PM'd you
2001 540it manual Solomon
1995 525i Edy
2003 525it manual Jeff
2002 540ia Kruse
1999 540ita Battle Wagon
2000 M5 Hazel
1999 540i sport
1997 Z3 - BubbaZ
2017 M240i
1995 325is NASA GTS2
Toolman, would you be interested in fabricating another adapter plate for the same supercharger build? I am very interested in buying one. Thanks!
------ gakkk -----------
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
DOH. Thread confusion. I thought this was Wagons current thread/build, sorry. Different guy/setup/etc.
2003 M3CicM6 TiAg
Former:
Bump , would like to see vids of this beast pulling
That's for sure
E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
2003 M3CicM6 TiAg
Former:
i'm still interested in the experiments going on over at bimmerbosted of using a newer more compact jaguar blower with a forward facing throttle body, something to keep an eye on for sure.
http://www.bimmerboost.com/showthrea...981#post755981
Looking for an e39 Touring black carpet set, including the rear cargo cubbies and side sections!
ALSO looking for 540i 6speed manual transmission sets (2001+ pedals with switches, driveshaft, gearbox), for the 6speed swap! Probably not for a while....
GN92489
540i msport touring; jet black on grey
Progress Thread (general)
Progress thread (touring specific)
Toolman2 is kind of Ghost which never apear....))))
e39 540i 6speed Supercharged,
E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
Sorry, Autowerke active programmable ecu sold by Urotuning.com
Sent from my A571VL using Tapatalk
2003 M3CicM6 TiAg
Former:
I'm back...
So i had this extra sts blower sitting around and thought i'd see what the newer design with the larger inlet, possibly improved intercooler, and larger and straight ports would do and if it would actually fit under the hood. The port shape and spacing wouldn't work at all so they were cut from the casting. I made die to form runner tube halves from sheet and welded them together, this way i could form a taper for the intake runners
20170908_001126.jpg 20170911_223843.jpg and ended up with this 20180128_170357.jpg
THAT is sooooo frikkin SWEET! You are the man!!!
sts blower? cool
but i think at that height, it's less about fitting under the hood and more about how big of a hole you'll have to cut in it for the blower to fit though
GN92489
Crazy?! Is he saying that it actually DOES fit? Looks HUGE on the mockup motor but if thats it in the engine bay, doesn't look so bad!?
2003 M3CicM6 TiAg
Former:
Impressive job on the runners! From here, it looks like it will fit with the hood closed. What throttle body?
Technically it did fit...20171214_181602.jpg but i ended up cutting the motor mounts and welding them so the motor set 1/2" lower.
The STS and the M62 throttle body are basically the same.
2003 M3CicM6 TiAg
Former:
That is some impressive work, how is it performing?
Thanks you guys for the compliments. It's been a lot of work!!!! I've only had had a couple of days i could test and tune with all the snow here in Michigan and with the salt on the roads traction is limited so i can't say if there is an improvement over the XKR setup but hey i'm just happy it works at this point.
I had a problem with heat soak on the old system and noticed the cheapo coolant pump was kapoot! Heres a pic of the new ZL1 pump verses old dead pump. Made a huge difference!
That is absolutely awesome!!
What are you doing with your old m122 supercharger?
