First or all, thanks a million to cwise12 for the excellent guide!
However, I'm confused about the splitter cables, and how i attach these to the new projector?
So I'm upgrading from stock xenon projectors to bi-xenon. I should be able to split the electrical current from the full beam (ie the blue male connector in the video) and feed the new projectors. But i haven't figured out where the other end goes. There seems to be no female plug anywhere. Do i need to buy another set of splitter cables, and what would the specs be?!
I recorded a short video to illustrate this. Thanks in advance for your ideas!
https://youtu.be/skl2m2TYySY
I guess i found the answer in this video at 4:55:
https://youtu.be/MALhlsdNtl0
So the solenoid comes with just raw wires. I need an extra pair of 9006 connectors and "rubber boots" which should go on the raw wires. It might be useful to add them to the list of material at the top of the guide. Or did i miss something?
Hello,
Thank you for your guide.
I used it to install new EvoX-R 2.0 from Retrofitlab with 9006 splitters.
For those who would like to do the same and install EvoX-R 2.0 instead of the EvoX-R (1.0 ?), I must warn you I had to do some mod!
The EvoX-R 2.0 are shorter than the first version...
When I mounted it in place of the OEM projector, I had this :
The lens was far from the hole...
I had to trim the support screws :
Work done on 3 screws with the last one unmod as reference :
And then after all screws trimmed and mounted :
You can see on the latest picture I added bigger nuts to keep a gap between the plate and the original nut to keep it on the thread.
I'll take pictures in some days when headlights will be on the car.
Thank you!
Aarrrggghhh, pics are missing! Does anybody still have them somewhere? I've got a set of EvoX-R 2.0 I'm eager to install this weekend, but I've no clue of the screw dimensions or anything like that! Will M4 screws be fine? I'm planning on buying new ones, trimming them so they fit, get some locking washers of sorts and be done with it, trimming the light pod tower bracket thingies seems a bit extreme, like so:
https://www.m5board.com/vbulletin/e3...evox-r-v2.html
Does anybody have any more clues on this?
Live slow, die whenever
So I took my lights apart and did a bit of digging around at a local hardware store in a hurry and made this makeshift solution out of some alu tube and some 4,0 wood screws:
They're about 19mm in length, added washers for more adjustability. It's a makeshift solution, I'm not too happy with it, it does the job right now, but I will be taking the lights apart again to do a better job. The more permanent solution is going to be to use the old stock screws, get the washer off and cut more thread into the mounting end and use nylon nuts or loctite to keep them from undoing then add washers. That way I should retain stock stability and more adjustment with getting the beams to match up. Will update this thread when I finally get to it.
is this, or similiar midification possible to pre facelift bmw e39 1998?
Probably not Shiremux the housing is different unless you have xenon lights from factory.
Mehman are they m4 threads for the bolts? I just got the projectors will probbly tackle the project next year. I don't want to shave down the towers either.
Just did this and thought I'd contribute: To eliminate the gap, remove the 4 posts, and use a dremmel cutting wheel to remove the washers. Then use a 4MM .70 pitch die to extend the threads on the 4 posts down to about 5mm from the end. Finally, purchase four more M4 lock nuts and spin those down (locking part first) so that the bottoms are 10mm from the end. Add rubber spacers and mount the projector.
hi guys ... can the EVOX-R V2.0 D2S Bi xenon be converted to United Kingdom beam standard ? if yes can you tell me how as im located in uk. thanx
It's been a long time since I've done this projector swap, but I don't recall them being interchangeable between LHD and RHD. I checked the website and it does specify left hand drive, so it may require full disassembly and or custom fabrication of your own shroud, I'm not sure if you can simply flip them.
Sent from my Pixel 4 using Tapatalk
Madeiraviolett Bf.C club member #001
1996 BMW 328is Madeiraviolett/Dove Grey: 5 Spd, Sport, Cold Weather & Premium Sound pkgs.
3.5" ECIS/ITG intake -> Samco ASC Delete Boot -> M50 Manifold -> S52 Cams | Bav Auto Red-top ignition coils tuned w/ AA software, Dynomax Cats & Stromung exhaust
UUC Pulleys & Clutch stop, FDM=Zionsville radiator w/ SAMCO hoses, Fidanza LTW flywheel & M3 clutch, UUC Evo3 SSK, 3.23 LSD
Koni/Eiback Adjustable Damper suspenion, PUR RSM's & RTAB's, CF Strut brace, UUC Swaybarbarians, Motorsport X-Brace, 17x8 Beyern Mesh wheels
Power Slots/Carbon Metallic Pads, Hella CELIS projectors + 5k TRS HID's, Fog delete=Brake cooling duct, LTW wing, ///M Bumper & R. Diffuser
CCA Member #382557 FS: E36 Sport Pkg Sway Bars & OEM OBD2 dual catback muffler (great for 323 folks)[/SIZE]
