Searched though 5 pages & could not find the answer to this:
I disconnected the battery to install my CD43.
When I reconnect it, the OEM alarm goes off.
I found a switch under the dash and thought it was the killswitch but it does nothing.
All I have for this car are two keys. I don't have a FOB or anything else. How can I get this damn alarm to turn off? Even if I let it run its cycle, the car still will not start.
You need the fob. If you don't have one, time to get a non-factory alarm so you can use it properly.
You can TRY this (it works with most aftermarket alarms, dunno about yours): put the key in the ignition, and turn it to full accessory and off 5 times fast, but on the 5th time, leave it on accessory. If the alarm stops, it's in sleep mode.
1997 328is M-Sport
Body: DEPO headlights, Prolumen HID (low beams and fogs)
Performance: Sparco strut bar, H&R Touring Cup Kit, GC RSM's, Powerflex bushings, M3 diff
Sound: Pioneer Premier, Focal, Connection Audison, Scosche, Alpine
Is there some fuse I can pull to disable the alarm but that won't prevent the car from starting? I looked in the fuse box under the hood but there is nothing that appears to be labeled "alarm" or anything similar.
Otherwise I will try the 5 key turn method in the morning when it won't wake the neighbors & see if that works.
BUMP
Anything else I can try to get my car to start??
Try disconnecting battery, turn ignition on then reconnecting battery.
There is actually a way to do it, its in the ews alarm handbook
I tried both of these suggestions but to no avail.
The original owner ended up getting back to me and it turns out the alarm I have is aftermarket (and of course, he no longer has a working key for it). So anyway, once I get home I'm going to remove the aftermarket alarm and this should hopefully solve my problems.
Because alarms are pointless and irrelevant.
