I want to share with you what I've done with my lights using an IBUS interface and small computer running Linux.
[ame]http://www.youtube.com/watch?v=bp7JMdVq3L8[/ame]
The effect lasts for 30 seconds after unlock. All kind of lights and timing can be set. I intend to make a small scheme with microcontroller to do the job.
Thats some serious ingenuity. I envy you, keep up the good work. Maybe at some point a DIY wtite-up. I know id be ineterested in playin around with something like that.
1998 323is Avus Blue, ASA AR1 (Staggered!), 3000k HID Fog lights... Custom turbo kit, never tuned or dyno'd. Recently took off the turbo, looking for complete stock-ish exhaust setup (PM Me!) Stock or ebay headers, stock mid-pipe or 325/m3, m3 muffler would be nice.
I will write a short DIY later on what binary commands I send to IBUS to get the lights effect. The difficult part is to program a microcontroller chip to do the job, but I'm almost done with that. On the video the computer is inside the car
Or you could just pay for the software and hardware that does it for you...
I made the effect with the lights because I developed my own IBUS framework under Linux. The main purpose of the framework was to make an MP3 CD changer emulation with a computer. I just used my scripts to throw some commands on event. I can do whatever I want with binary commands on the entertainment devices inside the car as long as the light control module.
E-light module does this and comes with handy programing interface to setup your lighting. Neat that you did it at home.
>'97 528i, 200000 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers >'65 & '74 MG Midgets BFC OT Lego Club #48 Manual conversion in process!!!
Yes, OK.. I know about eLight module... I've made the video just to share my knowledge with you. On the other hand, do you know how much the eLight module cost, because I can solder that for me within a couple of dollars.
Very cool. Definitely want the DIY on this.
Now this would be very cool, even more so if you could mimic Ipod controls and make it compatible with the DICE module or be able to display TAG info on the MID. Would love to be able to copy my music library to a solid state drive mounted permanently in the car.
OP: Good job! Go on with the good ideas. Only remember to share when you're done. I'm interested in this since Linux is the thing that puts food on my table.
Resident Third World Country Advisor
diy please!!! ive been wanting to program my lights since i got my car! and dnt want to cough up that much money for a controller....
FWIW, so far you havent shared anything but a video. Cost part aside, do you really compare soldering to a programmable module that can do so much more? im not being negative, just asking
p.s. Regardless, good job on the project. This is the exact same lock/unlock light setup I have on my car utilizing the eLight (:
I can't understand why somebody wants to attach a whole programmable module to the IBUS, while I can just make a simple custom scheme and run it, but this is my opinion.
So how to proceed with the IBUS. First you should turn on the lights you want to light and send command ''3F 03 D0 0B E7" to read the LCM's IO status. Then the LCM will reply with a command like "D0 23 3F A0 E1 E0 00 10 00 00 02 00 00 A2 00 00 00 00 00 E5 34 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 FD FB". Get the IO status command, switch the place of the first and third byte, set the forth byte to 0C, recalculate the checksum byte at the end like "3F 23 D0 0C E1 E0 00 10 00 00 02 00 00 A2 00 00 00 00 00 E5 34 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 FD CS" and send it back to IBUS. Voila! the command lights up the desired beams for around 6 second, so you have to resend it as much times as you wish to have them lighted.
This is great. I like it, good job.
awesome!
KEVIN
BMW CCA # 416146
Current 2001 525i-5 / 234,000 Miles
///M Weighted Shift knob.
CD43 with AUX retrofit + Bluebus
Auto Dimming Mirror upgrade
H&R Sport / Koni STR.T
OEM Xenon HID Retrofit
The Ex- 2000 540i-6 / 82,xxx miles to 186,xxx miles
CDV Free, 545i Shifter and ///M Weighted Shift knob.
Member of DSC Module Failure Club $$
it's always good to see some custom work on here.
there's way too much emphasis on OEM in my opinion.
Hey! Can you tell me how to code the flash-light-sequence from the video to my E39? Usually I'm coding by NCS. But here I couldn't realise it.
I tried Navcoder now.
The LCM-promt command didn't show up a return message. I tried sending code from post "3F 23 D0 0C E1 E0 00 10 00 00 02 00 00 A2 00 00 00 00 00 E5 34 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 FD CS" via Navcoder, but the result was pretty poor. LWR-movement und lighting angel eyes only.
Hope you can help me! I would like my car to get illuminated as in the video by unlocking remote.
You can contact me via fd_brandmeister@hotmail.com, too.
