Results 1 to 25 of 29
Thread: German HP Vs any other HP
    Jun 2003
    U.A.E - Dubai
    E34 540iM - 93 4.0 Wrangler
    I've heard that the German HP is more than any other HP is that correct ?
    In other word if we have a german car and any other car with the same HP let's say 200 Hp ,, the German car will win is that correct ?
    thanx
    E34 540i Manual
    Eibakh Pro Kit | Blistein Shocks | EAT Chip | Racing Dynamics Front Stressbar | Racing Dynamics Swaybar Kit | 850cis Front Brake Kit | Zimmerman Cross-Drilled Brake Rotors All Arround | Hawk Street And Racing Brake Pads |Angel Eyes | 8000k HID Xenon Kit All Arround | Plasma Coils | JB Racing Lightweight Aluminum Flywheel
    SOLD!! E38 740il
    Searching for E39 M5 .......
    Irving TX/El Salvador
    M3,318is,1600,1802,520
    "HP" = horse power its just a measurement
    maybe what you heard its different...like "specifications" on some models than others....
    for example...german cars have more horsepower than others thats why it make them faster
    but german horse power compared to american, japanesse horse power ARE THE SAME!!! like i said its just a measurement of power!!
    Dec 2003
    Phoenix, AZ
    Stg 2+ Audi S5
    Quote Originally Posted by Francisco View Post
    Sarcasm pwns you.
    May 2005
    Johnston, RI
    2003 330i, 1999 328i (RIP)
    No.
    http://home.att.net/~numericana/answer/units.htm#hp
    The horsepower and the watt are both units of power; there's just a conversion factor between them. The way power is delivered (voltage, etc.) is irrelevant.
    A horsepower (hp) is about 745.7 watts (W), but many metric countries use another closely related unit [best abbreviated "ch"] which is nearly 735.5 W.
    The horsepower unit (hp) was originally defined by James Watt (1736-1819) as exactly equal to 550 ft-lbf per second (lbf = "pound-force", see below). Since January 1, 1959, the foot and the pound have been defined in metric terms (1 ft = 0.3048 m and 1 lb = 0.45359237 kg, both exactly). Furthermore, since the third CGPM of 1901, the standard (or conventional) acceleration of gravity has been defined as exactly equal to 9.80665 m/s2, which is thus the "conversion factor" to use to transform units of mass (like the pound, lb) into their common namesakes as units of force (pound-force, lbf): 1 lbf is (0.45359237)(9.80665), or 4.4482216152605 N exactly. Multiply this by the length corresponding to 550 ft (exactly 167.64 m) and you have the equivalence of a horsepower in watts (since a watt "W" is simply a meter-newton per second), namely 1 hp = 745.69987158227022 W exactly. There's (almost) no need to say that everybody usually rounds this up in the most obvious way: 1 hp » 745.7 W.
    In countries where the metric system has been around for a while, the horsepower (ch) is a 1.37% smaller unit, called Pferdestärke (PS) in German, paardekracht (pk) in Dutch, hästkraft (hk) in Swedish, caballo de vapor (CV) in Spanish, cavalo-vapor in Portuguese, cavalli vapore in Italian...
    The French call it cheval-vapeur (ch) or simply cheval (plural is chevaux). This "metric" horsepower (ch) is defined as 75 kgf-m/s, which engineers used to abbreviate as 75 kgm/s, using the obsolete symbol kgm for a "technical" unit of energy called kilogrammetre or kilogram-meter and worth 9.80665 J. A metric horsepower (ch) is thus (75)(9.80665), or exactly 735.49875 W.
    Dec 2003
    Phoenix, AZ
    Stg 2+ Audi S5
    Quote Originally Posted by djmatty View Post
    Informative post, but I still think you are missing the OP's tangent.
    Mar 2002
    NJ
    Ferrari 360
    german car manufacturers tend to be conservative with their numbers. Japan also recently revised the way they rate hp since a lot of their higher hp cars weren't living up to expectations.
    2000 Ferrari 360
    2004 Yamaha R1
    2007 Porsche 911 C2S Cabrio
    2017 VW Jetta (DD)
    1995 M3 (SOLD HELP ME FIND IT TO REBUY)
    1998 740IL (Sold)
    2003 x5 4.6is (Sold)
    Jun 2003
    U.A.E - Dubai
    that is what I've heard but not that clearly here it is more info.
    thanx alot
    E34 540i Manual
    SOLD!! E38 740il
    Malibu, CA
    '08 335i, '89 325i
    People say German ponies are more pwoerful than others becuase theyre underrated, while most of the world is overrated.
    Two best examples are probably the 335 and the Rx8
    The 335 is advertised as 300hp, it putting out around 330hp on the dynos
    The Rx8 manual was advertised aroudn 230hp, its only hitting around 200hp on dynos
    Germans tend to be conservative so they dont cut into their own sales. I think with euro companies, they offer many different types of engines in the same kind of car, so the dont want 335 sales cutting into M3 sales, etc etc
    I dont see as many jap brands offering different engines in the same platform, so they tend to overrate their power because often times the car only has one engine available for it
    SD
    1997 BMW 540i/6
    this thread makes my head hurt
    May 2005
    Johnston, RI
    Quote Originally Posted by brianahlers View Post
    Someone from the UAE.......were you expecting perfect English?
    May 2005
    Zephyrhills, Fl
    outside the fellowship
    supercharged cobalts and srt-4s are underrated...it has nothing to do with nationality, only the manufacturers interests(insurance, sales, etc)
    IIRC the "PS" rating is not even in use anymore. Only kW and hp are.
    bacon? bacon...
    Jun 2003
    2002 M5
    Quote Originally Posted by eurocar328 View Post
    Click here for link
    Quote Originally Posted by Automotive Mag Dyno
    The results? 275 hp and 300 lb-ft of torque at the rear wheels...
    2002 M5 Chiaretto Red/Caramel extended leather
    Jun 2003
    2002 M5
    Quote Originally Posted by Der Abt View Post
    Learn the difference between wheel hp and flywheel hp before posting
    275rwhp = more than 300hp to the flywheel
    BMW claims 300hp at the flywheel.
    I know the difference between wheel HP and flywheel HP. Thank you very much.
    Did you even read his original post?
    So they dynoed the 335 at 275HP on the dyno. RX8 at 200HP on the dyno. Right?
    So, unless 200HP is a calculated HP number, the correct way should be...
    'The 335 is advertised as 300HP, the calculated dyno HP was over 300HP.
    The RX8 manual was advertised around 230HP, the calculated HP on a dyno was around 230HP.'
    May 2005
    Zephyrhills, Fl
    The 335i is advertised at 300hp (flywheel), yet most owners have seen 330hp (flywheel) on a dyno = underrated
    they don't see 330 flywheel hp...they see 275whp and adjust it to flywheel hp which is in the area of 330 or so[/technicality]
    bacon? bacon...
    Jun 2003
    2002 M5
    The RX8 was advertised at 230hp (flywheel), yet it only produced 200hp (flywheel) on a dyno = overrated
    See, that's where it confused me. I did not know the RX8 dynoed at 200HP flywheel HP. Thought he meant 200 rear wheel HP.
    Figured 200 rear wheel HP = 230 flywheel HP.
    Oh well...
    Dec 2003
    Phoenix, AZ
    Stg 2+ Audi S5
    Quote Originally Posted by Mohamed 525i View Post
    thanx alot
    You were being serious?
    I guess it's my fault, as I didn't see where you're from, and it's likely that English isn't your first language.
    It sounded like you were being sarcastic about the value of "German horsepower", considering all the fantastical kills that have been written in Kill Stories over the years.
    To some of you:
    I guess Germans made the 2003-2004 SVT Cobra too, considering they were rated at 390 crank HP, and were dyno'ing close to 380 WHP in some cases. Not to mention the LS1 Camaro - rated at "325 crank HP", yet were dyno'ing up to 305 WHP in some cases.
    Germans must have also made the new Z06: SAE Rated at 505 crank HP, yet are putting up to 465 HP to the wheels. At a conservative estimate of 15% drivetrain loss, that's more than an estimated 540 crank HP.
    Mar 2006
    Great Lakes
    BMW
    I'm not trying to make a case that German HP is any different from the HP in the rest of the world...but!.....
    A 260HP G35 was good for 0 - 60 ~ 6.2. A 330i from the same year had 225HP and ran the same 0 - 60. I'm not sure about the weight differences b/w the two cars, but I can't see it being much. I'm sure a G35 has a power-to-weight ratio advantage, but it doesn't show in acceleration times.
    Quarter-mile times and trap speeds are a similar draw. I'd say German powertrains are more efficient maybe
    Malibu, CA
    '08 335i, '89 325i
    Sorry, 330hp est. to engine, didnt mean to type dyno
    basically, the 335 is 330 hp vs the 300 advertised
    the Rx8 is closer to 200hp than the 230 sumthing advertised
    I didnt have the whp measurements, so i just used bhp measurements. Sorry for confusion.
    It might also have to do with taxing. I know you are taxed on engine size in europe, maybe they take hp figures into account so thats why some underrate the power produced
    SD
    1997 BMW 540i/6
    i was referring to the misconception that german cars somehow have more potent horsepower based on the numbers than others.
    May 2005
    Johnston, RI
    I'm pretty sure that's not the OP's original thoughts.
    SD
    1997 BMW 540i/6
    you don't get it obviously, but whatever
    May 2005
    Johnston, RI
    You're the one who obviously doesn't...
    California BAY AREA
    e30 M3, 335d
    German car with the same hp are faster because American cars measure their hp at the shift knob, and Japanese cars measure their hp at the stickers, so after you calculate the power loss through the idiot behind the wheel, you win!
    around
    three twenty slow, a
    E-fight!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    -Serge
    Oct 2002
    Cold Snowy North
    Misc.
    Quote Originally Posted by prash View Post
    You also have to take into account gearing in both 'height' and number.
