Just thought i'd throw up a post of my E36-LS1 from Australia.
Was a 325i 2dr. Been 9 months in the build. Designed all bits myself (mounts etc) as i couldn't find a 'kit' for RHD.
Will hopefully be ready to drive within the next week.
Only has mild mods, exhaust, MAFLESS tune, underdrive pulley, intake. I hope to do the cam/heads in the near future.
Looks good. Nice overflow reservoir.
Rob
Prior projects:
1998 540i with 6.6 LS2/T56 Chevy Power
- pictures and details
1992 325i with 6.6 LS2/T56 Chevy power - pictures and details
1995 M3 with 6.6 LS2/T56 Chevy power - pictures and details
Very cool.
I noticed that nobody puts that tubular cross member back. I know that it can't be put on in the same location due to trans, but there are extra set of tapped holes just couple of inches further back. Any reason not to put it back there?
Looks fantastic. Nice work
Thank you. I was going to powdercoat or annodise all the alloy black to go for a more OEM look, but the fab work seems too nice to cover up like that.
I think it will foul on my pipes, i do plan to make a custom X brace once it is up and running.
Thank you
Very Clean Install, more picture !
What transmission is that? a TKO or T5 WC?
Looks great!
2001 E53 X5 - 5.3 Procharged, 4L80E RWD, Brembo, 20" alloy, EBC race, Forge, A2W intercooled, Alcantara interior, 3.62 LSD and more!
2005 E53 X5 - 6.0TT, 4L80E RWD, 20" alloy, EBC race, Forge, A2W intercooled, Alcantara interior, 3.62 LSD and more!
1996 E36 335ti - N54b30, A2W intercooled, ZF 6speed rwd, 4.10Lsd, Speedline magnesium rims, Brembo, S55 exhaust, 245/40/17-295/30/18, idrive, Forge, logic 7
1999 E36 360ti - 6.0, ls6 springs, ls6 cam, hardened pushrods, trunion, racing baffle, t56, ls7 clutch, m3 brakes, 4.10lsd
Tremec T56
Twin 3", into single 3 1/2" system, all stainless.
Greabox crossmember-I wanted to keep the exhaust as high as possible to keep good ground clearance. This was later powder coated.
Extractors before being ceramic coated
More
Was tight fitting 4-1 1 7/8 pipes/steering column and starter all on the RHS side
Beautiful. What did you use for Driveshart?
nice i saw this build somewere else nice work
wow, great work. everything looks awesome. what cats are those? they are nice and compact. waiting for some action videos
By the way did you leave the original steering shaft or planning on using something more low profile?
Cats are 3" Magnaflows
Original steering shaft, i have 10-15mm clearance all the way around, so no need to go smaller.
Drove this up and down the driveway this afternoon
It sounds pretty tough just sitting in the car, nothing like the old BMW 6.
I still have a few more small jobs to do before i take it for a proper drive up the street (like wire up the ABS :w: ). Getting oh so close now.
what mufflers are those? anything thats available in the US?
Nice work, mate.
E30-LS1 Swap Guide and Kits, email us at e30ls1@gmail.com !!! or check our website e30ls1.wordpress.com
How did you do the headers?
Did you modify a set of off-the-shelf long tubes or build them from scratch?
Very inspiring work
- Peter Shen -
It's alive
Small problem-Pulling out of the driveway i realised it has no brakes :O. Well very little in the way of retardation anyway, so just a small run up and down the street :knock:.
I just gave it 3/4 throttle 1st-2nd-3rd. Has some serious grunt compared to before. :w:
Now off to look at what is wrong with the brakes so i can give it a proper run
Congrants!
Now We Need More Pix and Videos!
very nice work. Seems the brake boster has plenty of clearance on the RH drive. Was the ABS unit relocated or was it always where it is? I've never seen under the hood of a RH drive before.
Also extra + for doing the headers yourself.
