i know theres tons of threads out there about this but i just had to ask myself..
ok so after driving my car(1996 e36 328is) and riding in my friends car(2002 e46 330i sprt pkg.) ive concluded i love his suspension, like its so smooth for daily driving and it corners like its on rails, and just all around feels so much tighter..
so i want your suggestions of what the best way to make my e36 handle better, similar to the e46 330i sport package maybe better? but i dont want a really hard ride or to dump a TON of money into it..
i heard the x-brace makes a big difference?
thanks!!
are you just riding on the stock suspension? how many miles? how many miles are on the E46?
an x-brace will tighten things up a little in the front but if the the looseness is being caused by on the wear and tear items in the suspension then I'd get those replaced first, then get the x-brace.
--DrDubHold on let me get my laptop and read this on the toilet.
the e46 is just a newer car. i have kinds oh cricks and sounds in my car. i just give up
dude, go to understeer.com they seem to have lowest prices for suspensions, im about to order the koni yellows and h&r race springs, that setup whether u get the sport or race springs will run you about $750 which is one of the stiffest setups available, there is also the uuc Sachs setup, or the h&r cup kit for about $700. If you do shocks, struts, springs, (all included in those prices) you should be real swell, but you should check your bushings while your in there, ur getting up there in those miles, so just gotta check that stuff. Suspension is easily diy , specially with a friend, very easy accessible bolts and such, just need some sockets, spring compressor, and which ever method to get the basterd bolt out of the top of the strut
I don't think its too soft, with 17's my car handles quite nice, allthough its been a while since I have driven an M3(either year) Rob's is just old as crap. Can you use a vice as a spring compressor? or is it one of those things you need to buy/rent from autozone. And btw, my car has 18K
You rent them.
You would risk serious injury by doing it that way. Rent or buy a spring compressor. They're not that expensive.Originally Posted by Racerhoze
Yeah, getting hit in the face with a spring wouldn't be the most fun thing I can think of to doOriginally Posted by ElSupremo
SOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
you wanna make it ride WORSE???
helloladies
OOOOH ouch But 120K on stock suspension doesnt make for the best handling or ride quality, neither do 16's wrapped with mega 205'sOriginally Posted by LagunaSecaBlue
my tires RUL
so should i just replace all the suspension components with the e36 sport suspension(does my car already have this just old?), or what about the e36 m3 suspension(is this a good idea?) where would i get those from though?.. i dont want to lower my car very much, and im not gonna be like auto-xing with it i just want it a little more stiff not like the STIFFEST out there..
OEM M3 front struts w/ Koni's
OEM M3 springs
Check out http://www.understeer.com and snag yourself the $99 kit under suspension.
That would be an inexpensive upgrade!
But also you could have new springs (Vogtland) and new Koni shocks for:
http://www.ajusa.com/cgi-bin/vogtland/details?part_num=9661007&part_name_safe=<nobr&ajr_ skey=6a3e3da1034aebe2f7a1b17b97223970
Remember if you want to go M3 way you have to snag a set of M3 front strut housings as well as the M3 hats / plates.
You can easily find the housings online. From someone that upgraded to coilovers or upgraded to bilstiens, etc.
As for the hats / plates you can simply snag those from the dealer, they are cheap.
Basically we have the same car and this is the setup I am in the process of doing. If I go that kit route I will have a set of OEM M3 springs of a '99 with 7k on them if you want.
dont be stupid and dont listen to these ppls dumb ideas, get konis+ eibach pro kit or h&r sport springs. You wont be dissapointed. Throw in the x-brace later on if you still want some added handeling.
and the winner for today's most positive and uplifting post is amdspitfire. You are like a ray of sunshine with your words man....dont be stupid and dont listen to these ppls dumb ideas
if this is turning into a what suspension should i get thread, then do some searches right? odds are those are not the only suspension parts that need replacing, ie RTABs etc. might as well start looking at RSMs too while you do the suspension swap.
Originally Posted by amdspitfire
Glad your wits could be added to this thread! Because after all whatever you say goes right?
I mean whatever you suggest is the best way, no?
Thanks again!
Don't do the M3 suspension if you want to keep a smooth ride. M3 is much more hard core than standard E36. I had a 93 E36 and now have a 99 M3, so I'm qualified to say that. If you want to keep the smooth ride(more or less) but firm it up a little and improve handling, get a set of Bilsteins or Konis, keep the stock springs, replace suspension bushings as needed, and get some 16" or 17" wheels and suitable tires. If you want to stiffen the roll, try some new stiffer sway bars also. My 93 with 16" sport wheels, 225/50x16 performance tires, Bilsteins, shock mounts, was much improved over stock and still comfortable. Not nearly an M3, but not as hardcore either.
MikeG
^^ thanks mgambini that helps a lot, i think im going to take your advice and get better tires first then ill get a set of konis and work my way up to different springs if i decide i want it a little more firm, the stiffer sway bars are a great idea too, thanks!! that was the info i was curious about.
