Page 1 of 15 1234567891011 ... LastLast
Results 1 to 25 of 354
Thread: We need more build threads: 00 Z3MC SG/DBO
    Oct 2007
    Chesapeake, VA
    00 Mshoe
    Bought my dream car finally June 2013. It was a little rough, but I fell in love with it immediately.
    Current Photo(s)
    Backstory:
    Specs:
    2000 Z3 Mcoupe (E36/8)
    Steel Gray exterior (400) Custom order
    Dark Beige Oregon (R3SN)
    1 of 1
    944xx Miles at purchase
    100% stock, save for a set of Billy sport front struts
    Orignal owner was a Docter from DC (per business cards found under seats) and it was apparent he didnt "care" for the car like he should have being that he ordered it SPECIFICALLY for him orignally. Guy (technically 2nd owner) I ended up buying it off a dealer lot and put only 300 miles on it before, what I understand to be, not having the desire to put the work into bringing it back to its proper state.
    Issues:
    Transmission wasnt very smooth, clutch point was at the floor, throw out bearing was shot, minor rust, curbed rims, dent in hood, scrapes on pass rear fender, tear in driver bottom bolster, misc broken/missing interior bits, dinged/misaligned bumper, missing undertray, the list goes on, but I'll get to some pictures:
    For sale listing photo:
    Additional sale as-purchased photos here
    Car has obviously been neglected for a while, and I thought I would document its rebirth. I'm horrible at taking pictures 90% of the time, but will try to get them through this process. I have wanted one of these awesome cars for years now and it just so happen I find a 1of1 so close to me I couldnt pass it up.
    Ardy (guy I bought it from) replaced:
    Valve Cover Gasket set
    Power Steering hoses refreshed and flushed with new fluid
    metal impeller water pump
    Aluminum Thermostat housing and thermostat
    Coolant flush
    Things I have done so far:
    Engine:
    SAP block off plates (SAP delete)
    ECIS CAI
    Carbon heat reducing wrapped ECU box
    RE underdrive WP & PS pulleys
    E36 power steering cooler w/ SS braided low pressure line
    Zionsville radiator
    S50 Euro expansion tank custom retrofit
    Relocated Diagnostic (D110) connector
    Relocated 12V+ Tower
    Relocated Ignition plug
    Relocated Passenger side relays to inside ECU box
    Rallyroad oil adapter block for oil press sender
    Throttle body coolant line delete
    ECU "tune" (SAP delete, 7040 redline, no speed limiter)
    Water temp sender in old throttle body supply port in head
    Magnetic Oil drain plug
    S54 Oil Filter Housing
    VAC OEM to -10AN fitting adapter kit
    Custom Zionsville Autosports oil cooler
    -10AN SS braided oil cooler lines
    Stewart Water Pump
    Wired oil pump nut
    Exhaust:
    Super Spring cat-backs
    Drivetrain:
    Mason clutch pedal
    Oilite clutch pedal bushing
    Rogue Engineering Trans mounts
    Shifter bushings refeshed
    Delrin shifter carrier bushing
    Sach's Clutch/PP/throw out bearing kit
    Brass clutch fork pivot pin
    Shift pin service
    Amsoil Trans Fluid change
    Rogue SS clutch line replacement (DCV delete)
    OE Slave cylinder
    Suspension:
    GC Coilovers (440f/600r) break down progress 1 2 3 4 prealignment
    GC Hybrid camber/caster plates
    Meyle HD FLCAs
    Powerflex offset FLCABs
    Lemforder inner/outer tie rods w/ fresh boots & locking plates
    OEM front strut reinforcement plates (modified for GC camber plates)
    Bimmerworld weld-in essentric rear toe/camber adjusters
    AKG poly subframe bushings
    Turner Motorsports "Street" rubber RTABs
    Mason Engineering Racebrace
    Brakes:
    Zimmermann 2-pc OE "euro" floating front rotors
    Zimmermann vented OE rear rotors
    Axxis pads
    Ireland Engineering SS brake lines
    Motul 600 fluid
    Overhauled rear calipers (OE softparts, painted)
    Bimmerworld SS caliper pistons (rear)
    Delrin brake pedal bushing
    Interior:
    50% ceramic tint on sunroof
    Seat tilt mod
    Seat bushing replacement
    12V Sky ///M plug
    Viper 3202 2-way Alarm w/ OEM siren & OEM Alarm harness spliced for plug-n-play 2
    (Remote functions: Keyless entry, window roll up/down, hatch pop)
    ZHP shift knob
    Passenger side "parcel net" replaced
    LeatherZ armrest
    Refreshed center console
    LeatherZ sunroof sunshade
    LeatherZ footwell lighting
    VDO water temp/oil temp/oil pressure gauges
    Euro driver lower dash panel
    Euro glovebox
    Exterior:
    Aluminum Motion Motorsports Undertray
    OEM gloss black painted hatch spoiler
    Blacked out kidney/hood grilles
    Color matched Garagewelt wiper delete
    Skeene design front license plate bracket
    OEM shorty antenna
    Wheels & Tires:
    APEX 90mm wheel studs
    Motorsports Hardware lug nuts /w locks
    Yokohama ADVAN Neova AD08R's 255/35F 295/30R
    AC Schnitzer 18" Type II 3-pc 9.5 ET34 (measured, incl. 5mm spacers) 11.5 ET9 (measured) (post1post2teaser)
    Lighting:
    Smoke bumper marker lights
    Stealth bulbs all around
    LED 3rd brake conversion v2.0
    3rd brake light accelerometer flasher module
    LED license plate bulbs
    FX-R 3.0 2.5" projector retrofit v2.0 (v1.0)
    Skyy FX-R 3.0 brackets
    In Progress:
    Misc parts aquired/waiting install:
    Misc center console switches (spares)
    ACS flippers (2000mkoop reps)
    Custom ND splitter
    Black dash
    Black door cards
    OEM plastic hatch spoiler with holes (for a project )
    Spacers: 3, 7, 15
    Rear brake wear sensors F&R
    Visors for airbag label removal
    Focal/Alpine/Pioneer Stereo from the parts roady, just need to figure out the Sub situation.
    DSSR 390
    3" MAF
    6-speed SMG project trans
    Maintence:
    Misc OEM seals/replaceables when removing the trans (946xx)
    Oil changed Mobil1 15W50 (95000)
    Bank2 Sensor1 O2 replaced (946xx)
    Rebuilt Alternator (948xx)
    Driver door handle cover replaced (949xx)
    Derusted and sprayed small spots on side skirts till replacement ones can be painted and replaced (946xx)
    Bumper adjustments Front and rear
    Removed 13 years of dirt from inner fender pockets (946xx)
    Front tow plug replaced (946xx)
    Passenger brake duct sourced and fitted (949xx)
    Driver brake duct fitted (949xx)
    New spring clips installed for front grill (947xx)
    AC button rebuilt/replaced (946xx)
    Auto-dim mirror fixed (before leaking) (947xx)
    Second key (946xx)
    Replaced broken dash defroster vents (950xx)
    SCRUBBED carpets (946xx)
    Oil filter housing to block gasket (948xx)
    Black radio/shifter surround (95xxx)
    Replaced broken dead pedal (95xxx)
    FAG rear wheel bearings (95xxx)
    Glove box sag fix (preventative) (95xxx)
    Center console bulbs (guages & heater controls) (95xxx)
    Brake light switch (97617)
    ECU fan (97617)
    Fresh coolant (97617)
    Injector Orings & Pintel caps (97617)
    Manifold to head gaskets (97617)
    Vanos Banjo crush washers (97617)
    OEM fuel filter (97617)
    Driver door window spot weld repair (97617)
    Door window weather stripping (97617)
    Brake wear sensors (97617)
    Driver & Pass. window sliders (97617)
    Driver window glass replaced used OEM (97617)
    OEM BMW Coolant fill (4/23/14) (97617)
    Oil changed Mobil1 0W40 (976xx) (4/29/15)
    Oil pan gasket (100030)
    Good condition x-brace (100030)
    Literature aquired:
    Bently's Manual
    2000 Owner's Manual
    Things coming in the mail:
    Things planned for near future:
    Custom 3" single midpipe
    Install knock off headers
    Tint
    Long to-do List: (in loose order)
    Rear end reinforcement
    Front brakes rebuild
    Stereo overhaul
    Interior work
    Turbo build
    Wire tuck
    Paint
    Jul 2011
    New York
    E368 / E30 M3 / 997 GT2
    This is gonna be good. Sub'd
    Bloomington, IL
    E90 M3 / Z4M Coupe
    Looks like the start of something awesome!
    Where at in Norfolk are you? I live in Newport News. I love to come check it out sometime.
    Jul 2004
    SA TX
    E46 M3
    i must take credit for talking Rob int this... sold his pretty slick tastefully modded E36 328i what, a year ago, and almost got lost in 4runner modding culture... i kept harping on him, when are you getting a bimmer, when are you buying that M3...All i heard was, i only want a shoe, nothing else will do, so until you buy it for me, fuk you too... rhymed just like that... then he'd spot them and some were meh, others were already done up and stupid expensive, then he up this one, i was like quit BSin and get it, you kno you wont regret it... i guess that was the nudge he needed... next thing i know, like 2 weeks later he buys it and few weeks later we're changed the clutch and all kinds of stuff..
    so excited for him, and to see what he does with this beast. Theyre such sick cars, i could never own one, id get locked up instantly. street legal gokart is how i describe it... woot woot...
    i are very excite.!
    M driver, RSV4 Rider, Powerstroke roller
    Boston 'burbs
    '01 Z3.0 R; '13 MB Coupe
    Looking forward to the resurrection. That car was rough- hope you got a killer deal.
    Mods: Remus 76mm exhaust, CDV delete, ASA AR1 18in staggered wheels, Turner 12 mm spacers, custom red tails, Kenwood deck/Sirius/BT/USB, ZHP knob, Redline boot, LeatherZ armrest, Amsoil all around, red needles, Akebono Euro brake pads, 34k original miles!
    Batavia, IL
    00 M Coupe, 08 335xi
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E39/2 E46
    I bet a ride around some entrance and exit ramps will get that CAI et al off your list....
    and put FI near the top.
    /.randy
    Oct 2007
    Chesapeake, VA
    00 Mshoe
    Quote Originally Posted by dfjaws View Post
    Thanks. I'll PM ya
    Quote Originally Posted by f50nut View Post
    let's hope
    Quote Originally Posted by snikwad View Post
    blah blah blah
    i are very excite.!
    Me too.
    Quote Originally Posted by BlackjackM View Post
    Stay tunes. I think so.
    Quote Originally Posted by SunzOut View Post
    No need for the 15w50....10w40 maybe but normal is 5w30
    Love the color...
    I used to run 20w50 in my 328. I can't fathom putting in 5w30. Ugh.
    Quote Originally Posted by rf900rkw View Post
    Yea yea, just need to get that powerball ticket and it will.
    Aug 2008
    Sunny SoCal
    VcLaren
    Love it! Looks like the awesome beginning to a great project. Steel Gray<3
    Subscribed. Nice to see one of these being brought back to life.
    For a DD I prefer SG/beige over SG/imola, so I think you made a good choice. SG is the only color I like a beige interior in
    Jul 2013
    Houston TX
    Escalade, M Coupe, CLS55
    Sweeeeett color! Congrats on the ride, glad to see some love going into it.
    SW Florida
    99-01 M Coupe & Rdstrs
    Whatchutalkinbout!?!? I'm building stuff all the time
    Why I actually *just* finished building something for myself
    Next up on the roster is a 2000 ///M Coupe that's going to be fitted with my former Dinan/Vortech supercharger system (after getting a head gasket, rings and coated bearings)
    MD/DC/NoVA area
    00 MCoupe / Audi B8 A4
    Robb, is there even any brake fluid in that reservoir?
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    Quote Originally Posted by BMWBergy View Post
    Looks like it's about up to the line to me. Maybe you need to adjust your screen!
    Oct 2007
    Chesapeake, VA
    00 Mshoe
    Quote Originally Posted by Msilvia View Post
    Steel Gray is amazing. Thanks
    Quote Originally Posted by BimmerBreaker View Post
    I usually dislike beige as well, but I think it goes well with the SG. My DD is also a beige interior.... I dunno how this has happened to me. It's not my first pick for interior colors, but I dont think I'd want Imola either. I dont DD it so something more "exciting" wouldn't be a bad thing.
    Quote Originally Posted by ILowNslowI View Post
    Quote Originally Posted by Randy Forbes View Post
    building sure. posting? I haven't seen anything lately.
    Feel free to shoot that Dinan over to me to keep it warm for you while you do that other work. No rush on completing it, take your time, just ship the SC kit to me ASAP to make sure the bearings stay rotating
    Second to last picture, line is visible, about 1/8 from the "max" line
    Quote Originally Posted by BladeRunner919 View Post
    ^this guy
    Thanks for all the compliments guys (and lurker girls??). The underpanel showed up last night. Still waiting on the filters, its the first time Amazon Prime failed to deliever within 2-days, weird. Also figure I need to go grab a filter to block gasket to swap in too while I'm at it.
    Z3speed4me's Avatar
    Z3speed4me is offline Coupe Cartel Forever! BMW CCA Member
    Apr 2002
    Clark, NJ
    01 coupe, 15 GTI ABahn
    It's a S54 SC kit..... I'll hold onto it for him instead. Although my bearings and a valve adjustment are on the list first as well.
    Can't wait to see you bring this thing back to life even more, I am kinda in the same boat bringing my 01 back to her glory.
    ~Ken~ {'99 M coupe : 1 of 35} - 1 of 1 Custom Build by Maximum PSI 623 whp 516 wtq @ 21psi 93pump;RIP 3.24.13 (<OO\ (II] [II) /OO>)
    {'01 M coupe : 1 of 16} - Nick G Tune, CPI Headers, MaximumPSI sec1, Supersprint X-Pipe, Vibrant Resonators and Vibrant Black Mufflers, TCK S/A 450/500, RF dual ear, 3.64, 8200RPM ~294 whp 237 wtq
    Oct 2007
    Chesapeake, VA
    00 Mshoe
    He's putting it into a 2000, so we can test fit and run it on mine first
    Z3speed4me's Avatar
    Apr 2002
    Clark, NJ
    That's boring then.... Randy the 01 needs some boost!!!
    SW Florida
    Quote Originally Posted by Z3speed4me View Post
    Indeed it does! Except for the antique '57 Healey, it's the only car not force induced; even my wife's X5 is a turbo (N55).
    Z3speed4me's Avatar
    Apr 2002
    Clark, NJ
    You could always do a test run on my car just to make sure it's ok...
    Oct 2007
    Chesapeake, VA
    00 Mshoe
    UPDATE 8/9/2013
    Miles: 95111
    Oil change complete (mobil1 15w50)
    Diff oil changed (Royal Purple 75w140)
    Tranny topped off (Amsoil)
    All photos taken with my trusty toaster.
    Motion motorsports undertray fitted:
    The mail came today:
    Some light reading material
    And the harness for my next project came
    Thats all for today...
    or well I'll give ya a teaser for what else is HOPEFULLY to come. I put in an bid on a place that has living space for the Shoe to get it off the streets (I'm excited and nervous).
    Jul 2004
    SA TX
    E46 M3
    word is RP diff fluid breaks down quickly... thats the word on M3 forums... i stick to redline.. yrmv
    Oct 2007
    Chesapeake, VA
    00 Mshoe
    I figure knowing what's it is is better than guessing. I'll get redline next when I can order it on the interwebz. RP was local
    Jul 2004
    SA TX
    E46 M3
    Word. It'll be goo for a quick rinse.
    Andover, MN
    Z3 Coupe, ZHP, E46 M3
    Looking good! That MM undertray is sexy...
