Will any of the the e36 (3-series) strut assemblies (specifically coilovers) directly fit a non-M Z3?
Thanks in advance.
Fronts if you get the entire assembly including hats for the most part (there may be issues with E36 M3 for 1995) yes, but the rears no.
Now in E92 M3 ZCP -- Absolute beast
They're identical. 100%
I've answered this same question twice in the past week alone on here. Please use the search function in the future.
^I like the stance of your z3!
Thanks for the input.
Just double checking, because coilovers aren't cheap... If I were to buy Megan Racing Coils fitted for the e36 (3-series), it would be a direct fit Front and rear to a non-m z3 roadster?
No, only for the front. You need to get something Z3-specific for the rears. Most common mistake along these lines is using rear shocks intended for an E36, which appear to fit but are actually too long, and you'll bottom them out.
I like the unicorns.
'99 Z3 Coupe - Jet Black/Black (1-of-114)
'99 M Coupe - Estoril Blue/Black (1-of-82)
'03 540iT - Sterling Gray/Black (1-of-24)
'16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
