Page 1 of 15 1234567891011 ... LastLast
Results 1 to 25 of 374
Thread: Well, i did it. I built 3 piece custom roadstars.
    Jun 2006
    Provo, Utah
    GT40R Turbo M Coupe, 71 Datsun VG30 510 "AKASmurf"
    *****UPDATE AS OF 2/29/2016********
    PROJECT IS 100% COMPLEE
    I accomplished my original goals in their 100% finished forms with no other revisions planned.
    18" flat flat lip
    19" stepped lip
    The two versions use the same identical center forging, same center design, but the machining is unique between the 18" and 19" wheels. Utilizing the same center design, the brake clearance potential is as good for the 18" wheels, as it is for the 19" when it comes to 14" brake applications.
    For those interested in these wheels for your own car, custom widths, offsets are unlimited between 18x8 to 19x12. I have worked with the machinist and manufacturer (Schott wheels, Gardena CA) to get the pricing down as low as possible. For most finishes they are $1100 per wheel. Plus actual shipping costs to your location. The most expensive set I have spec'd for my self with titanium hardward, and a chrome powdercoat finish on all parts ran about an additional $400 per wheel. Wheel weight range I have measure my self, including valve stems runs about as low as 21 lbs for a 18x9, up to the heaviest 24.75 for a 19x11.5".
    The finishing options are many. If interested, please shoot me a text or call me at 801-310-8170. I can also be reached at jonesmechanical@gmail.com, but please shoot me a text when you send that email so I can look for it. You can also go to the iconfcorged website iconforged.com and contact us there, as email is forwarded to the same email.
    Here are some updated shots of wheels in both 18" and 19".
    19" brushed gold:
    18" powdercoat silver
    18" black chrome back side details:
    Follow on instagram @ iconforged. Most pictures are there with updates.
    Thanks for your support Bimmerforums/z3 forum. Its a great place. Anyone interested in this design for their own car, just let me know, I can make it happen.
    Greg Jones.
    We surpassed 1000 posts, which I suppose means the old thread ends. I think it was appropriate anyways given the state of the project. The 4 year journey has been well documented here: http://www.bimmerforums.com/forum/sh...iece-Roadstars.
    As of today, the first set is well on its way to completion with verification of the first two prototype centers.
    I am so pleased with the final design, and am happy to say every original goal has been met:
    1. Design that properly honors the original Roadstar Wheel
    2. Reverse Mount center (harder than I thought)
    3. Wheel center that clears Brembo 14" Front, and 13" rear brakes while offering maximum backspacing available.
    4. High Quality, Light Weight. Currently, the wheel center weighs between 9-9.5 lbs depending on hub pad thickness.
    5. Reasonable Cost. Depending on size, and Volume, between $4600-6900 a set plus special finishing and hardward options (polishing/painting/Powdercoating included).
    We have started an interest list, that will eventually be brought over here.
    Currently, we are at least a month away from taking official orders and deposits. None have been taken yet.
    During this whole process, everything changed when I met the very talented 3D scanning artist and modeler Kevin Schiedle, owner of Meshwerks. We became equal partners on this project, and will continue to work together under the name Icon Forged Wheels. We have also partnered with very a reputable wheel machinist. For now, we are managing all of the assembly and finishing of all of the parts, which involves several specialized sub contractors. Each of which are very reputable.
    Here is a pictoral of progress:
    Original design target, which was a rendering my 2000mKoop:
    Then the final physical product:
    19" stepped:
    18" Flat Lipped (utilizes the identical same center design, slightly different machining for a interference fit for the 18" hoops, which are a bit larger. Center will also look like a reverse mount center, but will actually be a sandwich. The original thought that we could literally swap shells between the centers, and convert them back and forth, but that didn't work out.
    Brake Fitment Pics. Looking for a very OEM tight, hugging design, which also allows for the largest lips possible with or without big brakes:
    All of the wheel pictures above are raw low resolution machined to verify fitment. Everything verified. Centercap fitment, hub centricity is very tight, caliper clearance is perfect, offset was as specified.
    I just shipped off the ABS plastic centers to a friend with a coupe with Alcon 355 brakes, and will be verifying clearance to those. If anyone would has a different brake setup, we would love to send out our abs plastic centers to verify fitment. A small deposit would be required, and full refund of it upon return.
    Its all very exciting. This wheel design by its nature is something very unusual for the wheel machine world.
    Thank you for all your support, and here is to the next 1000 posts!!
    Greg Jones.
    1999 M coupe, Black/Kyalami Orange, Sunroof Delete; GT4088R turbo, 610 WHP @ 22PSI Pump Gas; 2.79 Gearing; TCK D/A's; Forgelines 19x9 et38 w/265 30's; 19x11.5 et19 w/305 30's. Brembo GT Brakes; Race Logic Traction Control.
    1971 Datsun 510: High Compression VG34e, CAI,Fuji Blue, GC C/O's; system, Penultimate Rear Crossmember R160 lsd 3.70, cv axels; CCW LM16's 16 x 7.5/8.5 w/215 40 and 245 35 T1R's.
    Sep 2008
    Havertown, PA
    02 e367, 08 Acura TL-S
    #2. 998 to go
    Thanks for clarifying some questions. Looking forward to the availability.
    Oh, Congrats again! Great work!
    -Todd
    Bay Area, Killa Kali
    2002 M Coupe, 2019 F31
    -2023 Honda Odyssey Elite
    -2019 F31 Individual (M-Sport, Prem, Exec, Track)
    -2004 Honda CRV
    -2002 S54 M Coupé
    Oct 2007
    VA
    00 Mshoe
    I'll say it before I'll say it again
    I'm going to have a tough decision when these are available if I wanna keep my horribly brand new ACSII's (that are still being finished, I haven't even seen them together yet!) and a set of these...
    Amazing work, Amazing finished product, and I dare say the 18" Flat lip blew me out of the water... who needs a stepped 18 when the flat look that damn good.
    Bravo.
    Last edited by robb1887; 03-26-2015 at 10:37 PM. Reason: clap gifs... cuz clap gifs
    - 1of1 rebuild (build thread) - - Wanted Car items -
    My Website for DIY content and parts: Double Bee Garage
    Sep 2004
    SoCal
    Chariot
    Big kudos to all involved parties... well done fellas!!
    I'm extremely excited to see these mounted.
    Kansas City, Missouri
    89 750iL | 06 M5
    Wow awesome job and congrats, this was a long time in the making
    Can't wait to see them finished and mounted on the car with some rubber
    Apr 2009
    Istanbul, Turkey
    Z3 M Coupe
    Quote Originally Posted by jonesmechanical View Post
    Hi Greg,
    Did you send the plastic center to me? (I do have the Alcon Mono6 355mm setup and asked for the center)
    I didn't send you a deposit or gave any shipping address So if possible PM me the details for the plastic center
    Best,
    Cemal
    @Tripfcr
    1998 M Coupe
    : (Euro S50B32), Estoril/Estoril/black, B&M SSK, 6Spd S6S-420G, Strong Strut, R.Forbes sub-frame kit & RE dual ear diff cover, Pro Ramp Variable Lock %75 LSD, Supersprint Race Headers & Resonators & DTM Cat-backs, Bilstein B6 Sport, BBS RC 301 & 303 8.5/10x18" wheels, Alcon Mono6 355x32mm Front & Mono4 332x32mm Rear Full Floating BBK
    Jun 2006
    Provo, Utah
    Quote Originally Posted by cemalakcal View Post
    Hi Greg,
    Best,
    Cemal
    No, sorry, your next in line.
    Columbia, Worst Carolina
    2000 M-Coupe, 1994 SE-R
    Time to get retroactively added to the BMW parts list?
    Apr 2009
    Istanbul, Turkey
    Z3 M Coupe
    Okey let me know when the plastic center is ready for clearence test
    @Tripfcr
    1998 M Coupe
    Apr 2012
    Houston, TX
    2002 M Coupe
    I'm looking forward to seeing the chrome shadow finish on these. Will the same 3-step painting process that BMW used be used here as well, or will it be a powdercoat?
    Im torn between polished aluminum with a clear coat or chrome shadow.
    Sent from my iPhone using BF.com
    ___________________________________
    Always looking for my next
    ///M Coupé...
    Jun 2006
    Provo, Utah
    Quote Originally Posted by sitdownrando View Post
    It won't be an identical process. It will be as close as we can get it without asking the finisher to do something that is an experiment. It will be a powder coat.
    FWIW the original shadow chrome was black powdercoat base, with a special translucent silver paint over top. I think you could get 90% of the look without any guesswork by having a gloss black powdercoat base and a silver paint mixed with clearcoat on top, then clearcoat over that. Not sure if that would be too much $$$ though, but I'd love the shadow chrome centers and that's what I'd go for if available.
    Buy them raw and have them done how ever you'd like?
    Side note, I'm upset because this wheel reveal is going to overshadow my own.
    Oct 2007
    VA
    00 Mshoe
    Quote Originally Posted by BenFenner View Post
    Yea, I'm hoping mine get here soon too so I can at least have a week or two of thunder! Haha
    The District
    S54 e36/8, X3 M40i
    Quote Originally Posted by BimmerBreaker View Post
    There is a shop in NC that all the e39 M5 guys use that has replicated chrome shadow finish. These centers could be sent there for that look.
    That's of course an option but I just think it'd be cheaper having them done before being sent out. ie. instead of having a finish applied to the wheels, then stripped, then new one applied - just do the chrome shadow right off the bat. I haven't seen it mentioned being available though, so I'll probably go with one of the finishes that will be offered. Then maybe down the road get something else done to em.
    Quote Originally Posted by fmcfad01 View Post
    Yup, Prince Wheel, but there is also a shop in Phoenix near me that does the finish just as well. I have some wheels at the shop local to me right now and am considering taking a few sets of Roadstars I have there to get refinished. The shop near me mostly focuses on powder coating airplane equipment
    Apr 2012
    Houston, TX
    2002 M Coupe
    If I were still in CA I'd send them to Rite Way Wheels in Walnut Creek. They replicate the process and it looks 100% identical to OEM. That said, it's $200/wheel...so...I'll probably take whatever finish is available for these at the group buy price!
    ///M Coupé...
    San Francisco, CA, US
    GTI/M Coupe/Targa4/912
    Got mine refinished using Chrome Shadow. Love them, very happy and prefer this. The paint BMW uses always gets damaged over time from brake dust and other contaminants. I wanted to see how the P/C holds up by comparison. Oh, and I'm foaming at the mouth to see these wheels mounted with tires on a M Coupe, preferably mine
    Lansdale, PA
    00 M '96 Z3
    Sold a few body parts. Got some wheels to sell. Almost there for my set
    2011 Z4
    2010 MB GLK 350
    2000 M Roady
    1998 Lincoln Mark VIII LSC
    1996 Z3
    Jun 2006
    Provo, Utah
    Quote Originally Posted by Ronan1 View Post
    Anything we do will be covered by a 5 year finish warranty. Are you saying the chrome shadow BMW finish had issues. Yes, I can't wait for these to roll down the road.
    Jun 2006
    Provo, Utah
    Quote Originally Posted by Tazmanian Devil View Post
    Kidneys? BMW or human? Remember, bmw's need 2, humans only need one.
    Regardless of what the actual demand is on these wheels, its so much fun to want. In this case, it's going to be better to have. Just like z3m ownership. The tease has lasted long enough. Time to wrap it up.
    Hopefully someone posts some good pics with Alcon brakes clearing the superstar centers. I'm waiting on that now. They were delivered today....
    Jun 2006
    Provo, Utah
    I'm a click away from getting some r888's in 305 30 19 and 265 30 19's and 315 30 18 and 255 255 35 18. I just can't help myself.
    Bozeman, Mt
    e36/8, W201
    R888's are good sticky tires. I can't wait to see them on your wheels. I honestly like the Nitto NT01's a bit better but they come in such odd sizes that it makes it hard to find a decent stagger front to rear.
    Oct 2007
    VA
    00 Mshoe
    I've been checking TireRack daily hoping that Yoko's go on sale
