tl;dr
go drive more
Soo SLR for rear spring what's your recommendation?
with low power and just learning the ropes, start out stiff. When you add power, tire, and angle, go softer.
mike has a bajillion horsepower and he runs 890lb/in out back which is 16kg/mm.
i ask because i used to run like 16k rear and was ok but to stiff, you can slide the car more easily and if you let go the gas it will keep side ways but not much traction and less smoke.
recently i have changed to 9k and the grip is great and the smoke two, BUT the car squats and tries to get straight soo no bueno (for me) maybe with more power but im still m5x with mods (for now) what maybe! 200hp, going for some 12k (672lbs) or something in between to balance things up.
you know you wanna come out to the 626 event on the 12th and give me a ride
Who uses those rates? The only time i've seen anyone use an even spring rate is this e30. A few people have ordered 12/10k from me for e36 recently but i've never seen a company offer it that way.
In any case, i agree about the rear needing higher rates unless you go for a full coilover conversion
that car is bonkers and your driving is pretty top shelf as well. Sub'd
I explained that exactly how you've typed it, it's a simple concept really but they said that they liked the rear grip. I suspect one random guy said it was awesome and it made it's way through the grapevine. All were from california too.
I've never tried such a high difference in rates in the rear, i like to go with a good 100 some odd pound difference or 2k.
My most popular set up is 15/16-17k or 16/18k. You just weren't looking hard enough google the name in my sig. I don't use those specs for drift though, those are for a stance set up.
My BC's are 10k/14k and revalved.
I run a shock spring setup not a full coilover, bought them of Ebay Hiper coilover spring (900lbs) so maybe 16k?, they are 2.25" inside diameter, so they fit the center hump on the spring base, i trimmed for height cut just like half turn almost nothing just to make it flush.
http://www.ebay.com/itm/Hyperco-Coil-Over-Spring-2-5-ID-6in-900lbs-HYP186B0900-/380535806522?pt=Motors_Car_Truck_Parts_Accessories &hash=item5899b39a3a&vxp=mtr
NOte: i bought them of graigslist for 70dlls used for the pair but are the same as the link, worked great! going for 12k now.
subscribed
Beautiful cage/fab work. Q: Any reason you opted for your pedal assembly instead of a floor mounted pedal box?
awesome car, awesome drift skills, awesome thread.. subscribed!
Update!
chopped off the front of the frame rails to make room for our bash bar. Finished up the steering shaft mods
made a floor board and cut the steering shaft to length
chopped out the trunk area
its starting to come together!
WOOHOO!! thanks for posting, its so sick to see it all come together.
looking better and better
Jeezus.. O_0
subbed.
Dont know if you mentioned it already but what are your plans for the roof? fiberglass, carbon fiber, etc?
I know its unpractical in a street setting but in a racing setting could you leave it completely open? It would be just like a convertible right.
Looking good! I have some new ideas
235/40/17 front, 225/40/17 rear, megan euro street coils 7k/F 9k/R, -2 degrees camber front(max on coilover) 6 degrees of caster front, oem sway bars, welded diff, all stock control arms in rear....
Btw car is coming together awesomely, I'm starting a similar build except with a 2jz.
Speed>Elegance
