BMW of Bloomfield
Results 1 to 17 of 17
Thread: 2000 M Coupe - Blk/Blk - 71Kmi - $19K OBO
    Jan 2003
    CA
    2000 M Coupe - Blk/Blk - 71Kmi - $17.5K OBO
    Reduced price.
    With regret, I am posting my 2000 BMW M Coupe for sale. I love this car, but it just doesn’t fit in my growing family so I’m hoping to pass it along to another enthusiast who will appreciate this car as much or even more than I do.
    Car Details:
    MY2000, BMW M Coupe
    VIN: available on request
    Exterior: Cosmos Black
    Interior: Black Nappa
    Mileage: 70,8xx – still drive occasionally
    Located in SF Bay Area. CA only car (originally from Bevery Hills)
    I am the 2nd owner, having owned the car since early 2003. It currently has ~71K miles. I have driven the car approximately 36K or a little over 4K/yr during my ownership. I have done most of the maintenance myself over the years and have receipts for just about everything. I also have detailed records in Excel showing when mods were installed, maintenance performed, etc….The car has been very reliable and hasn’t needed anything beyond normal maintenance. I have never tracked the car, but I have gone to the occasional BMWCCA autox, perhaps 3-4 times in total. The same was true of the PO. Needless to say, the car does have some modifications.
    The car has been recently serviced. This includes an oil change, brake fluid flush and complete F&R OEM brake rotor and Hawk HPS pad replacement. Beyond the maintenance already performed, the car requires a new set of tires (currently has Kumho MX 235F/255R) and new serpentine belts although neither are super urgent. Since I am no longer driving the car, I have elected to leave the tires for now so the new owner can choose their own replacements. The existing Kumho’s are probably good for another 3-5K.
    The paint is not perfect thanks to horrible CA roads. It’s decent, but you’re not going to win a concours with it. There are paint chips in the bumper, hood and fender wings. The front bumper has some hairline cracks as well. It has over 70K miles so it comes with the mileage and driving conditions. I have always used Klasse AIO and glaze with occasional clay bar so the paint without chips/scratches is in great shape. Since the car is black, some of these flaws are more noticeable than on other colors. The interior is in great shape given the age/mileage. Very minor signs of wear on the driver’s seat bolster, but that’s about it. Floormats are new.
    There is no stereo installed. The PO took this out to install an VDO oil pressure gauge and I’ve left it that way. I’m not an audiophile by any stretch. I no longer have the original BMW Business cassette stereo, but they aren’t very good anyway. I do have all of the remaining stereo components including the amp, subwoofer enclosure, speakers, etc….so it can be returned back to stock with an afternoon of work if you get a stereo. I would recommend installing the VDO oil pressure gauge in the analog clock position if you were to do so for a clean OEM look. The analog clock would be superfluous with a stereo that shows time. I prefer the existing location since it’s easier to keep an eye on though.
    Although the Carfax is clean, the car has been in a minor accident. I was rear-ended at a yield sign at ~5mph in 2004. This required replacement of the rear bumper and bumper supports, but there was no structural damage. Have all receipts and original estimate was <$750 so it was not reported to DMV and thus, does not show up on a Carfax report. All work done by B-Line in San Jose who is known for their great paintwork on BMWs. I paid out of pocket $500 additional beyond the estimate to get it repaired there to my satisfaction. Repair is fully documented of course.
    Additional pictures, Carfax and maintenance spreadsheet available upon request.
    Mod List: (This car is not stock, but it is so much better this way I would do it again in a heartbeat.)
    Engine:
    TMS (Conforti) chip
    Jim Conforti Air intake
    Dual Magnaflow "14815" exhaust (have stock mufflers)
    S54 M Coupe Oil Cooler - keeps temps <220F even in summer
    M50 Manifold Conversion w/ Eurosport adapter & injector cover
    ASC throttle body delete (have original, can swap back in)
    Drivetrain:
    UUC StageII Lightweigt Flywheel (LFW), 8.5lb, E34 M5 Clutch
    Stainless steel clutch line
    JTD Transmission Mount reinforcement rings
    Diff = Stock 3.23. (Korman Motorsports rebuilt 3.73 available for additional $500)
    Suspension:
    TCKline True Match S/A coil-over
    Vogtland Springs - 450lb (front)/600lb (rear)
    Koni Yellow Externally Adjustable Shocks (rebound only)
    BunaN RSM (Rear Shock Mounts) - much stronger than stock
    TCKline Camber/Caster Plates
    Adjustable front sway bar end-links (Ground Control)
    Sway bars (24mm front, 22mm rear)
    KMAC eccentric rear trailing arm bushings (adjust camber/toe)
    Ireland Engineering subframe bushings
    Subframe diff mount reinforced by BMW
    Small tow hook receiver (1 ½”) to accommodate small trailer or bike rack
    Interior/Misc:
    VDO oil pressure gauge (installed in stereo slot)
    Window tint all around
    1 & ½” Trailer Hitch (can tow small tire trailer/bikes)
    Stereo not installed (Have all components except headunit)
    Clear Corners & Silverstar bulbs
    Wheels/Tires/Brakes
    Stock 'Roadstar' Wheels - Refinished in 'Gunmetal' Powdercoat
    Brand new OEM Brake Rotors F&R
    Brand new HAWK HPS Brake Pads
    Kumho Ecsta MX tires (235 front/255 rear)
    Fluids:
    Engine: every 5K or 1yr, Mobil 1 5w30 full synth or Castrol Syntec 5W-30
    Brakes: ATE Super Blue/Gold
    Tranny: Redline Mix (based on UUC recommendation with LFW)
    Diff: Redline 75W-90
    Jan 2003
    CA
    Bump for the weekend.
    I had a couple people ask so please note the subframe is in good shape. No wrinkles, broken welds or any other issues. Pictures available upon request.
    Jan 2003
    CA
    bumparoni
    Jan 2003
    CA
    bump for price reduction to $17.5K OBO
    Nov 2003
    Mpls
    02 X5 4.6is
    Nice coupe with a great mod list! GLWS!
    93 318i red/tan - 131,xxx - bone stock daily driver
    02 x5 4.6is titanium silver/black alcantara - dinan stage 4 - eibach/bilstein - brembo 380/345mm bbk - 149k miles - sold
    95 m3 hellrot/black - dinan stage 1 - koni 1150 - arc8 - 155k miles - sold
    Dec 2004
    Hawaii
    525it, 318ti, MCoupe, X1
    This is a great deal for all the mod's and the work/time it takes to sort it all out.
    GLWS!
    "There is no excellent beauty that hath not some strangeness in the proportion." Sir Francis Bacon
    Nov 2010
    Montana - Big Sky Country
    M3, Miata, 240z
    Sent you a PM with offer..... waiting...
    Jan 2003
    CA
    still available
    Chicago, IL
    1965 Mustang Fastback
    seems like i cant pm
    jasonoh35@gmail.com
    Jan 2003
    CA
    Quote Originally Posted by jasonoh1 View Post
    jasonoh35@gmail.com
    email sent.
    Jan 2003
    CA
    still available.
    Jan 2003
    CA
    back to the top
    Jul 2011
    Los Angeles, CA
    still for sale?
    Catfish, is your car still for sale? I cannot PM.
    jasonjpae@gmail.com
    Apr 2002
    Florida
    Coupes...
    Caution! DO NOT TEST DRIVE THIS CAR!
    You would sell your first born to get this car.
    Like Opiates, it is physically addicting and you will suffer from withdrawal.
    All you will be able to think about is your next fix, your next power slide.
    Jan 2003
    CA
    pending sale
    Fort Collins, CO
    02 M Coupe, 07 A3 S-Line
    Man Jason, you can't catch a break.
    2002 Steel Gray over Imola Red M Coupe
    Jan 2003
    CA
    Sold.
