Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 122
Thread: Long 740
  1. #76
    Jan 2016
    Houston
    tbd
    Quote Originally Posted by purplecty View Post
    Oh man I love it! Hows the ride quality?
    quality has improved significantly, considering I was on 175K miles suspension that had been bad for some time. its not a bouncy, not as loud, handles better too. I'm very happy.
    Looking to buy
  2. #77
    CT
    E38
    I'm so happy to hear! It looks great. The clunk is gone? It sounds like it was in your shock mounting hardware.
    E38 M Sport 6 Speed MANUAL
  3. #78
    Jan 2016
    Houston
    tbd
    Quote Originally Posted by shanecarmaster1 View Post
    yea clunk is gone! that's all I can think of, maybe front upper strut mount(s). I am very happy
    Looking to buy
  4. #79
    Jan 2016
    Houston
    tbd
    had a great weekend in Glen Rose, Tx. Played a little golf, drove through the Fossil Rim Animal Park and got face to nose with a few Ostrich, deer, and a ram.
    Car drove like a champ, though I still need to inquire about this ticking from underneath (I hope its a guibo and not the previously mentioned CATs)
    I am also looking into the Zionsville radiator kit, I just about need to replace all of the hoses/tubing anyway (they have gone soft, and are probably deteriorating) and figure this will be a great piece of mind install. definitely don't want those fan blades flying, after all they have 175K miles on them! and it will cut back on that turbine noise every time I accelerate.
    https://www.zionsvilleautosport.com/...g-kit-1999-03/
    anyone have thoughts on this kit in particular?
    Looking to buy
  5. #80
    CT
    E38
    Quote Originally Posted by Lamer321 View Post
    I totally missed the post where you describe what kind of clicking it is, but if it's similar to when you put a card in the spokes of a bicycle, that's likely the diff. The guibo is just rubber, so I'm not sure how much that can lead to clicking per say. My diff spontaneously combusted at 60 mph after clicking for a few weeks. Luckily it didn't take out anything in the meantime.
  6. #81
    Jan 2016
    Houston
    tbd
    I'll try to get a sound clip this evening. if its the diff, and isnt a simple fix, then i'm probably going to try and get a M5 diff....it would be a little sooner than planned, but in the end still on the "Want to-do" list
    Looking to buy
  7. #82
    Jan 2015
    Tempe, AZ
    1995 540i/6
    My touring is getting that card in the spokes of a bicycle ticking at anything over 2k RPM. It never really stops, but at highway speeds the road noise seems to drown out the sound. Could that be my diff going bad?
    1995 540i 6-speed - Thread
  8. #83
    Jul 2015
    Dallas, Texas
    98 750iL, 01 740iL
    looks awesome, suspension is the next thing on my list. your iL has SLS? a little more tire in the back would perfect it. changed all the hoses on my 750 too, got a factory replacement radiator, though.
  9. #84
    IL
    2000 740i sport
    Mine was the rear CV joint. The grease dried out and killed the joint. New cv joint, repacked with grease, new csb and guibo as well went in while the driveshaft was out...
    Link to thread
    http://www.bimmerforums.com/forum/sh....php?t=2271501
  10. #85
    Jan 2016
    Houston
    tbd
    Quote Originally Posted by dannyzabolotny View Post
    so I have the ticking at idle, i havent checked to see if it speeds up as I accelerate, thats next on my list for this weekend.
    Quote Originally Posted by MKIVJZA80 View Post
    it it NOT a 750, the B&G springs drop every corner 1.5" so that's why it looks low in the rear. I like it, and I think when i put spacers on it will bring more of the tire out. My only other option is to get the H&R stage 2 springs but those have a MUCH harsher spring rate. I havent ruled them out, just didn't want to go too harsh too fast. Plus the H&R would drop the front another .5"
    Link to thread
    so the noise in your videos is not what I have. I have a small ticking at idle, in neutral (havent listened for it when I drive yet)
    Looking to buy
  11. #86
    Jan 2016
    Houston
    tbd
    Any tips on the radiator install? hoses to replace? anything else to replace while I'm in there? what about the cooling parts at the back of the engine???
    Looking to buy
  12. #87
    IL
    2000 740i sport
    For radiator just replace the hoses if they're old and check the date of the fan clutch... Be prepared to have new hose clamps when removing and of the old original ones fron the smaller hoses... Get ready to bleed bleed bleed air...
  13. #88
    Jan 2016
    Houston
    tbd
    going with a Zionsville radiator so fan clutch be gone!
    ....hose clamps.....great call.
    yea I squeezed the hoses the other day and they are all soft.
    I do need to research the bleed process a bit as I have no idea how to do that.
    Looking to buy
  14. #89
    Jan 2015
    Tempe, AZ
    1995 540i/6
    The bleed process isn't complicated, it's just time-consuming because you have to bleed the engine, let it cool down fully, add more coolant, bleed it some more, and repeat. You have to make sure it's done right because you'll overheat otherwise.
  15. #90
    West Palm Beach, FL
    06 Audi A8L Quattro
    Still curious how cars that rolled off the assembly line were filled with coolant once and ready to drive.
  16. #91
    Jan 2016
    Houston
    tbd
    G2 Caliper Paint - RED
    Finished the rears last night, curing/hardening today. will hopefully start and finish the fronts tomorrow afternoon. will update this post with the completed photos....
    Pictures are a little dark, the red pops a bit more than it looks...
    Looking to buy
  17. #92
    Jan 2015
    Tempe, AZ
    1995 540i/6
    Quote Originally Posted by dville View Post
    Probably using some proprietary tool that's super specialized and expensive. Every BMW job is easy when you have a $500 tool to do it!
  18. #93
    Jan 2016
    Houston
    tbd
    Upon painting my calipers red, I found that my caliper piston seals has become free to move about however they please...I will have to order some new ones, I really dont like taking brakes apart though, really makes me nervous when putting them back on.
    Also, my Zionsville radiator arrived! couple of teaser shots....really well packaged, extremely well welded from what I can see so far. waiting on FCP euro to ship my new hoses and ill start this install next weekend!
    Looking to buy
  19. #94
    Jan 2016
    Houston
    tbd
    new meats
    Michelin 255/45/18 in front and 285/40/18 in back. It might just be a placebo effect but man does it ride smooth. previous set of tires wer OLD OLD, the mech at discount tire asked why I hadn't changed them earlier....oh well, now its done.
    and here is the gap before and after. (I had stock tire size in the first picture)
    Looking to buy
  20. #95
    IL
    2000 740i sport
    Any rubbing in the front? Did you use spacers? I want to run 18x9.5 on the front the 255 45 18...
  21. #96
    Jan 2016
    Houston
    tbd
    no rubbing, no spacers. I can turn it full knock both ways this evening and take some pics. if i remember....
    Looking to buy
  22. #97
    IL
    2000 740i sport
    You have the 18x8 on the front though right? I want to put the 18x9.5 on the front so the width and offset may require spacers for what I want to do...
  23. #98
    Jan 2016
    Houston
    tbd
    correct. I'm also lowered 1.5". If I have time, ill put one rear in the front just to see what happens.
    Looking to buy
  24. #99
    Jan 2016
    Houston
    tbd
    New Plan!
    wasn't able to swap the wheels last night, should be able to today.
    NEW PLAN:
    buy 2 more jack stands,
    Jack up car on all four corners,
    remove Bilstein Tourings and B&G springs,
    put barely used shock mounts on fully functional stock S-EDC suspension. (probabaly going to sell the complete, functioning set once I've decided I like the new set up....)
    return touring shocks to FCP,
    use store credit to purchase BR Series Coilovers (contemplate swift springs),
    winning stance
    America
    Looking to buy
  25. #100
    IL
    2000 740i sport
    Damn why? The car looks perfect now with the new shocks and BG springs...
  1. Long drive in my 740
    By Avec in forum 1988 - 1994 (E32)
    Last Post: 08-10-2012, 09:37 AM
  2. Tappet noise from 740 after long layup
    By neoman in forum 1995 - 2001 (E38)
    Last Post: 11-25-2010, 08:04 PM
  3. wierd sound from engine after long drive
    By 94_325is in forum 1991 - 1999 (E36)
    Last Post: 03-06-2001, 10:25 AM
  4. Check this out - coolest thing in a long while!
    By Anfanger in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-06-2001, 02:15 AM
  5. HIOP race-tec positive displacement supercharger (long)
    By DMD///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-06-2001, 12:28 AM
