Page 7 of 17 FirstFirst 12345678910111213141516 ... LastLast
Results 151 to 175 of 409
Thread: 1997 M3 4 Door with LS/T56
  1. #151
    Mar 2018
    Arizona
    1998 328I
    Love your build so far, thank you for all the info!! Will be starting mine soon as my car is back from the paint shop. Question on the steering column, is there any change in steering quality or feel going to that telescopic column you are using?
  2. #152
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Ruly: We haven't progressed as far as we would have liked. But it appears we have a real start date in 2 weeks.
    Steering shaft: not so much the column...just a thinner shaft to gain extra room thru the headers. Believe it will be similar to OEM (understand and E46 shaft can also be used although don't believe it is thin as the one we will use). This is based on others experience...of course.
    Thanks.
  3. #153
    Mar 2018
    Arizona
    1998 328I
    Quote Originally Posted by Tim Mc View Post
    Thanks.
    Ok very interesting, I saved the parts and will give them a shot if i run into any clearance issues. Love seeing your progress
  4. #154
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Happen to find myself in Virginia where a fellow M3 swapper lives. Chris put a thread together on Grassroots Motorsports where I've been following. He was more than accommodating showing the car...goldmine if info considering his obvious success at not only a running example, but one that is a rocket!
    https://grassrootsmotorsports.com/fo.../124020/page1/
    Big kudos to his workmanship and exercising the 383 powered car. Certainly got my blood going...perfectly timed as we are about a week out from tear down of our own M3.
    Thanks Chris!
  5. #155
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Finally some more progress:
    Realized our modified truck windage tray wasn't worth it...when the oil pump pickup didn't fit...so another Summit order:
    [url=https://flic.kr/p/H4dapZ]
    [url=https://flic.kr/p/25BGhxs]
    Lift plate install...love all that aluminum!:
    [url=https://flic.kr/p/H4dbdx]
    Modifying the power steering pulley for easier access to the pump bolts (mod swiped from Chris):
    [url=https://flic.kr/p/JzyKVq]
    Installing the pulley:
    [url=https://flic.kr/p/JzyJWS]
    Some art...Chuck's SuperTube 1 7/8 header art:
    [url=https://flic.kr/p/23XkFfW]
  6. #156
    Mar 2004
    USA
    96 328is 6.0L
    This is a nice looking header. Curious to see the deiver's side.
  7. #157
    Mar 2018
    Arizona
    1998 328I
    Very nice headers!
    Are you planning on dropping in the block with headers on?
  8. #158
    Mar 2004
    USA
    96 328is 6.0L
    Quote Originally Posted by RulyLSX View Post
    Very nice headers!
    Usually you cannot put motor with headers already in place or it is extremely uncomfortable to do. They have to be out on afterwards.
  9. #159
    Houston, TX
    1997 M3 Sedan
    Looking good Tim. I’ll second the request for a shot of the DS header.
    Sent from my iPhone using Tapatalk Pro
  10. #160
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    More progress...
    Vibrant 3 inch merge into single 3.5 inch. Beautiful piece...we plan to run a single 3.5 inch pipe to the rear bumper with at least 1 muffler:
    [url=https://flic.kr/p/JJuLYb]
    Finally got the oil pump pick up installed with the correct windage tray and blue seal:
    [url=https://flic.kr/p/HdgmMD]
    Front cover torqued permanently:
    [url=https://flic.kr/p/HdgnAc]
    Driverside header temp installed:
    [url=https://flic.kr/p/25LLY9j]
    ...only one wire boot touches...likely due to the bulky OEM Delco boots. I may be even be able to just trim a portion off for clearance:
    [url=https://flic.kr/p/25LLYrJ]
    Chuck's header to mount puzzle...stunning work:
    [url=https://flic.kr/p/25LLXMh]
    And steering shaft clearance...look at the flange thickness - 1 7/8 header tube into 3 inch collectors:
    [url=https://flic.kr/p/Hdgo34]
  11. #161
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Progress...FEAD installed except the AC portion. That will wait until we have a running car:
    [url=https://flic.kr/p/25wEMYX]
    Engine in the air to fit the oil pan permanently:
    [url=https://flic.kr/p/26U9kti]
    Missing a bellhousing dowel pin and starter bolts. Another Summit order...
  12. #162
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Adding the clutch...LS7 flywheel:
    [url=https://flic.kr/p/26ZPazo]
    LS7 Disc:
    [url=https://flic.kr/p/274JmX8]
    LS7 Pressure Plate:
    [url=https://flic.kr/p/25GbEP2]
    Of course I installed the wrong pilot bearing...from an LS7...should be a small Camaro unit deeper in the crank due to the bellhousing height difference. So back to Autozone to get a pilot bearing puller to destroy my newly installed bearing. Amazon will deliver a GM one on Sunday...
    Did prep the car...final wash before entering the garage:
    [url=https://flic.kr/p/25GbTtF]
    Hopefully we will eliminate the 4 types of leaks currently marking my driveway:
    [url=https://flic.kr/p/24iZbiw]
    Unsure how much we will get done on Mother's Day weekend...
  13. #163
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Getting closer...awaiting the pilot bearing:
    [url=https://flic.kr/p/272xr9u]
    It has begun:
    [url=https://flic.kr/p/JXBiBq]
    Today's result...no assistant so...:
    [url=https://flic.kr/p/24kLg2d]
    Will attempt the engine removal tomorrow...
  14. #164
    Jul 2013
    FL Gulf Coast
    E36 - 1998 328iS - LS2
    Awesome!
  15. #165
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Today's lack of progress courtesy of the local airshow (loved the P-51's roar), stripped bolt, and stubborn radiator support factory spot welds.
    18 05 13 M3 Day 2
    The Camaro pilot bearing showed up...in the freezer for the night. Will attempt to mate the engine/trans tomorrow.
  16. #166
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Huge kudos to Tipsy for laying out the details of repositioning the ABS setup for hydraulics. Providing the following list:
    CNC-325 3/16 Nicopp x 25 feet
    BLU-8C Small Union
    BLU-10C Large Union
    BLF-39C Small 'b' nut
    BLF-48C Large 'b' nut
    Purchased from Advance Auto Parts for ~$68.
    We finally got a look at the ABS system upon removal of the air intake tract...looks like fun!
    Thanks Tipsy!
  17. #167
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Tonight was Boy Scout night...so limited to installing the pilot bearing...deep in the crank to make up for the 'short' Camaro bellhousing:
    [url=https://flic.kr/p/276KshJ]
    Even went so far as getting an Autozone bearing installer tool to ensure undamaged needle bearings - I've done that before!
  18. #168
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Today's progress...installing the transmission!
    Assistant bolting the LS7 assembly on:
    [url=https://flic.kr/p/24s4fUQ]
    Success! Easiest mating ever...nice when you are dealing with new parts:
    [url=https://flic.kr/p/27cH6S2]
  19. #169
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Today 'I' pulled the exhaust - incredibly heavy as one piece unit!:
    [url=https://flic.kr/p/HBb8HK]
    And driveshaft:
    [url=https://flic.kr/p/HBb8mx]
    My assistant was busy with finals preparations...better for it as I neglected to blast the bottom of the car before disassembly and the power steering leak was something fierce. What a mess...
  20. #170
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    All the ancillaries are disconnected. Tomorrow is the engine pull.
    Question: the various heat shields beneath the car...believe there are 3. All appear to be in good shape although covered in PS fluid/dirt. Do most retain these? They seem to be well constructed (made in Switzerland!)...but may interfere with custom exhaust.
    Thanks.
  21. #171
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Well highly successful day today. Became experienced at removing an engine from a BMW M3,
    Preparing:
    [url=https://flic.kr/p/27jDLZX]
    Pulling (darn steering shaft!):
    [url=https://flic.kr/p/24yYP9C]
    Assistant at work:
    [url=https://flic.kr/p/24yYPGS]
    Success!:
    [url=https://flic.kr/p/27jDPF8]
    Empty, but with 229,000 miles of dirty:
    [url=https://flic.kr/p/27fyzF9]
    Cleaned up real nice!:
    [url=https://flic.kr/p/24yYNFy]
    S52 for sale...and with luck will go home tomorrow to a new owner for $1100:
    [url=https://flic.kr/p/27jDMjV]
    VIN Tag at the rear of the cylinder head...this head (and likely engine) is original to the car - kind of cool:
    Is this normal for wiring and what exactly is the engine wiring harness?:
    [url=https://flic.kr/p/27jDLKt]
    Will I use any of it for a stand alone Holley HP EFI system?
    Thanks.
  22. #172
    Houston, TX
    1997 M3 Sedan
    The one for the driveshaft tunnel was trash so I removed it and have been running without it until now with no issues. I have a new replacement that’s going in when I have the exhaust mid-section remade and it’s going to need a little tweaking to fit near the GUIBO because that’s sitting further rearward with the T56. I think the heat shield for the fuel filter can go back on with no problem. The one for the passenger side that covers the rear control arm bushing might be in the way. I removed it on mine and snapped off the studs that hold it because I guess they were interfering but I don’t really remember.
  23. #173
    Jul 2013
    FL Gulf Coast
    My car was very low mile and super clean. I gave away the tunnel heat shields when I sold the exhaust, simply because my garage is small and I wanted to keep the clutter to a minimum. In retrospect, I realized most have been able to utilize the larger of the under-body heat shields with the swap. I've since regretted letting mine go because everything I've been able to find used is in much worse condition than those that I gave away.
    Keep what you have until you're sure that you won't use them
    At the every least, you're going to need the connections to the X20, X69, etc. Hang on to it all, until you're done.
    If you haven't already figured it out, the three relays on the fuse box (circled in red) that are under the fuse box cover are simply attached to the outside of the fuse box with little tabs that can be easily depressed which will allow the relays to be removed from the box without cutting any wires.
  24. #174
    Mar 2004
    USA
    96 328is 6.0L
    And you will need thick red power wires for fuse box, etc
  25. #175
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    All - very helpful.
    I will retain the heat shields as all are in good shape...although the big one is incredibly dirty. Great job for the assistant!
    I did manage to disconnect the entire engine compartment harness and definitely have questions on what I need to keep. As suggested - large power wire, possibly the diagnostics port (for ABS codes?), and it appears the ABS computer wires. There are two ECU's in the passenger side computer compartment - DME...not sure about the other one.
    The new owner did come and transaction made. I gave him several extra items - M3 exhaust, DME, and few odds and ends. Both a winner as I didn't care to spend time cutting up the exhaust - depositing in the trash one piece at a time. Without a pickup, some simple actions are challenging. We'd actually met during local autocrosses a few years ago so...
  1. E36 driver side alpine white M3 door with mirror
    By 600whp S4 in forum Exterior Lighting & Body Parts
    Last Post: 07-05-2012, 12:14 PM
  2. E46 FS: M3 Doors with Mirrors, Door Panels, Windows
    By rlddlr53 in forum Exterior Lighting & Body Parts
    Last Post: 05-23-2012, 10:34 AM
  3. 1997 M3 Sedan with Full Euro Conversion
    By simmons in forum 3 series & Z Series
    Last Post: 03-20-2008, 01:53 AM
  4. Does a 1997 M3 come with...
    By Julz69 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-24-2005, 03:06 PM
  5. F.s. 1997 m3 motor with trans.
    By MyTyphoon1993 in forum BMW Parts For Sale
    Last Post: 03-04-2004, 11:00 PM
