Results 1 to 20 of 20
Thread: LED replacement for console dials?
    New York, New York
    M Coupe, E83 6MT
    The bulbs inside my console dials are dying (and my clock doesn't work ). Has anyone successfully replaced their bulbs with LEDs? I would like to solve this problem once and for all!
    New York, New York
    M Coupe, E83 6MT
    I guess no one has done this.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    There are several threads on bulb replacement that can be posted, if that is your question. But I don't recall any about sourcing and using LEDs. I think the bulbs are BMW parts as shown in this thread, with special mounts, which may be why there's no history on using LEDs.
    http://www.bimmerfest.com/forums/sho...highlight=hvac
    BMW MOA 696, BMW CCA 1405
    Tacoma,WA
    Twinscrew M coupe
    I haven’t seen anyone replace the bulbs with LEDs yet but you can get replacement bulbs from any autoparts store. The only real difference between teh BMW bulbs and the generic bulbs is that the non BMW bulbs are a little brighter so I would recommend replacing all three bulbs at the same time.
    Dec 2005
    Sarasota, FL
    98 M Roadster
    What about the bulbs for the HVAC? Is there an alternate source for those? BMW wants ~$8/each for those little buggers.
    Oct 2012
    Louisville, KY
    Quote Originally Posted by Vinci View Post
    Do you suppose that it is not a BMW part consisting of bulb plus base, and that you can get a generic bulb without the base?
    http://www.ecstuning.com/Search/Site...3797/ES165448/
    Kent, Ohio
    1998 M Roadster
    Quote Originally Posted by Vintage42 View Post
    The HVAC bulbs are a composite housing and bulb with the bulb is molded into the housing. The bulbs do not come out of the housing; plus they are really expensive. They are also a PITA to get to unless you are pulling the center console for some other reason--in which case REPLACE THEM.
    Tacoma,WA
    Twinscrew M coupe
    there isn't an aftermarket bulb for the HVAC controls I picked up a spare control module just for the bulbs but other than that I think your only real option is to pay dealer pricing.
    Oct 2012
    Louisville, KY
    Quote Originally Posted by Mr Bingley View Post
    The HVAC bulbs are a composite housing and bulb with the bulb is molded into the housing. The bulbs do not come out of the housing...
    That's why I have a spare bulb in housing, on hand waiting to go in if needed.
    Springfield, Ohio, USA
    1998 Z3 Roadster
    I haven't tried this yet, since I don't have any burned-out bulbs, but the BMW panel bulbs sure look like these B8 style bulbs:
    http://www.superbrightleds.com/morei...panel-led/222/
    It would be worth a try for the cost.
    Oct 2013
    Tennessee
    2000 M roadster
    subscribed
    New York, New York
    M Coupe, E83 6MT
    Quote Originally Posted by Blacklane View Post
    It would be good to get a pic of the base of those. From what I see, they don't look similar but I think you're on to something. I'm going to do some more digging.
    Oct 2013
    NSB, FL
    2005 BMW Z4 3.0i
    The problem with using LEDs is that they are so bright they will wash out the amber color.
    1998 Z3 Roadster
    Quote Originally Posted by canaryM View Post
    Follow the link to the SuperBrightLEDs website, then scroll to the bottom of the B8 listing and they provide dimensioned drawings. I just don't have any BMW lights out and available for measuring.
    Quote Originally Posted by Knowthebattle View Post
    With LED bulbs, you can buy amber, red, or any other color. Typically that really enhances the look when used to back-light a similar color, precisely because there is no other color to wash out the intended one.
    Dec 2005
    Sarasota, FL
    98 M Roadster
    They aren't molded into the base, but they are attached. I examined a blown bulb that I replaced a while back, and it can probably be made to come apart. The question will be if I can find something else to go back in its place.
    I was just curious if anyone had already been down that path.
    Kent, Ohio
    1998 M Roadster
    They aren't molded into the base, but they are attached. I examined a blown bulb that I replaced a while back, and it can probably be made to come apart. The question will be if I can find something else to go back in its place. I was just curious if anyone had already been down that path.
    I took one apart last weekend and tried just that--the bulb is soldered to the plug pins in the middle of the housing, and the housing is formed around them--no way to unsolder/resolder without melting the housing in the process.
    New York, New York
    M Coupe, E83 6MT
    Didn't catch that, thanks! Looks like these are the twist on types. Ours are plug-ins.
    Dec 2005
    Sarasota, FL
    98 M Roadster
    Challenge accepted, Mr. Bingley, challenge accepted.
    Boynton Beach, FL
    98 M Roadster
    New York, New York
    M Coupe, E83 6MT
    These are still twist-ons. Maybe they can be removed from their original socket/housing and placed in the OEM one?
