Page 5 of 12 FirstFirst 123456789101112 LastLast
Results 101 to 125 of 281
Thread: Big Power Manual Transmission (S6-53) Swap
  1. #101
    Under a roof
    507whp 318i
    Quote Originally Posted by Mklock View Post
    So what's the group buy pricing starting at?
    This^^^
  2. #102
    Mar 2008
    Canton, Ohio
    02 525it, 97 M3, 08 X5
    Quote Originally Posted by Kame36sedan View Post
    Isn't the bolt pattern on the housing the same as the e36 trans? I know of 2 people running the earlier n54 trans that does not have the pilot bearing in the input shaft. But like I said, the n54 8 bolt crank clutch setups bolt to the e36, so in theory you should be able to bolt up the trans and run an n54 clutch kit. Just have to figure out starter. Slave will work as well.
    Maybe you are thinking of the GS6-45BZ trans that came on the later n55 cars? It has a more traditional looking input shaft.
  3. #103
    Mar 2012
    Renton, Wa
    98 m3
    I got this guy all mounted up last night. Fits perfect. No issues with the trans tunnel or anything. Just waiting on the clutch to try this guy out.
    I took measurements (cmm) if the mounts and trans brace and then measurements of the shifter location.
    I’ll machine little shift carriers for these setups also. Not included in the kit but available for those of you looking to keep oem shift lever selection.
    Its almost exactly 53” flange to flange. So those of you looking to use a dss or similar you can check your shaft versus that. That measurement is from output flange face to driveshaft face, so if you want a guibo in there or an adapter that needs to be included.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  4. #104
    Apr 2006
    Minnesota eh?
    86 325es
    People are not good at figuring out driveshaft stuff. I would recommend running down a bolt in option for that.
  5. #105
    Mar 2012
    Renton, Wa
    98 m3
    Yeah I’ll probably end up doing that. I researched building carbon shafts years back.. not much clearance so I might have to finally do it.
    1989 535i - sold
  6. #106
    Vancouver, B.C., Canada
    '97 M3
    The euro 6-speed DS is 53.82”. I measured my 420G to 210 diff to be 53.5 and had it shortened to that.. Maybe the CV could yaw up the difference in length
  7. #107
    Mar 2013
    Upstate NY
    M3
    That would be awesome, only problem is guibo bolt patern difference, i'm sure there's a solution(time and money). I'd love to see a guibo tri-bolt adapter to standerd domestic u-joint 3" chromoly or what ever, same to 6 bolt cv and 4 bolt u-joint diffs. Not 100% sure on options for this.
  8. #108
    '97 M3
    I’ve got a DSS one piece so all I’d probably need is a new forward adapter.
  9. #109
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    And some shortening?
  10. #110
    Mar 2012
    Renton, Wa
    98 m3
    Recent developments include indirectly bringing DSS onboard. Complete driveline solutions will be available for this trans and 188/210mm rear ends. More information on this in a few days as we have some pricing and better info.
    I set up the driveline to be about 0.25* high so once weight is on the mounts the driveline operating angle will be between 0.0-0.25*. Transmission brace will be out for quotes Monday.
    Shift linkages are already quoted and prototypes are on the way.
    Things are moving.
    1989 535i - sold
  11. #111
    Mar 2012
    Renton, Wa
    98 m3
    I wrapped up all the parts and got them all out for quotes. Expecting to have everything here 5/14/18.
    Parts quoted or in production:
    -Selector Rod (DSSR)
    -Adapter Ring
    -Trans Brace
    -Shifter carrier for oem style shift rods
    -Clutch Kit
    On some other good news the bmw e92 328Xi Driveshaft (26107573482). These are very common driveshafts found for 75-100$. You only need the front half, which you pair with your oem e36 rear half and everything is spot on. This reduces the entry threshold for everyone a bit I hope.
    I will be using this shaft combo for the testing of this kit, DSS will be producing a 1 piece shaft for the kit also (Still waiting on pricing) for those of you who will be looking for it.
    I'm hoping to have my clutch this week for testing.
    1989 535i - sold
  12. #112
    Boston, MA
    E36 M3 Turbo
    Moist
    Sent from my SM-G930P using Tapatalk
    97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
  13. #113
    Mar 2013
    Upstate NY
    M3
    Cool, OEM driveshaft is great for people that just want a 6 speed (me).
  14. #114
    Boston, MA
    E36 M3 Turbo
    For what it's worth - Just ordered up a used 6spd MT from an 08 335i w/ 85k for $350 and an 08 328xi AT rear driveshaft for $75. These are all readily available and inexpensive
    I can't wait for this
  15. #115
    Mar 2012
    Renton, Wa
    98 m3
    I just had two people ask so I’ll clarify, the 5/14 date is the potential ship date for parts to you guys.
    1989 535i - sold
  16. #116
    Mar 2003
    Hell Hole, NC
    325i
    Very exciting for e36 platform.
  17. #117
    Under a roof
    507whp 318i
    Quote Originally Posted by SCapelo View Post
    Isn’t there a specific model number that as important here. Or do all n54 trans work fine?
  18. #118
    Vancouver, BC Ca
    1993 325is
    Any of you guys looking to sell your ZF 5 speed E36 4 bolt (maybe 6 bolt) driveshaft, I’m in the market. No twisted up shit please.
  19. #119
    Boston, MA
    E36 M3 Turbo
    Quote Originally Posted by bavdrftr318 View Post
    From what I understand a white label trans is what Zack is using for the mock up currently.
    GS6-53BZ
  20. #120
    Royalest of Oaks
    Mazda 3
    Dang. Will be on the edge of my seat for the kit pricing!
  21. #121
    Feb 2014
    Caboolture, Q, Australia
    E39 535i
    Now of only we can make this work on the V8s...
  22. #122
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by StRaNgEdAyS View Post
    Yeah I could make a kit.
    1989 535i - sold
  23. #123
    Mar 2003
    NC
    CES Stage 3 Turbo M3
    Quote Originally Posted by vollosso View Post
    This is really awesome work! And we want to thank Zach for allowing us to include some additional Driveshaft options for your 355 trans swap kit.
    We are on the list for one of his conversion kits to put in our project widebody e36, which we hope to have ready in the next couple months that should be putting down some big power. I myself have always been a manual trans guy at heart, and it pleases me greatly to have a BMW trans swap conversion option that can hold 1000+whp reliably to use. Can't wait to test it out!
    We have been working with DSS to develop a shaft for our project widebody car with our 750 diff conversion that will handle the power, and work with the 335 trans swap Zach is making. We reached out to Zach since we thought it would be great to offer some DSS driveshaft options for those of you interested in a 1000hp driveshaft solution to work with this trans swap as well.
    As Zach mentioned... options would be for either 4 or 6 bolt OEM E36 188mm diffs, or for the 750 6 bolt 210mm diff conversions in either chromoly or carbon fiber.
    List pricing for the E36 335 Trans Swap Chromoly Shafts is $892.49 and Carbon Shafts is $1469.99
    We can offer Group Buy Pricing under 12 shafts for 15% off. 12 shafts and over Group Buy Pricing will be 25% off.
    Group Buy pricing for Chromoly Shafts at 15% off is $758.62
    12 shafts and over at 25% off is $669.37
    Group Buy pricing for Carbon Shafts at 15% off is $1249.50
    12 shafts and over at 25% off is $1102.50
    Shipping is $45.00 UPS ground
    DSS 335 swap CES Shaft Options are as follows....
    BMWSH2-CES3 E36 BMW with 335 Transmission to stock 6-Bolt Rear 3" Chromoly 1-Piece CV Driveshaft
    BMWSH2-CES3-C E36 BMW with 335 Transmission to stock 6-Bolt Rear 2.75" Carbon 1-Piece CV Driveshaft
    BMWSH2-CES4 E36 BMW with 335 Transmission and stock 4-bolt Differential 3" Chromoly 1-Piece CV Driveshaft
    BMWSH2-CES4-C E36 BMW with 335 Transmission and stock 4-bolt Differential 2.75" Carbon 1-Piece CV Driveshaft
    BMWSH2-CES5 E36 BMW with 335 Transmission and 7-series (6-bolt) Differential 3" Chromoly 1-Piece CV Driveshaft
    BMWSH2-CES5-C E36 BMW with 335 Transmission and 7-series (6-bolt) Differential 2.75" Carbon 1-Piece CV
    We would be happy to start a list and update it from our end, and have customers PM us so we do not clutter this thread, or However Zach would like to handle this part of the group buy.... These shafts are made to order and are not something that is on the shelf, so the quicker we can fulfill the group buy for these, the quicker we can place the order and get them going. Maybe a cut off date for the DSS group buy would be advisable so we do not delay placing the order for those that get on the list and are waiting.
    The CES Motorsport Team
  24. #124
    Mar 2012
    Renton, Wa
    98 m3
    Hey John,
    Appreciate, you taking up the driveshaft, and looking forward to seeing you trying to break this setup :wink
    Just finished up a little dust shield to complete the kit:
    Everyone, I will be releasing finalized pricing for everything tomorrow. I am considering starting a smaller group buy to kick things off.
    As of now the kit will include the following:
    • 6061 CNC Adapter Ring
    • 20Ga Stainless Laser Cut Dust shield
    • Laser cut, CNC Bent, Powder Coated Steel Transmission brace
    • Clutch kit (in your selection of disks)
      • Aluminum Flywheel
      • TOB
      • Necessary Hardware
    • Adapter ring bolt kit
    • Transmission bolt kit
    • Dowel sleeves
    • Stainless Dual Shear Selector rod (DSSR)
      • Selector rod bolt kit
    • Stainless Pivot Pin
    • Instructions on install with torque values
    Additional Items not included in the base kit that you may need:
    • Shift Carrier for OEM style shifters
      • You can alternately run a chassis mount shifter (CAE, IRP, RTD, AKG, Etc.)
    • CES One Piece Driveshaft Options Listed above
    The OEM Part numbers that will be used with these kits (Please check Linked REALOEM.COM with the interchange numbers)
    Transmission: 23007571423
    Driveshaft: 26107573482
    Guibo:
    26117610061
    1989 535i - sold
  25. #125
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Looking forward to this!
  1. The Official Auto-to-Manual Transmission Swap Thread
    By TheBestCow in forum 1991 - 1999 (E36)
    Last Post: 12-20-2023, 09:07 PM
  2. Manual Transmission/Rear Differential Fluid Swap
    By Johno in forum 1992 - 1999 M3 (E36)
    Last Post: 04-28-2018, 06:54 AM
  3. Replies: 30
    Last Post: 12-15-2016, 01:15 PM
  4. WTB: e30 manual transmission crossmember for swap
    By r4esh in forum BMW Parts Wanted
    Last Post: 01-06-2010, 10:52 AM
  5. Wanted: auto to manual transmission tranny swap parts
    By molszews in forum BMW Parts Wanted
    Last Post: 07-14-2005, 08:23 PM
