Page 32 of 40 FirstFirst ... 722232425262728293031323334353637383940 LastLast
Results 776 to 800 of 998
Thread: E46 Can bus project.
  1. #776
    Nov 2005
    Kilmarnock, VA
    E53, E90, Triumph GT6
    Quote Originally Posted by hakentt View Post
    Can arduino be programmed to tell the E90 electronics that cluster is present? For example in your E90 you want to install some aftermarket digital cluster and use Arduino to run it, I wonder if E90 electronics demand some special matching code from E90 cluster?
    I would think so. If the can bus codes are correct the other modules can't tell the difference.
    Quote Originally Posted by TerraPhantm View Post
    MSR is actually requests for torque increase (used when engine braking would cause slippage for example). In the MSS54, you can either completely turn off ASC interventions, or you can set a minimum torque before intervention (default is 0 Nm)
    Just so I'm on the same page your suggesting there is a value in the DME we can edit to change the amount of intervention? That might be worth working on.
    On another note, bought myself a Z4M cluster to play with. The DME <-> KMB messages appear to be the same as the E46 (with one quirk being that the oil temp gauge won't register a value above 0ºC unless there's some RPM coming in). What I do not yet know is whether or not the DSC messages are the same. If they are, MK60e5 retrofit to the E46 may be feasible.
    Seems like the engine temp doesn't change on the E46 without RPM. It's been a long time but I think that is a requirement for it as well. I know it doesn't move after the engine is off (to keep it from spiking due to heat soak). And I belive the RPM is what is used to tell if the engine is off.
    I did some work with a couple different Z4. The Can bus codes seemed to be the same.
    On one I know the DSC error light went off when simulating the DME just as it does for me in the E46. (Car was modified to be an EV so no DME) And we found the EPS didn't work unless there was some RPM being sent as well. Seems like it had to be at least 300 RPM.
  2. #777
    Philadelphia, PA
    2005 M3 & 2004 330i
    Quote Originally Posted by Thaniel View Post
    You can set it so that the DME doesn't cut throttle/ignition unless it's making X torque, which I assume also means that the DME will not allow DSC to command torque below that value. I haven't played with it a lot since M-track mode seems sufficient on the E46 M
    Strange, my E46 clusters (all from 04 or 05 models) don't seem to care about RPM and engine/oil temp.
    So one thing that makes me unsure about the mk60e5 working with the E46 is that the MK60e5 only came on 2006+ Z4s, and they all used the new-generation DMEs. BMW obviously programmed those new generation DMEs to use the old CAN-bus messages, but what I'm not 100% sure about is whether or not there are any new ARBIDs that would be used only by the DME and DSC modules. Can't know for sure without logging a 2006+ Z4, which is easier said than done. From what I can tell, the cluster is looking for ASC1 and ASC3, telling me that at least some of the messages are the same as the old DSC modules.
    Main reason I'm interested in retrofitting the newer MK60e5 module is that it has a couple cool features, including hill hold for manual transmissions. Clutch switch data, brake pedal sensor data, and throttle position are all transmitted over even the old-generation CAN bus, so perhaps the module won't be looking for any new messages
  3. #778
    Norway
    e46 332ti,e46 325ti,f31
    The mk60e5 have all the CAN messages as found in the mk60. The typical message transmit rate seems to be 10ms in the mk60e5 while 7ms in the mk60. There is only one extra CAN message (ASC4/0x1f8/ 8 bytes) in the mk60e5, which is related to the HDC.
    Happiness isn't around the corner - happiness is the corner!
  4. #779
    Philadelphia, PA
    2005 M3 & 2004 330i
    Okay so I took a closer look at this since I finally got a CAN interface.
    On my DME, that byte 0 constantly cycles between 0x11, 0x40, 0x80, and 0xDF. It looks like that 4th value is what can vary from engine to engine. On the MSS54, that 4th value is determined by ORing 0xC0 with a variable BMW calls "md_norm_can" which is taken directly from scalar called "K_MD_NORM" which is set to 0x1F on my DME. The math works out -- 0x1F OR 0xC0 = 0xDF.
    According to the funktionsrahmen, K_MD_NORM is the "Standard Torque for CAN" (and for whatever it's worth, the pdf defines "md_norm_can" as "Normalization reference for torque interface"). According to the MSS54 damos, the conversion is 16*x. So 0x1F (31) would equal 496 Nm. 496Nm is quite a bit more torque than the S54 produces. So I don't know if BMW just coded it so that DSC is more aggressive than "necessary" for the amount of torque the S54 makes, or if the "reference" torque refers to something other than the engine's peak torque.
    In an earlier post you mentioned that the 4th value in your sequence is 217 or 0xD9. If the formula is the same as in the MSS54, that suggests your reference torque is set to 0x19 (25), which would equal 400Nm..
    Just wanted to expand on this; the MS43 seems to cycle through 3 bytes instead of 4. 11h, 80h, and D9h (C0h | 19h). This is with the DME on the bench with pretty much no inputs hooked up. I don't know if that cycle tells the DSC module anything, or if it just doesn't matter beyond broadcasting the "standard torque" at the right interval.
  5. #780
    Jan 2013
    Russia
    E46 330 ESS Touring
    As I understand, E46 (and also z4) IKE doesn't show real oil temp, it just shows a temp calculated using some formula that depends on coolant temp, rpm, running time, etc. Correct me if I'm wrong. That's why E46 M3 IKE shows oil temp even with MS43 connected instead of MSS54.
  6. #781
    Nov 2005
    Kilmarnock, VA
    Quote Originally Posted by MadToha View Post
    The IKE does not make a calculation for oil temp. It displays whatever value is in the Oil Temp byte of the can bus message from the DME. I can make and have made the coolant temp gauge read totally different from the oil temp gauge.
    The reason the MS43 DME will show oil temp on the E46 M3 IKE is because an MS43 DME (at least some of them. I have can data logs) broadcasts the oil temperature byte. The Non M cluster just ignores the data. Some E46 DME's do not broad cast the Oil Temp data. The Can version on the DME's does make a difference :-)
    Thaniel
  7. #782
    Philadelphia, PA
    2005 M3 & 2004 330i
    IKE shows what the DME sends it. It's up to the DME to decide how to calculate the oil temp. On the MS43 it's taken from the oil temp sensor attached to the oil filter housing.
  8. #783
    Philadelphia, PA
    2005 M3 & 2004 330i
    Where did you get that information out of curiosity? Going to the MSS54 example, 11h (0b00010001), 40h (0b01000000), and 80h (0b10000000) are hardcoded
  9. #784
    Nov 2005
    Kilmarnock, VA
    sorry I'm not following the question. Which information?
  10. #785
    Philadelphia, PA
    2005 M3 & 2004 330i
    Guess I should have quoted it. There was a post with information on 0x329 byte 0 that is now deleted
  11. #786
    Mar 2008
    Yonkers, NY
    2004 BMW 330i SMG
    Sorry wasn't getting notifications about posts.
    That's interesting info. I wonder if the DSC just looks for the value that comes after one with 0x80h ? I have logs of my MS45 having 0x8C. Maybe it masks it?
    -Matt
  12. #787
    Philadelphia, PA
    2005 M3 & 2004 330i
    Quote Originally Posted by mdrobnak View Post
    -Matt
    Based on what I remember from the deleted message, 329 byte 0 is a multiplexed message. The value of bits 6 and 7 dictate what information the DME is trying to broadcast, and bits 0-5 contain the actual data.
    If 7, 6 = 00, then the DME is trying to broadcast whether or not the CAN-bus is okay. The deleted message mentioned 00 was "okay" and "11h" was not, but I think it's the other way around since 11h is the only value I've ever seen any DME broadcast
    If 7, 6 = 01, then the DME is trying to broadcast the engine type (with 000000 being petrol, and I forget the other combos). So that explains the 40h we saw in all our logs
    If 7, 6 = 10, then the DME is trying to broadcast the transmission type (000000 being manual, and i forget auto and SMG... though it should be noted that the M3 doesn't seem to bother broadcasting whether or not it has an SMG). 80h if manual, and perhaps other functions since the MS45 seems to change values based on certain conditions.
    If 7, 6 = 11, then the DME is trying to broadcast torque according to to the formula we already figured out (x * 16 = standard torque)
  13. #788
    Mar 2016
    Texas
    Thaniel,
    I'm interested in your solution if you can message me.
  14. #789
    Nov 2005
    Kilmarnock, VA
    Quote Originally Posted by jakeshoe View Post
    Thaniel,
    message sent.
  15. #790
    Mar 2008
    Yonkers, NY
    2004 BMW 330i SMG
    Then I would guess the DSC looks for whatever has bits set to 1 in 7,6 and uses that value, and ignores everything else - though I read in some BMW docs that it sends out a bit to the "AGS" (auto trans controller) to keep it in gear during a DSC intervention.
    So engine type is missing from the MS43 broadcast on the bench. Hmm.
    Thaniel - your cars are MS43 right? Do you see 40h as a value for 0x329 byte 0?
  16. #791
    Jun 2014
    Heilbronn, Germany
    E39 530i 2002
    Here the Message, that have been deleted. Found in notification mail
    ---Quote (Originally by TerraPhantm)---
    ---End Quote---
    I assume this is about 0x329. The format of 0x329 byte 0 is:
    Bit 0-5: 6 bit mulitplexed info
    Bit 6-7: 2 bit multiplexed code
    Bit 6-7 (binary):
    00: can status
    01: info about engine/gear box
    10: obd control
    11: md_norm
    Multiplexed format belonging to each code is:
    00: can status
    multiplexed_info: can_ok (00h?), can_not_ok (11h)
    multiplexed_info:
    bit 0:
    0: petrol engine,
    1: diesel engine
    bit 1-2:
    00: gerbox manual
    01: gerabox smg
    10: auto
    11: ?
    bit 3-4:
    00: engine type 1-4 cylinders
    01: engine type 5-7 cylinders
    10: engine type 8-11 cylinders
    11: engine type 12 or more cylinders
    bit 5:
    0: the provided info is not valid
    1: valid info
    10: obd control
    multiplexed_info: in accordance with the obdII standard
    11: torque interface scaling factor (md_norm)
    0-99.6094% of md_norm
    multiplexed_info: range 00h-3fh
    value = 16*hexValueOf(bit0-5) [Nm]
  17. #792
    Nov 2005
    Kilmarnock, VA
    I have a few MS42 and MS43. I'm looking at a data log from an MS43 and it shows on ARBID 329 byte 0
    11
    86
    D9
    On an MS42 log I have
    11
    88
    D9
    Hum a log from a z4
    11
    40
    85
    D9
    One more. From a 318i MS42 (Australian)
    11
    40
    88 or 8C (from different data samples of same car)
    D0
    In our modules we use
    11
    80
    D9
    and we get no errors in the other modules in the car. I forget what we thought the 86 and 88 were in Byte 0. error status?
    Thaniel
  18. #793
    Sep 2010
    Pacific Northwest
    95 BMW M3 | 03 330i ZHP
    Quote Originally Posted by demlotcrew View Post
    Thanks Pete,
    I have it all under control (I think). Ive got most of the data working now, only need to work out why brake pressure is not being transmitted, does anyone know if this comes from the ASC module? Its not an issue for me as I have FIA fully calibrated F1 pressure sensors on both circuits. Ive tapped directly in to the valve block, not even the 1mb MK60E5 sensors come anywhere near, but it would still be good to work out why the MK60 pressures are not being sent over CAN for others who might want basic built in pressures.
    Andrew
    Andrew,
    Would you be willing to share more pictures of your setup?
    Trever
    2003 E46 330i ZHP - Daily Driver | Bike Hauler
    1995 E36 M3 - Autocross | Fun
  19. #794
    Philadelphia, PA
    2005 M3 & 2004 330i
    Quote Originally Posted by drukhadze View Post
    ---End Quote---
    Bit 6-7 (binary):
    00: can status
    10: obd control
    11: md_norm
    00: can status
    multiplexed_info:
    bit 0:
    0: petrol engine,
    1: diesel engine
    bit 1-2:
    00: gerbox manual
    01: gerabox smg
    10: auto
    11: ?
    bit 3-4:
    bit 5:
    1: valid info
    10: obd control
    Okay, so looks like I mixed up a couple things. So if I'm reading it correctly:
    If bits 6-7 are 00, the CAN status is sent (and everything seems to send 11h, so I'm guessing 11h really means can okay)
    If bits 6-7 are 01, then the engine type, gearbox type, and # cylinders are sent. But not every DME seems to bother actually sending anything here (MS43 skips it altogether, and MSS54 is hardcoded to 0x40)
    If bits 6-7 are 10, then some OBD data is apparently sent
    If bits 6-7 are 11, then the standard torque is sent, and this is the only one that seems to be consistently applied.
  20. #795
    Philadelphia, PA
    2005 M3 & 2004 330i
    Been digging through more can disassembly stuff and figured out where the DME processes received messages. So here's some more information on ARB 615 since that one's pretty easy (bold is stuff I added):
    ARBID: 0x615 sent from the instrument cluster.
    -B0 AC signal. Hex 80 when on (10000000) Other bits say something else (Load, Aux fan speed request? system pressure?). AC torque is in bits 0-4 (value can be between 0 and 1F; unit is Nm). Bits 5 and 6 are unknown
    -B1 Bits 4-7 = AC Fan-speed request (can be 0-15). Bit 2 = Headlights/Parking lights on. Bit 0,1,3 unknown.
    -B2
    -B3 Outside Air Temperature: x being temperature in Deg C, (x>=0 deg C,DEC2HEX(x),DEC2HEX(-x)+128) x range min -40 C max 50 C
    -B4 Bit 0 set = driver door open, Bit 1 set = handbrake engaged
    -B5 Bits 3, 4 = CAN_EKP_CRASH (probably whether or not the car is crashed and whether or not fuel pump should be turned off). Bit 1 set = Left turn signal, Bit 2 set = Right turn signal. Hazards = Bits 1 and 2 set.
    -B6
    -B7 Bit 1 = Key Information (if 1, key information available); Bits 2 and 3 = Key number (00 = Key 1, 01 = Key 2, 10 = Key 3, 11 = Key 4)
  21. #796
    Nov 2005
    Kilmarnock, VA
    Great stuff. I'll update page one so it is easier to find. (When I'm on a computer)
    -B2
    -B6
  22. #797
    Aug 2003
    georgia
    135i, R53 jcw, x5d, E39
    has anyone tapped into the canbus and adapted a bluetooth elm 327 onto it? something like canbus > arduino > bluetooth > bluetooth phone/tablet app like harrys laptimer
    Using the free/cheap data logging tools over kline is very very slow if we could get the canbus data instead it would be able to keep up with 10hz gps instead of only 1hz
    The term badge whores is not allowed on bimmerforums, because badge whores don't like it
  23. #798
    Nov 2005
    Kilmarnock, VA
    Quote Originally Posted by MrBlah View Post
    Yah I did something like that. We did
    e46 can bus>mcp2551>mcp2515>arduino>mcp2515>mcp2551>Blueto oth elm obdii adapter>iPad using some obdii app that allowed custom gauges.
    Everything to the left of the arduino was BMW can bus messages. In the arduino we converted to obdii standard messages so the Bluetooth module would understand it. It was amusing and we did it at the request of a ev builder that wanted to display some data on a tablet. But speed wise it is limited to the max speed of the Bluetooth module. Would probably be faster than getting messages via the iso protocol.
  24. #799
    Feb 2014
    United Kingdom
    1998 Compact 328
    Help please
    Hi
    I have read a lot of this and am trying to understand it.
    I have got this far and would like to get it all working as oem in the car.
    This thread gave me hope that it would be possible for this to work.
    Have the complete engine and ecu I took out is there an option of just leaving the wiring and sensors from the removed parts to make it work?
    All the hardware is done gearbox exhaust mounts everything
    Here is the engine
    Quote Originally Posted by hk1828 View Post
    Hi
    Here is the engine
    The original engine was 4 cylinder the car is 2002 bmw e46 318ci
  25. #800
    May 2016
    Washington DC
    2001 Bmw 325 CI project
    Smile
    New member alert!!!!!! I have a Ls swapped 325 Ci. I have just about everything for the swap but I can't figure out what ECU to buy that talks to the stock ECU . Any suggestions?
