Avus Autosport
Results 1 to 6 of 6
Thread: Ball Joint Separator Tool
    Pasadena, CA
    00-540i,93-Z32,95-Miata
    In need of a ball joint tool for front control arms, the ones I currently have are too short. Anyone here in Socal have one for rent?
    Mar 2008
    West Covina, CA
    97 M3/4/5, 98 M3/2/5
    Quote Originally Posted by hyjaxe View Post
    Harbor freight one works well and then the trusty pickle fork and a mini sledge hammer.
    Pasadena, CA
    I do have this one from HF and is not tall enough. Only works well on tie rod/thrust arms. The BMW specific tool is substantially taller
    Dec 2007
    l.a. california
    1997 328is
    For the inner ball joint on the control arm I use a pickle fork, you can rent it from Autozone.
    Apr 2013
    Kensington, Maryland, USA
    528i E39;M52TUB28;5L40-E
    None of the rentals at any stores, including autozone, advanced auto, and harbor freight, will work. Ask me how I know. And, IMO, the sledgehammer ideas are bad due to the complexity of the E39's suspension system.
    I ordered an "Orion Motor Tech Ball Joint Separator, Universal Ball Joint Puller with Lower Control Arm Prying Tool Compatible with Ford Lincoln Mercury, 2-3/8 in. Lower Ball Joint Remo" from amazon as an alternative to dremeling down the stud. (Came so close, but I was wondering about the other side, and that the part is probably forged steel.) The cost was under $30 including the taxes and overnight shipping. For cases where you cannot wait, hit up your metal grinder/slicer/dremel.
    Any ideas as to why stores don't carry units that fit? Is this some dealer incentive thing?
    Nov 2008
    SF (East) Bay, CA
    3S-GE 2002
    The HF one works on everything I've used it on including the e36 which I maintained for well over 12 years. There's two holes for pivot points, are you using the correct one?
    Current: SeeDee 2002 Past: Veronica e36 Le-Ah e30
