIYs are excellent.
    Virginia
    1999 540i sport
    Thanks I saw that in the diagram it just doesn't look like the part. I guess I will risk it and order one.
    For those removing the bellows, take the lower part of the bellows loose from the car then remove the glass bolts.
    The sun bakes the rubber into the glass on the upper part of the bellows and its near impossible to remove without tearing.
    1999 BMW 540i Sport
    Mar 2012
    Hayling Island
    Alpina B10
    Quote Originally Posted by Alpina540i View Post
    Thanks I saw that in the diagram it just doesn't look like the part. I guess I will risk it and order one. .
    Was edjack right? They don’t look right either to me but I just tore one of mine
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Just saw this thread w/ the bump today.
    #12 is not the bellows/'boot'. #12 is the plastic rim thing that goes on the glass.
    I'm not sure the bellows (or 'boot' as I think they call it...) is available actually.
    The trick to the boot removal is well documented in the many DIY's. You leave it attached to the car. You need a hook-pick that hooks into the folded metal support under the rubber that holds it into the glass part. If you get that hooked in right, then it comes right out, regardless of baking-in etc. If you don't, then you tear the boot. I would not advise whatsoever trying to pull the glass with the boots still hanging there.
    Quote Originally Posted by djb2 View Post
    FYI, 2 kinds of "3rd party manufactured" plastic sliders are on eBay... 3D printed and injection molded versions... I have ordered both and would strongly recommend the injection molded ones... the 3D printed ones are brittle as hell, probably a fraction of the strength of the factory ones...
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Los Gatos CA
    When I bought there were only injection molded parts.
    Most hobbyist 3D printed parts like this are garbage. If the original failed, making a crude replacement with much weaker plastic isn't going to work. Even with the same resin, high pressure injection molding will almost always produce a much stronger part. And the resins used with hobbyist printers are weaker to start with.
    Mar 2012
    Hayling Island
    Alpina B10
    Thanks for the replies, ironically I got them off intact first time around but got complacent second time when I tore one
    Will take a look on eBay and see what’s available or might try some from a breaker, guess a steel sunroof would be best as they won’t have been quite so exposed to the sun.
    Are all BMW sunroofs the same size from the E46/E39/E38 and possibly later models?
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Quote Originally Posted by BarryM View Post
    This is easy to find out...just pull up the diagram for the sunroof on one of the online part database sites like wwwrealoem.com, www.bmwfans.info, or www.etk.cc ...then just click on the 11 digit BMW part number and the sites will list all other BMW models that use the same part number.
    Mar 2012
    Hayling Island
    Alpina B10
    Good idea, it seems a few bits are common to the X5 but no listing for the rubber part I need on the X5 diagrams either. Guess I’ll be trying to get ‘good’ 15yo items.....
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Reviving an old, old thread from the dead to say... the sunroof gators/accordions/bellows for the E39 are available, but are not cheap. Found this out today while searching.
    Not obvious at all on RealOEM, they are number 14 on this diagram:
    https://www.realoem.com/bmw/enUS/sho...diagId=54_0195
    54128202281
    54128202282
    ECS currently shows $343. My preferred parts company shows $287.
    ouchie
    Nate J.
    Titanium Silver/Black Nappa Full 07-18-2001 E39 M5 Heritage (BZ99672). 201,000mi+. Engine rebuild thread.
    Alpineweiss III/Black Merino Full 03-26-2007 E60 M5 Manual (CX08265). 161,000mi+. Increasing daily.
  1. Sunroof Gator part number - help
    By adjmcloon in forum 1996 - 2003 (E39)
    Last Post: 11-04-2010, 11:59 AM
  2. Part number for differential mount (not rubber)?
    By snowphun in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-23-2007, 11:56 AM
  3. part numbers for sunroof pieces
    By Canon in forum 1991 - 1999 (E36)
    Last Post: 04-18-2006, 05:58 PM
  4. E36 Rear window rubber part number help
    By ACS S3 in forum 1991 - 1999 (E36)
    Last Post: 03-13-2006, 01:10 PM
  5. part numbers for sunroof cassettes
    By Eurofied in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-18-2004, 12:42 AM
