Results 1 to 10 of 10
Thread: E38 7-Series M Parallel Rims on an 8 Series?
    Sep 2010
    Phoenix
    840ci/540i/540i Touring
    Will the BMW M Parallel Style 37 Rims from a 2001 740i fit on my 8 series 1997 840ci? I was told they have the same hub size???
    Oct 2005
    Silver Spring, MD
    Too many
    They are the same hub size, and will fit.
    Sent from my SM-T817V using Tapatalk
    00 740iS
    84 635 (euro)
    88 M6
    84 745i
    88 325iX
    92 850i (6 spd)
    Sep 2010
    Phoenix
    Thank you! Do you know of any other series that will fit?
    Apr 2016
    Park City, UT
    1993 850Ci
    Just make sure to change the tires if the wheels come directly from an E38. They are slightly larger than E31 and will rub.
    Apr 2018
    Essex, UK
    '95 840Ci, '06 730d
    The e38 paras are the only ones which are a direct fit. You can bolt on e39s but you will need hub centric rings to avoid problems.
    Oct 2005
    Silver Spring, MD
    Too many
    Check this site. There are a couple of other styles that will work. If the wheels have tires on them you'll need to check tire size as the E31s generally take a wider tire with less sidewall.
    http://www.bmwstylewheels.com
    00 740iS
    84 635 (euro)
    88 M6
    84 745i
    88 325iX
    92 850i (6 spd)
    Jun 2015
    West Chester, PA
    BMWs:74 3.0 CS, 97 840Ci
    I've had the 7 series M Pars on my e31 for over a year. NO issues. To my ancient eyes, they are the best looking OE BMW rim for this model - look like the could/should have been OE.
    Gary
    Gary Knox
    '97 BMW 840 Ci
    '03 MB SL55 AMG
    '07 Mini Cooper S hatchback
    '09 Aston Martin DB9 Volante
    '13 Audi A8
    '90 MB 560 SEC and '94 Porsche 928 GTS recently departed but long enjoyed
    50 or so others over the past 70 years of driving
    Orange County, CA
    840Ci|725tds|Alpina B7
    Quote Originally Posted by idfotou View Post
    Correct. They are the only ones that are a direct fit.
    Sep 2010
    Phoenix
    Awesome. THANKS for all the info and links
    The Netherlands
    DE-spec E36 328i/M3 cab
    It's E39 wheels you have to be aware off. They have a 74.1mm hub instead of most others' 72.5mm
    IG:
  1. e38 M Parallel rims with good tires 60%+
    By hockeyfreak007 in forum Wheels and Tires
    Last Post: 09-22-2012, 08:35 AM
  2. E38 M parallel rims on E34 questions
    By Joban in forum 1988 - 1996 (E34)
    Last Post: 02-28-2010, 12:58 AM
  3. Can I put 275/35/18 tires on 18" M Parallel rims? 98 740i e38
    By adamsweis in forum BMW Rides & Events
    Last Post: 02-13-2010, 06:17 PM
  4. 2 e38 parallel rims (fronts) for sale (again) cheap
    By mumzergadol in forum Wheels and Tires
    Last Post: 09-05-2007, 01:32 PM
  5. Looking for an E38 M-Parallel rim
    By Mungrin in forum BMW Parts Wanted
    Last Post: 04-27-2007, 10:38 PM
