Page 54 of 62 FirstFirst ... 42944454647484950515253545556575859606162 LastLast
Results 1,326 to 1,350 of 1544
Thread: E46 330i Automatic - M54B30 Turbo
  1. #1326
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by wazzu70 View Post
    Only problem is with a GT30 turbine your P3 is unreasonably high Cant have it all I guess!
    In general, I think that this turbo has a mismatch between the compressor and turbine wheels. The more efficient an engine is, the more the restriction in the exhaust will be evident. In contrast, a less efficient engine is going to need more pressure on the inlet to get the same mass flow out the exhaust, so it might be a better match. That....or a smaller engine period. (This probably why the Ford Focus with it's smaller engine was able to do so well with the GTX3076R)
    Then there's my engine, which is absolutely stunning me with how efficient it's airflow is. It was sucking air through the compressor faster than the turbine wheel could let it out....at all RPMs. The GTX40 feels stronger off-boost in comparison to the GTX30.
    Considering my experience with the GTX30, one might expect that I could recommend it for XXX HP on our engines....but I can't. I think it might be a good turbo for a lower efficiency 2.0 - 2.5L engine, but with higher airflow it's not a good fit. On my engine, at about 42 Lb/min of airflow, the exhaust back pressure starts to exceed the inlet manifold pressure. If I target 19 PSI of manifold pressure, this happens at approximately 4000 RPM. If I target 10.5 PSI of manifold pressure, this happens at a higher RPM. If you want to run more than 42 lb/min of airflow, at any RPM, a different turbo would be a better choice. As odd as it sounds, I think the GTX3071 would have been a better fit for my engine, it just wouldn't make as much peak power. The cost of using the GTX3076R is high EBP....and you either add high octane fuel to deal with that, or lower the boost. The GTX3076R is probably fine up to 400whp, but it's not the best fit for how our engines operate.
    For those wondering about my comment on high octane fuel: High EBP means more of the exhaust charge is left in the cylinder during the intake stroke. In-cylinder charge temps end up being higher, and you need higher octane to combat that.
  2. #1327
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I wonder what the backpressure is for an N55 motor on which the owner has cranked up the boost — 3.0L and an even smaller turbo. Maybe past 2:1?
  3. #1328
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    Quote Originally Posted by PEI330Ci View Post
    I've not heard one person "like" a GTX3076R. The GT3076R was a big mismatch between compressor and the small 60 mm major dia UHP turbine wheel (which is REALLY old tech). Then they put a higher flowing turbine wheel that takes more torque to spin at any RPM, and saddle it with the same turbine wheel? No shocker that the turbine inlet pressure required to drive the thing was through the roof.
    I believe I mentioned it when you were thinking about using the GTX3076R - the GTX3576R is a much better fit, and will make more power, and typically have a faster response as the larger turbine wheel can provide more torque at lower massflow conditions that the big compressor wheel needs. I think you're seeing that with the GTX40.
    FWIW, the GTX3076R having good boost control is the same as sticking a silencer plate in your exhaust with the GTX40 - you had really high EBP, and that compensated for the poor WG flow priority on the manifold. Take away that high EBP condition - and you're only going to get creep.
  4. #1329
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by Def View Post
    Maybe you are confusing me with someone else?
    I don't recall telling anyone on Bfc that I bought a GTX3076R until months after I took delivery of it. (I ordered the GTX3076R in November of 2011, and this thread was started in November 2014.)
    Or perhaps you are referring to when I was considering running a TS housing on the GTX30 with the Steed Speed? There was certainly a lot of suggestions at that point....and I remember you being quite helpful along with Phil and Butters.
  5. #1330
    Def's Avatar
    Aug 2002
    SW22, Volt
    Maybe it was after you already had it - but yes, the GT35 turbine is a much better fit for that much compressor wheel.
  6. #1331
    Jul 2005
    PEI, Canada
    2001 330i
    I totally agree
  7. #1332
    Sep 2002
    USA
    BMWs
    This is the basis of my issue w/ boost creep. Went and put my 7675 on with a 4" exhaust right off the turbine housing (.81 AR open T4) for maximum horsepressures and found that my EBP is the opposite effect of what Adam saw w/ the 3076 - there isn't much motivation for exhaust to change direction and leave the collector area pre-turbine despite the dual 44mm holes I poked. It's better now, but still not perfect. I think coercing it with some scavenging by recirculating the WG's may work, but that's a PITA.
  8. #1333
    Bellingham, WA
    e30
    I know you don't want to fab up a new exhaust, but do you think switching to 3.5" would provide a little backpressure to increase boost control without having a significan impact on horsetorques?
    Its usually said that you can't get too big with a turbo exhaust dismeter. Thats mostly in literature from the 80s/90s. I wonder if a "huge exhaust" then was like 3" diameter? Kind of like the statements that you want a really small cam with a turbo engine. It worked at the time because people used really poor flowing manifolds and inefficient turbos.
    Adam, what is the diameter of your exhaust again?
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  9. #1334
    Manchester, N.H.
    96 332IS 6466 turbo
    3.5 wouldn't be enough reduction. 3.5 will flow a shit ton of power w/o choking at all.
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  10. #1335
    Jul 2005
    PEI, Canada
    2001 330i
    3"
    At the time I did it I wasn't thinking primarily about power, it was about noise. 3" is quieter than 4" in general, and that was...and still is important to me.
    The thing is, my exhaust is 3" straight through.....you can roll a tennis ball from the turbine housing out the back through all 3 mufflers in place.
    Since I have the sensors and data channels, I might add a bung on the exhaust just after the WG recirculation to measure exhaust pressure at that point. I'm very interested to see how far I can stretch the use of this exhaust before it's an issue....
  11. #1336
    Jul 2005
    PEI, Canada
    2001 330i
    I am considering removing the oil cooler from my engine.
    Under most operating conditions, I don't see engine oil temps going over 200 degrees, Realistically, I should be running the oil over 210 degrees to help vaporize moisture contamination, but I very rarely see that kind of temperature. In fact, most of the time I don't see over 190 degrees on the street!
    Being that I have really good control of coolant temps....able to hold them under 200 degrees at the drag strip hot lapping....and under 180 on the street....I think I might have over-done my cooling package.
  12. #1337
    Sep 2002
    USA
    BMWs
    Had one fro my car and sold it off as well. I saw oil temperatures that mimicked coolant temp exactly and nothing more.
  13. #1338
    Frederick, MD
    '87 e30, '02 e39 Dinan
    Can you add a thermostat for the oil temp?
    Capital Driving Club Car # 102
    How to turbo your car:
    Step one. Install ecu and learn to tune and or have it tuned.
    Step two. Install injectors and retune.
    Step three. Install turbo parts and bits. get it running with out leaks. DO NOT DRIVE IT. Idling should be ok
    Step four. Retune car
    Step five enjoy
  14. #1339
    Sep 2002
    USA
    BMWs
    Quote Originally Posted by euro2fast4u View Post
    Oops - thermostat question.
    Most coolers do have a t-stat, but it's made no difference in the way I drive my car. Unless you have a real race car it's probably unnecessary.
  15. #1340
    Def's Avatar
    Aug 2002
    SW22, Volt
    What about a small oil to coolant heat exchanger like a lot of OEM cars have (primarily Japanese, but you can get aftermarket ones)?
    You'd get faster oil heating, and still be able to control excessive oil temps if they start to get really hot for some reason. Advantage of also not needing to duct another heat exchanger, and the mass impact is very low.
  16. #1341
    Mar 2013
    Upstate NY
    M3
    I've had oil temps way high in my car but like 99% people say, no track use, it's not required. Try hot lapping for 30 minutes straight with a turbod M5x / S5x and you'll want a cooler just because of the noise it makes. Thermostats should be used on aftermarket setups, they are cheap enough. On top od that the turbo is only oil cooled so take that into consideration.
  17. #1342
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by 5mall5nail5 View Post
    Good data point. Thanks!
    Yes, but it comes with some compromise...mainly the complexity of adding 4 additional connecting points to the oil system.
    I was originally planning to use a Laminova oil cooler. However because of how much the OEM cooling system would have to be modified to accommodate this, I went with what I thought was a "simpler" system.
    Quote Originally Posted by Mklock View Post
    The one thing that needs to kept in mind is that the oil pressure regulation is based on a feedback circuit from the main oil gallery in the block. You can add all kinds of stuff after the oil pump, and the regulation valve will accommodate this up until the pump runs out of capacity. Adding a thermostat that in theory might affect flow, will be compensated for by the oil pump. Want to put 3 oil coolers in series? The regulation valve will compensate for the pressure drop through the cores. A thermostat is a viable option.
    Of course....running a dry sump would also change things...
  18. #1343
    Jun 2005
    New England
    S54 housing has a thermostat for the cooler. It’s what most use.
  19. #1344
    Sep 2002
    USA
    BMWs
    Adam - I really like the N20B20 oil coolers as fitted to our X1 M Sport. Small but effective.
  20. #1345
    Jul 2005
    PEI, Canada
    2001 330i
    It's a smart option, but I might see how the no oil cooler thing works.
    I'm not buying any more oil coolers! I think I have 4 right now...
  21. #1346
    Jun 2005
    New England
    While I was still supercharged, I swapped in the S54 filter housing and a 10AN adapter for the cooler ports and bought a nice 13 row cooler. Put the turbo on about 6 months later and found my oil temps ran cooler with the water and oil cooled turbo than the oil cooled Vortech V2 and that I did not need a cooler. That was 8 years ago and my cooler ports are still capped. But I am not trying to make 1000 rwhp and do not track my car and live in NH where temps don’t get over 100F.
  22. #1347
    Vancouver, B.C., Canada
    '97 M3
    At what whp/wtq do you expect the Timeserts to start to pull out of the aluminum block?
  23. #1348
    Jun 2005
    New England
    He will let us know later this year.
  24. #1349
    Vancouver, BC Ca
    1993 325is
    I know it's not apples to apples, but there are plenty of 1,000+ whp 4 cylinder Hondas out there and they don't have any trouble with pulling the head studs out of the aluminum blocks.
  25. #1350
    Jul 2005
    PEI, Canada
    2001 330i
    I don't have any indication that this will be a problem.
    800rwhp was made in Sweden with 10mm head studs without timeserts.
    I'm running 11mm studs and timeserts....so the thread engagement into the aluminum is closer in surface area to 1/2" stud.
    If the aluminum anneals, that would be a problem regardless of the size of the fastener, but so far I haven't put that kind of heat into the block.
    Since this is primarily about cylinder pressure, as long as I keep the torque to a manageable level I should be OK. My goal is to manage torque output with boost and timing to keep the curve flat from about 5000 - 8000 RPM.
    To give an idea of the strategy:
    First Gear = < 200rwtq
    Second Gear = 300rwtq
    Third Gear = 450rwtq
    Fourth Gear = 600rwtq
    Fifth Gear = < 750rwtq...but realistically I'll probably top out around 660 with nitrous.
    The target is not so much engine torque, as axle torque after transmission and differential multiplication. Somewhere around 2600 ft/lb on street tires with a good road seems to be my current limit. If the head studs pull out of the block, I'll just mark that point in the data, and set the limit under that for the next block. (I have a spare block)
