Results 1 to 9 of 9
Thread: Will Wilwood clear stock rim?
    Sep 2017
    Northeast
    2001 M Roadster
    I am looking to upgrade my brakes. Does anyone know if Wilwood Forged Narrow Superlite 6R Big Brake Front Brake Kit
    https://www.summitracing.com/parts/wil-140-8797-d
    Clear stock rims?
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
    Which stock rims? What size?
    Sep 2017
    Northeast
    2001 M Roadster
    Sorry, don't mean to sound like a tool, but I just literally got the car (2001 z3m roadster). Not in front of the car right now to confirm. I will check and update when I am at home.
    That said, I am reading some posts and general consensus is that short of looks, there is no performance benefit with Wilwood bbk. I guess its a mute point now... thanks anyways
    Feb 2014
    Galt,CA
    2002 M Coupe
    He's got an M Roadster, so the stock rims are 17x7.5 front and 17x9 rear Roadstars. I can't find my notes on offsets, but I'm sure someone has them.
    Marty
    Oct 2003
    Seattle
    99 M3
    I think the fronts are ET41, no?
    Looking at realism.com, Roadstars are front ET41 and rears are ET8.
    LOL!!! ET8, is that possible!!??!
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Yes. ET8, and many throw a 15mm spacer behind them for an effective ET of -7.
    A little story. Many moons ago on a different forum (listserv, actually), someone figured out that you could bolt the 6 piston GSXR calipers onto the RF900 forks, and they RAVED about how much better they were. Okay, sounds good. I call up a friend that is in the bike salvage business and procure a pair of almost new GSXR calipers. The first thing I notice is they don't just bolt on. Well they do, if you don't mind them being offset to the rotor by 1.5mm. So I made some spacers to properly mount the calipers. The second thing I noticed is the stopping power did not change. Not at all. Me, being me, starting thinking and measuring.
    The master cylinder did not change. Therefore logic would say that the total piston needs to remain the same. Measuring the pistons confirmed, total area was the same for the 4 pot and 6 pot. No gain or loss in mechanical leverage, or apply pressure here.
    The pads, after much measuring were nearly the same surface area. And the same material. No direct advantage there. However the pads were longer and narrower; less swept rotor area, but more concentrated to the outside. Likely a net loss and a net gain mostly offsetting. Beyond my skills to analyze precisely.
    Thus, there should be no real gain. And I did not notice any gain. When I reported the findings and supporting maths back to the list, it was met with much hate and disbelief. S'okay, I was used to it then, and I'm used to it now.
    OP, have you actually DRIVEN this car yet? The stock brakes with the correct pads are pretty good Stainless lines will bring the feel right up. You have lots of places that need funds, quit trying to find more without real world info.
    /.randy
    Sep 2017
    Northeast
    2001 M Roadster
    I wouldn't call it driving, but yes, I drove it around few days ago. Up and down driveway... lol. Not I put on about 300 miles last Sunday. Picked up hardtop from someone on Craig's list. We installed it on the spot. It brakes pretty good. But upon inspection looks like both pads and rotors probably got another 5k on it. So I got time, because I am not planning on taking it on the track until next spring. So I am just staring to do research. Hence all the redundant questions that all the noobs are asking.
    SF Bay Area, CA
    BMWs: 1; MINIs: 1
    Come on Randy, just admit it ... the stock brakes suck because they are STOCK! And, uh, they look kinda small. And, uh, they only have one piston, and how can that even work? Won’t only one side of the brake even clamp? Need better. Because race car backwards is race car.
    I like the unicorns.
    '99 Z3 Coupe - Jet Black/Black (1-of-114)
    '99 M Coupe - Estoril Blue/Black (1-of-82)
    '03 540iT - Sterling Gray/Black (1-of-24)
    '16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
    Ellay, CA
    BMW Z3 3.0 VF SC'd
    Quote Originally Posted by JoshS View Post
    ...it's actually 'rac ecar'. Which is a type of Norwegian goat cheese used in the making of condoms for whales.
    "You don't win silver....you lose gold."
  1. Snow setup. Will 16" clear stock brakes?
    By AbaDaShoe in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-14-2010, 06:24 PM
  2. What rims will fit on stock suspension?
    By SEWELLM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-07-2005, 01:27 PM
  3. will M coupe stock 17 rims fit E46 coupe?
    By Reno in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-29-2005, 01:21 PM
  4. Will E46 M3 Stock Staggered 18" rims fit a 330i
    By M3Jokster in forum 1999 - 2006 (E46)
    Last Post: 07-03-2003, 03:20 PM
  5. Will 205/50-15's fit on my stock rimmed E30 M3?
    By phae1017 in forum 1987 - 1991 M3 (E30)
    Last Post: 04-13-2003, 04:39 PM
