They are called upper strut tower bearings. They have a bearing in them that mounts the top of the shock/spring assembly to the car. Couple things here, the right side it obviously broken and if you look the left side has cracks in it so you need to replace both of them as the left will break soon. Also try not to drive the car with the mount broken, you can do damage to the suspension of your car ( if you havent already), your alignment is going to be way out so you will be wearing into your tires, and along with all of that it just being NOT safe to drive. If you know how to work on cars these arent a huge pain to replace and the parts arent going to cost you an arm an a leg. Im going to guess you have little car knowledge ( not an insult ) so you're going to have someone else do the work. Either way you go ( fixing it yourself of having someone else do it) you need to get the car re-aligned. If you have a buddy who knows cars, take it to them pay for the parts and some on top and then take the car to a shop for an alignment. If not just take it into a good auto repair place and say "Fix".
What car is this??
-Pat
Whats behind you doesn't matter
Black E36 M3 - Blackbird
Silver 2007 New Body 2500HD - The Judge
