I don't want to get into a discussion of oil brands. What oil weight are you using in your forced induction engine?
I have an E36 M3 with stage II AA Twinscrew supercharger daily driver, no track time. I am thinking either 0w-40 or 5w-50...the 0w-40 is what is recommended for the stock engine, is that sufficient or should a F/I engine use different weight oil than a N/A engine?
Looking forward to what others have to say.
Sent from my DROID4 using Tapatalk
Current: 2011 X3 35i M-Sport, Deep Sea Blue Metallic, Oyster Napa interior, Afe intake, RaceChip Ultimate.
Past: 1998 M3 sedan, Cosmos Schwartz Metallic, Black interior, Euro 6-speed, AA Stage II TwinScrew supercharger, and a bunch of other mods.
M1 0-40 euro spec
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
1996 332IS
Built 3.2
How many miles are on your motor and what are the current temps (highs and lows)?
Ambient temps that is..
40w under 40deg. 50 over it. Adjust your lower number to your average LOWEST temp. In EC, MD, I'd run 10-40 in winter/late fall, 15-50 late spring/early fall. Just take it easy until the oil warms up....thoroughly.
Don
I would go with the lightest weight oil that gets you good oil pressure under your operating conditions.
Liqui Moly 10w-60
Liqui 5W-40 here... been using it on all my cars for the better part of 10 years now
m1 15w50 for summer
If you are running a proper thermostat controlled oil cooler, the ambient temp should not play a significant role in choosing the hot weight. But since I don't have a cooler, I've been running Liquimoly 10W60.
/.randy
0w-delicious
bacon fat oil
Another Liqui Moly 10w-60 here..
the lighter weights oil's just don't seem to cut it.
I run 5w40 rotella t6
OLD
E30
636whp
1/4 mile: 10.91@144.38
http://www.youtube.com/watch?v=L_f7fUVqblI
NEW BUILD
335d
520whp
635wtq
120.51mph trap speed
Nope, no cooler as yet. The way my car gets used, the bigger problem is cold oil. By the time it's up to temp, I'm at my destination. And the bit of hooning it does see is short bursts. For *my* usage, I"ve been watching for an OE oil->water cooler I can adapt to my appllcation.
/.randy
Thanks for the advice all. I am going to go with M1 0w-40 euro spec for this oil change and see how it does. Will update if it doesnt work out.
10-60 here in UK conditions
