Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 101
Thread: E30 M62 Turbo
  1. #51
    Apr 2009
    shreveport,La
    1997 bmw 840ci
    I have a 1997 840ci, auto. Thinking of a motor\tranny swap when my m62 gets tired. I have a few ideas (s62 turbo perhaps).
  2. #52
    Oct 2007
    ny, ny
    e28 m5 e30 4.4T e36 325
    Quote Originally Posted by bigswervin69 View Post
    Nice. Do you have a water cooled alternator? Im not sure if 97 8's got the upgraded motor or not. I have a 96 motor. The early M62's before the upgrade are the best. There highly understated.
    S62 turbo sounds great if you have the money. I think i would stick with the M62 because of its simplicity. I like all around performance so in my case with the e30 chassis, the weight advantage of the m62 was also the way to go. Getting that S62 turbo done right would be huge tho!
  3. #53
    DUDMD's Avatar
    DUDMD is offline BMW Maniac Supporting Vendor
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Still snowed in?
    Performance Tuning and EWS Delete for MSS52/MSS54/MSS54HP/MS41/MS42/MS43/ME7.2/M5.2
    Virgnize DME service available to unlock DME to sync to another vehicle on EWS3 vehicles 98+. M5.2.1, M7.2, MS42, MS43, MS45, ME9.2 and more.
    Easiest way to contact me is to send me a message on my facebook page "DUDMD Tuning"
  4. #54
    Oct 2007
    ny, ny
    Quote Originally Posted by DUDMD View Post
    Still snowed in?
    The snow is gone now. Tuning will begin soon.
  5. #55
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by lughed View Post
    Nice, make some more videos when tuning/done tuning.
  6. #56
    Oct 2007
    ny, ny
    Will do. I reflash the ecu with the latest firmware and now i lost my icv signal and have a miss/putt at idle when at 14 a/r. After i work it out tuning will began.
  7. #57
    Dec 2005
    chandler arizona
    01 s4 blk,01 s4 slvr,93 NSX ,92 NSX , 02 x5 4.6
    looks great....
    did you make up a jig for the mani's and merge? would you want to make me a set? it would save me a ton of work and i would pay accordingly
    let me know
    marc
    01 s4 (500hp), 01 s4 (hers), 07 cayman s (FI soon) 93 NSX turbo, widebody, 02 X5 4.6is supercharged, 02 X5 4.6is (work truck)
  8. #58
    Oct 2007
    ny, ny
    Alittle update. I got the car out finally and it felt good. The session was cut short do to a dying comp battery. But overall the engine ran great off boost.
    Quote Originally Posted by 01blacks4 View Post
    let me know
    marc
    PM sent
  9. #59
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Updates?
  10. #60
    Oct 2007
    ny, ny
    Wow, its been a long time. Well after going through many cooling settups i decided to go through with mechanical fan which involved some relocating, re-chopping and welding and more fabrication. The last straw was drawn when on my way home from BimmerStock the car overheated to ~245*. So here are some before and after pics and a vid that i have been asked to provide.
    After relocating the oil filter, air filter, and re shaping my intake pipe all to be able to fit a mechanical fan and shroud. 12120007small.jpg
    This vid is from over a year ago on the cars maiden test drive. It was a 6th gear pull at about 30-35 mph and the tires broke traction so i let off not wanting to push the revs.
    [ame]http://www.youtube.com/watch?v=mw7HdyHA78k[/ame]
  11. #61
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Damn, 6th gear spinning at such low RPM.
    It sucks you had to relocate the filter housing that much, must not have been easy.
  12. #62
    Aug 2009
    Chicago, IL
    2000 BMW 540i 6 Speed
    Damn! Nice Project you got there sir! Helpfully after i get my stuff sorted out, i'll start working on my 540i with turbo set up. I was just thinking, what do you think of rear mounted turbo set up?
    I know it would create more lag, but im planing on running a smaller turbo? Plus, where did u put the MAF sensor? Did you take it to a tuning specialist?
    Thank you!
    P.S. Subscribed!
  13. #63
    Suffolk, Virginia
    35D X5, 335d
    So cool. Hope you got the cooling under control now.
    OLD
    E30
    636whp
    1/4 mile: 10.91@144.38
    http://www.youtube.com/watch?v=L_f7fUVqblI
    NEW BUILD
    335d
    520whp
    635wtq
    120.51mph trap speed
  14. #64
    Oct 2007
    ny, ny
    Yea, my brother and i couldnt really believe either. the first time it spun was at about 55 in 6th. Then i held it once and the car went sideways. After that i kept doing it at lower and lower speeds and higher gears while datalogging to see what was going on. Interestingly enough i never gave the throttle more than 50% according to the logs and it seems to break loose around 2800 rpm in some of the logs.
    Everything worked out for the better. With all this i managed to clear out some of the heat source from the intake side, my air filter is now down below the heat, the intake tube is shorter and more direct, and i now have more space at the front of the engine dispite having a radiator twice the size of the old one. And the bay actually looks cleaner the way it is now. All wins.
    Quote Originally Posted by filon102 View Post
    Thank you!
    P.S. Subscribed!
    I would prefer doing what ever i had to in order to fit the turbo up front. I do not use a MAF and i tuned the car myself. Mild tune on 7.5 psi
    Quote Originally Posted by futureroadracer View Post
    So cool. Hope you got the oolong under control.
    Thank you very much. Not sure what oolong means but if i need it i hope i got it undercontrol too
  15. #65
    Jul 2012
    jacksonville nc
    M3
    Nice build sir
  16. #66
    DeWitt, Michigan
    '97 540i/6, '97 328i
    I'm loving this build!!!
    I've been thinking that I would build a rear-mount setup on the 540 this spring/summer, but this build kind of shames a guy for thinking that way when you are able to fit everything within the confines of an e30 engine bay.....
    The big sticking point might be the amount of modification that is necessary to the chassis to get the downpipe out of the engine bay and whatnot. I'd like to keep the car unmolested if possible.
    Do you think you could post up some pics of how you routed the turbo kit plumbing? Especially the crossover from the non-turbo side, and how you got everything around all of those massive accessories?
    PS, PHATassM3, Nice sig pic sir!
  17. #67
    Suffolk, Virginia
    35D X5, 335d
    Meant cooling, sorry
    OLD
    E30
    636whp
    NEW BUILD
    335d
    520whp
    635wtq
  18. #68
    Aug 2009
    Chicago, IL
    +100000000
    I would also like to know the routed turbo plumbing
    How did you get around it, not having the MAF sensor? By tuning it, you got rid off need for MAF sensor? Damn, 7.5 on stock m62... thats not bad at all
  19. #69
    Oct 2007
    ny, ny
    The engine in this car is my sig pic. I also believe there are vids and pics in the beginning of this thread. The primaries are 15" equal length and mirrored both sides. The cross over crosses over at the front.
    Quote Originally Posted by PHATassM3 View Post
    Nice build sir
    thank you
    I hope so too but even tho its showing pos. signs i wont know till next summer. At the moment the fan brings it down into the 160's before disengaging. It electric fans never brought it down past 208
    MegaSquirt ecu doesnt use a MAF sensor. 7.5 psi and i only touched that once. The motor can take 9 psi and I believe Dinan and a Swedish builder have both claimed to make ~600 whp at this level on stock engines with much less efficient setups.
    Quote Originally Posted by tptrsn View Post
    I would stay away rear mounts. Its more money, time, headache, and maybe even fabrication with the least to gain. I believe if you are willing to ditch a/c and maybe a few other things you can bottom the turbo where the a/c goes. Right now I cant picture what else might be down there.
  20. #70
    DeWitt, Michigan
    Thanks man, but I can't ditch the A/C on the 5 series! I'll just have to take a good look at things when I get the front end of the car torn apart this spring. There's space for the turbo pretty much where you put yours, it's just a question of snaking all of the plumbing where it needs to go, AND having to build headers instead of using the stockers for a rear mount.... It will be interesting to see what occurs to me when I get 'er apart!
    Keep up the great work with your project!!!
  21. #71
    Aug 2009
    Chicago, IL
    any news?
  22. #72
    Oct 2007
    ny, ny
    any news?
    Actually i have big news. Big 14" rotors news. Im adapting C6 Z06 brakes to all four corners of the car.
  23. #73
    Oct 2007
    ny, ny
    I have an in boost breakup issue arrize. While diagnosing, re-tuning i shot this video from 0- ~100 spinning and shortshifting through 6th gear. You can hear the breakup in 3rd gear and a few of the individual 6th gear pulls. I think the issue maybe my boost gauge somehow. Enjoy
  24. #74
    Oct 2008
    Mclean, Va
    2000 Bmw 750il
    Nice build. Its nice to see a turbo m62
  25. #75
    Oct 2007
    ny, ny
    Thanks. There is a number of them now since the beginning of this year. I am 3 years ahead when people were still saying it couldn't be done.
