my style 5's have minor curb rash on them and i have no $$$ right now to send them somewhere...does anyone know how i can fix this myself... i don't know if i can file the rash down and then smooth them out?...i took the clear coat and everything off already....can anyone please help me asap??
thanks
2007 Tahoe- Daily
2004 M3- Weekend car
1995 M3- BMWCCA C-Mod
Depends how bad it is. If you are going to paint the lips, then you can use some type of body filler like Bondo or whatever. If you plain on polishing the lips, then your only option would be just sanding it as smooth as possible.
sand um down, then give it a nice polished, im guessing you did take it apart right? if not you should, and give the bolts a nice polish while your at it too.
i had curb rash on all 4 of my style 5s,
this was the finished product...
Damn that looks good. I bet it took a while didnt it?
Are the bolts that hold the 2 pieces of the rims together reusable? What kind of socket is needed? Also? if I just want to polish me lips(style 19) how do i get the clear off and do I need to take the tires off?
01 530i "to borrow from 1 is plagiarism, to borrow from many is research"
Yes the bolts are reusable...you need a 10mm 12 point socket to take the nuts off, and then i used a breass punch to take out all the bolts.
As for the lips. you definetly need to take the tire off...and to strip the clear off use aircraft stripper or paint stripper. you can get it at like walmart, or home depot
2007 Tahoe- Daily
Thanks for a quick reply. I saw on youtube someones BBS where leaking air from where the rivets are. http://www.youtube.com/watch?v=dPVKLqybC_s
Is this somethng to worry about?
