I posted recently about purchasing my first BMW, and was curious about the major service, but was informed that timing chain is not one of the items required for the 60k service.
When exactly does the timing chain need to be replaced? Does it ever??
Timing chain is far more robust than a rubber/fabric belt.
While I have seen timing chain failure reports (w/photos) on a high mileage M50 NV, these generally last the life of the car. Tensioners on early 325 and M3 are often times changed.
At after 150k miles it's not a bad idea to do the tensioner and guides.
At 200k miles my oil pump chain had stretched almost 1/2 inch.
1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
The timing chain is not listed as a service item. In theory, it should last the life of the car . I'm not suggesting the theory holds true all of the time, but there is no service schedule for it.
All depends on maintenance, I replaced the chain when I rebuilt my m50 at 188k but the old timing chain and new were exactly the same, same length, same amount of side play. If I had know I would have saved the money for something else. It isn't a service item unless the car has been very poorly taken care of.
'94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
'93 325is Coupe, Schwarz, work beater 299k
'89 325i Vert, Alpine White: 5spd swapped. Sold
'04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
'05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
'85 Toyota LandCruiser: Lifted, gas hog. 205k
I'm not sure I agree with this. While the timing chain is a life item, this only means that there is no scheduled maintenance for it. If you had the engine apart for some reason, it makes sense to replace the timing chain so that you don't get into a position that you have to take the engine apart again later. If you are taking an engine apart enough that you use the term, rebuilt, then putting a timing chain in is probably almost a requirement. I cannot see a reason to rebuild an engine and not replace the timing chain. I cannot see a reason to rebuild an engine if it still runs, but that's just me. My '94 M50 has 170,000-ish miles and I have no plans to rebuild it.
The M50 uses a timing chain tensioner that arguably needs to be replaced, but the issue here is that the chain rattles if the tensioner sticks or is worn out.
Easy win here. What's length spec of a good chain? If it's stretched then replace. If not who cares because it's not stretched after 20 years.
-Oakdizzle
These guys are spot on.
What's your mileage?
I'd consider it if you have REALLY high mileage AND are already in there doing a head gasket or something. I would never attack it just because.
I replaced the tensioner (and only the tensioner) when I did the head gasket at 145k. I'm at 219k now, and of all the things that keep me up at night, this isn't one of them.
Belts and chains are fundamentally different. Coming from a Toyota, you'd be expected to be worried about it. My wife's Camry never made it to 80k on any timing belt we ever had on it (both failed before we hit the 80k mark).
Timing chains are no more a service item than rod bearings for an E36. In fact, I'd do the rod bearings before replacing the chain, too.
If I WERE going to replace my chain, I'd replace all the associated gears as well to prevent potential issues (if your chain has stretched, you've likely also worn the gears down). This is not discussed much around here - not much need. However, on a Ford minivan my brother in law replaced the chain without doing the gears, which killed the engine in short order.
But if you're just inquiring about regular maintenance, a timing chain is anything but...
-Josh: 1998 S54 E36 M3/4/6 with most of the easy stuff and most of the hard stuff. At least twice. 276k miles. 1994 E32 740il with nothing but some MPars. Just cracked 100k miles.
98 328is
02 525ita
80 528i
81 528ia
and decades of owning and driving BMWs
Snap the throttle and listen for chain rattle... that is when you do your chain and guides. In all my years of working on these cars I have only seen 1 outright chain failure. Have had MANY with excessive chain noise/ worn guides.
Buy my native installed ISIS ISTA-D/ISTA-P bmw diagnostic laptop. More Info Here!
For me I've seen 100's of chain failures on other makes so I just did it while my engine was already out to be safe. Now these days MINI's are having massive timing chain issues and supposedly it's the same chain that BMW is using on the modern I6 engines, I don't get why BMW doesn't have the problem and Mini does....
Thank you for all your help guys, I did a short stint in a workshop with Renault, Citroen and Peugeot, and they all had timing chains listed as service items, we replaced them at 120k normally, but I don't know if that was just us, or just Renault, Citroen and Peugeot...
Maybe the French just do it differently?
Chains, we obviously did the belts but we changed chains as well
Wen I broke a tensioner the chain busted on my M52. However my engine is a unique case and wouldn't use it for a data point for any maintenance schedule.
That being said, if you are lazy and don't want to deal with the OEM continuous chain, I found out that a Mercedes master link with fit an e36 chain. (Mercedes also uses Iwis chain).
Don't be afraid of the copper side plate master link, they are plenty strong, when my chain busted the link the broke was a few links away from the master link with the copper side plate.
Granted if you are doing your chain the correct way you shouldn't need a master link.
Current fleet:
1999 BMW e36 M3
1999 BMW e36 328is with rotary valve engine head
1999 Oldsmobile Eighty Eight
1990 Jeep Comanche Eliminator
1962 Austin Healey Sprite
Just to be clear, there are two - one in the head on the secondary chain. And you are correct, only one on the primary chain on the RH side of the block. The 328/M3 M52/S52 one piece tensioner is an upgrade for the multi piece 325/M3 M50/S50 multi piece tensioner.
Good advice. In addition to new guides and tensioners.
That is the uniqueness of my engine. If you have seen my rotary valve engine head build thread you would note that I no longer have poppet valves. Basically the engine is not an interference engine anymore. At one point I had too much drag on the rotating valves which required too much chain tension. The old guide broke and when it did the chain caught on the rail and busted.
https://www.bimmerforums.com/forum/s...engine-project
Current fleet:
1999 BMW e36 M3
I'd like to resurrect this thread because it covered some questions I had concerning what to do when I'm doing the 94s 325 head gasket. 185k on the engine and it wasn't abused until I overheated it. Daily driver. Besides head gasket I know it needs the Vanos seals. Got the besian kit.
1. So probably don't need to worry about replacing chains.
2. Good idea to replace both chain tensioners? Last set I did was on an 89 SHO. Chains stretched. Gear teeth bend. Chain tensioner rubber guides develop deep tracks. Common at 100k miles.
3. The upgraded lower tensioned is just a redesign used on the M52 or S52 engine that is backwards compatible for the M50?
4. Is the chain guide a wear item or generally subject to failure?
thanks
Working on the 325 reminds me how much I LOVED my old Jeep Wrangler. A bus ate it.
281K S52 on original chains and guides.
Late model primary tensioner is backwards compatible.
So far, failed chains does not seem to be a problem. Broken guides and failed tensioners are occasional problems. Worn out vanos is a more common problem. Oil pump sprockets have come loose. But these E36 motors are getting up there, with the youngest being 20 years old and the oldest being 27 years old, with the mileage going up as well. How much of a project do you want to get into? The easiest time to remove the front cover and replace anything behind it is when the head is off. At that point you might as well pull the pan and check the oil pump.
