Results 1 to 16 of 16
Thread: A good source for metric fasteners and similar things
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    BelMetric.com
    http://www.belmetric.com/
    May 2005
    Red White and Blue
    82 E21
    Great company with a great selection and excellent service. I have used them for many items on all of my cars, they also have a broad selection of fuel hose, vacuum line, etc in addition to hardware.
    MJ
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    I have bought items from them as well.
    Randy
    May 2015
    Chicago, IL,United States
    1977 BMW 320i
    Thanks for the info, looks like they have a lot of stuff for the under-hood fuel lines that are hard to find.
    Houston, Tx
    '78 320i
    They dont have head/exhaust stud bolts. nobody does unless you feel rich and wanna pay $5 per stud on an ECS or FCP or BavAuto.
    Otherwise they are my source for pretty much every bolt Im replacing. Great site.
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    What size is needed for the exhaust studs?
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    Pinch nuts
    M6x1.0, M6, 6mm Metric Conical Hex Lock Nut, Hardened
    Material: Class 10 Hardened Steel
    Also known as Stover nut, all metal lock nut, all metal prevailing torque nut, all metal hexagon high nut, self locking nut, cone lock nut
    I'm going to get some of these lock nuts. Anyone use these, as opposed to the nylon lock nuts? I have a question. Do they damage the bolt you use them on? I know these nuts are one time use only, but do they make the bolt one time use only also?
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    Looks like exhaust studs are M8 by 28mm? http://www.realoem.com/bmw/enUS/show...diagId=11_0234
    Jul 2010
    San Jose, California
    E21 320i, E30 325i
    Quote Originally Posted by jaredmac11 View Post
    Cheaper than $5 each :p
    http://www.iemotorsport.com/bmw/item/manifoldstuds.html
    http://www.iemotorsport.com/bmw/item/IntStNt.html
    '81 E21 320i / '90 E30 325i / '̶9̶2̶ ̶E̶3̶4̶ ̶5̶2̶5̶i̶t (sold) / '15 Toyota XW30 / '̶̶8̶0̶ ̶E̶2̶1̶ ̶3̶2̶0̶i̶A̶ (sold)
    Houston, Tx
    '78 320i
    Great find. I was shopping for the M42, M7x45. I was able to clean them up well enough. I was considering these, but seemed too short:
    https://www.belmetric.com/7mm-metric...ck-p-5090.html
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    7mm is an odd size. eBay has M7 by 39mm long if that would work. 8 of them for $22 shipped is $2.75 each. or 6 for $17.
    http://www.ebay.com/itm/7mm-Exhaust-.../162364699496?
    7mm Exhaust Manifold Stud M7x1.00x39 for BMW - Pack of 8 Studs, $21.99
    Jun 2016
    Austin, TX
    1978 323i
    How about a source for these little "hollow washer"s they use on the black oval interior screws (which you can get at Home Depot)
    bmw part # 5145180497
    Cheapest price I've found is $3 each, if you buy 50!
    https://www.ecstuning.com/b-genuine-...51451804974kt/
    https://www.amazon.com/BMW-Genuine-H.../dp/B06Y4YX51R
    Sep 2015
    Massachusetts
    E21 327i, E46 325iT/5
    Quote Originally Posted by okieflats View Post
    There are some stover or elliptical lock nuts that are reusable multiple times. I think the BMW elliptical nuts are since they are grade 8 and zinc coated. They are great for high temp or high vibration spots. But they can strip coatings from the stud.
    Another Bel-Metric fan here too! So many engineering and racing teams use them. Tony in sales is/was a BMW fan. I almost bought a E30 323i from him.
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    I am going to convert my Alfa oil pan from bolts to studs, and use the stover locknuts on the studs to hold the pan on. This is because oil leaks out through the bolt holes. With studs you will be able to squirt some silicone sealer in the hole before putting the washer and locknut on to hopefully prevent the leaks. Would not want to use a regular nut for that as it would probably come loose.
    Jun 2016
    Austin, TX
    1978 323i
    Those stover nuts are pretty grabby, they might twist your studs out!
    May 2005
    Red White and Blue
    82 E21
    Okie,
    In that application you might want to use Curil T on the threads rather than silicone since it stays flexible and doesn't really cure. I placed some on my exhaust studs where they entered the head to prevent seepage and it has worked well so far...though admittedly it is still a young build.
    MJ
  1. MoleculeBond is good stuff for worn leather and plastic
    By Croak in forum 1991 - 1999 (E36)
    Last Post: 07-21-2004, 08:13 AM
  2. Good Source for Cobra seats?
    By M Rob in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-06-2002, 01:42 AM
  3. Good source for e23 body panels?
    By gork in forum 1995 - 2001 (E38)
    Last Post: 09-23-2002, 12:01 AM
  4. Good source for H & R Coilovers?
    By Keith_M3-4 in forum Vendor Comments & Supporting Vendor Info
    Last Post: 04-22-2002, 01:38 PM
  5. Where is a good source for M3 sheetmetal?
    By RUFRDR in forum 1992 - 1999 M3 (E36)
    Last Post: 02-22-2002, 02:30 PM
