Tools Needed
Wire cutters
Black Vinyl Gutter Gaurd
Pack of 4" Zip (wire) Ties
Electric Drill
9/64 Drill Bit
Time to Complete
Approx. 20 minutes__________________________________________________ ________________(Original idea by 12CoolDude Racing mesh upgrade...Inexpensive!)
My brother suggested I do this mod a year or two ago and the piece never stayed in place because of issues I will bring up later in this DIY. I decided to document this for anyone who wants to freshen up the look of the old pre-facelift bumper's ugly lower grill.
Get the black vinyl instead of the aluminum shown.
(Photo courtesy 12CoolDude)
Use a tape measure to measure and cut using wire cutters or scissors:
Length = 44.5"
Width = 4"
Tip:
Here I have cut the piece to length only and am comparing it to the old piece.
Cut the piece to width.
This is the old piece, but I use it here to show what the finished piece should look like.
The problem with the old piece staying in place was caused by not having a place to anchor to the grill on the passenger side.
You do not have to remove the passenger side piece to drill, but I did to make things easier, and because I wanted to know for sure I wasn't drilling into some crucial component.
I used the wire cutters to gently pry the center pin of the expansion rivet out.
This is what the rivet looks like with the central pin pulled out (this is also on the driver side but I'm using it for reference).
Pull down and out to remove the grill piece (once again, this is on the driver side, but is identical on the passenger side).
I used the drill to drill two small holes, but it turned out I only needed the hole on the left.
Note: This is on the passenger side grill piece only.
Here are the zip ties I used to secure the mesh piece in place. You'll need two for each side, four total. You'll have to connect two zip ties together for each side. Do not tighten the two zip ties together until you are securing the mesh in place.
Note: You will NOT need to drill a hole on the driver side because you can secure the zip tie around the top of the grill piece as shown below.
Here I have secured the passenger side throught the drilled hole.
The middle and bottom of the mesh is held securely in place by the license plate clips and the lower bumper. You can use extra zip ties to secure the middle portions if you choose, but it is unecessary.
Here's what the finished product looks like.
Special thanks goes to 12CoolDude for coming up with an excellent idea, and ignoring the haters who lacked imagination and open mindedness.
Looks good Jamie. I wanted to do this, but I switched to the M bumper...
Looking for a DIY? Parts? Check this out, it might be your ticket
Stable: e92is, e53 N62, e46M54B25, Tribby & e39 M54B30 R.I.P.
Excellent! Well done!
The original bumpers are the best looking. The M-Technic bumpers look simply horrid.
I also like the grilles on your car, James. The original thin and cruel ones look much better than the somewhat feminine 'Mick Jagger' grilles they put on the later cars.
I'm not sure if you are being sacrcastic.
I like the mod and the bumper if it is done right.
Here's a pic of Jordan's (jord1016) car. The lower bumper mesh is original race mesh.
(Source: http://forums.bimmerforums.com/forum...8&postcount=68)
I would also like to eventually do the bumper lower lip like this too (I just discovered Petes540i6's kick a** DIY today - Integrated Front Lip Spoiler).
I like the look of the border around the mesh. It gives it a finished look. I'll have to think about how to replicate it.
I'm serious. Ask Jason5Driver, he wants to put the thin lips on his car.
I've heard of a number of guys who have put the M-Technic style bumpers on their cars, and a few years later they take them off (in disgust).
Anyway, what's the point of the pasta strainer on the front?
Lol!
Ah ah aaaah! If you want to know the point, read the DIY.
(Although from what I understand, the mesh smooths the air flow of the air entering and cooling the engine compartment. The smoothed out air flow cuts down on drag and therefore causes a miraculous increase of 20HP.)
And for the love of God, what is your avatar? It looks like part of a woman's anatomy set alight with gasoline.
James, are you a misogynist?
Nice DIY, James! Nothing better than an inexpensive facelift to spruce up the look of the e39.
Clever. Really makes the non-M bumper stand out a lot more. Looks a lot better
PRICE CUT on ALL FABRICS
the real reason for the mesh is to keep track debris like rocks, tire goobers, etc from taking out your radiator or oil cooler. on the e90 328i that we run in Grand-Am, we have black mesh zip tied behind all openings in the front; including the grille, bumpers, brake ducts, etc
for the street? not really necessary but can help cut down on the cig butts and leaves i repeatedly dig out of those gaps
James
'88 M3 (track and weekends) | '01 540i/6 (daily) | '95 4Runner (lifted and armored)
Thanks guys (gals?).
The great thing about this mod is that I have enough material left over to do it again and again and again.
Total cost of the mesh = $4.00 USD.
I do want to do the border though. Not sure what material to use. Maybe 12CoolDude will think of something.
horrid?
Good idea, but no. When you need access to the fog lights, just snip the zip tie, pull the mesh aside and install new zip ties when finished.
Trying to line up the three seperate pieces to look like one piece would be a PITA and unecessary.
The best things about this mod besides how it freshens up the lower grill, is the low cost and ease of the install. Keeping it simple should be tantamount.
If the mesh gets damaged by road debris, it's so easy to cut a new piece and replace. This is the first time I've replaced it even though I did the mod exactly two years ago.
And I still have enough left over for several more replacements.
I reckon if you hit tire goobers or rocks with that vinyl mesh, they'll go straight through.
We might need a materials technical update (MTU). Zip ties also do very poorly when exposed to the elements. HiRel Zip ties (with a steel tooth) would be preferable in this application.
I also noticed the plastic stuff is a bit tricky to install. I was trying to put it on last night and it kept breaking when I tightened the wire ties. I guess the ~30° F temperature outside didn't help the plastic's flexibility too much.
I guess I'll have to track down some aluminum stuff; has anybody found any black aluminum mesh?
