Results 1 to 12 of 12
Thread: Need to find part #
    Ottawa, Canada
    96 328i, 86 325e
    Need to find part #
    My car took a huge chunk of ice from a truck. I'm trying to find the part number for a piece of plastic trim that goes under the bumper. It goes between the two part #9s in this diagram(I think)
    http://www.realoem.com/bmw/showparts...04&hg=51&fg=15
    A friend of mine called it a 'belly skin' if that helps.
    Thanks.
    Ontario, Canada
    2011 X5d, 2013 X1 35i
    51711977117 - Left
    51711977118 - Right
    RealOEM posts the part numbers under the diagrams
    I've replaced these, too!!
    02/1996 BMW 328i - (324,869km/201,864mi)
    Purchased May 15, 2004 (101,210km / 62,888mi) Sold August 22, 2008 (324,869km / 201,864mi)
    Ottawa, Canada
    96 328i, 86 325e
    Quote Originally Posted by beskhu3epnm View Post
    51711977117 - Left
    51711977118 - Right
    You've got it wrong. I'm not looking for left and right. I'm looking for center. You can see on the diagram, that left and right should bolt into something on the inner side, but whatever it is, it's not in the diagram.
    Ontario, Canada
    Quote Originally Posted by Jamil20 View Post
    It's the way I read your post. #14?
    http://www.realoem.com/bmw/showparts...48&hg=51&fg=75
    Ottawa, Canada
    96 328i, 86 325e
    It doesn't look like that. Maybe #15. I'll have to look again. $20 doesn't sound so bad. Here I was getting bent out of shape, because plastic can be expensive.
    Thanks for the help, dude.
    Ontario, Canada
    I was primarily thinking 14 as its the lowest on the diagram... I'll keep browsing around.
    Aug 2002
    Roswell, GA
    2005 X5 4.4is
    Ottawa, Canada
    96 328i, 86 325e
    Quote Originally Posted by zeit00 View Post
    No, that's metal. This is a piece of plastic.
    Aug 2002
    Roswell, GA
    2005 X5 4.4is
    That is plastic..
    It is the piece that goes between the porkchops and hits the underside of the front bumper. It shreds easily and most cars are missing it.
    A lot of people replace it with a JTM underpanel. I think its JTM..
    Edit: Crap you are right.. I have never seen this in metal before. It is usually plastic..
    Ottawa, Canada
    96 328i, 86 325e
    I went and took a closer look at it. It's #14 or #15? Looks sort of like both...
    Oct 2005
    Ontario, Canada
    Mcoupe 1999, Delsol 93
    well 15 is the tow hook so no...14 is the cover that covers the hole for the tow hook...they are both located mid bumper...
    you possibly need #2 in the following diagram...hard to tell from pics
    http://www.realoem.com/bmw/showparts...32&hg=51&fg=75
    Madison, WI
    2003 M3, 1998 M3 TS
    you talking splash guard? mines all fed up.
    2.1L Eurosport Twin screw on the 98 m3. Please send tires.
