Page 1 of 6 123456 LastLast
Results 1 to 25 of 146
Thread: How to fix your broken seat belt guides.
    Dec 2005
    Sarasota, FL
    98 M Roadster
    Like many Z3 owners, my seat belt guides cracked and fell apart. I bought mine with both of these broken, thinking "No big deal, how much can a little part like that cost?". Well, I was right, they are pretty cheap. Unfortunately, they are cost a lot of time and energy on top of that.
    After a week or two of seeing these eye sores every time I got in the car, and having to fish the seat belt out from behind the seat, I decided it was time to make them right.
    Required tools:
    13mm socket
    16mm socket
    16mm combination wrench
    Large slotted screwdriver
    Small slotted screwdriver
    Needle-nose pliers
    Diagonal cutters
    Large towel(s)
    I. Remove the seat(s) that need to be worked on
    Removing the seat is not difficult, but can be a lot easier with a second set of hands to help you lift it out.
    WARNING: Do not put the key into the ignition with either of the 2 seats out of the car. If the airbag sensor connectors are disconnected when the ignition is turned on, the airbag light with come on. This cannot be reset without an airbag reset tool. The dealer will rake you over the coals for this (~$70, I think).
    A. Cover the door sill, center console, and anything else that you might bump into with large towels. This will help prevent collateral damage to your interior while you are wrestling the seat out of the car.
    B. Slide the seat back to expose the two nuts on the studs holding the front of the seat bracket.
    C. Using a 13mm socket, loosen and remove the nuts.
    D. Slide the seat all the way forward and fold the seat back forward.
    E. Using a 16mm socket, loosen and remove the two rear bolts.
    F. Using a 16mm combination wrench, remove the seat belt from it's mount on the seat.
    G. Disconnect the wiring harness under the seat. There are 4-5 connectors per seat. The driver side is the easiest of the two, as the seat heater connectors are in the rear and fairly easy to get to. The passenger seat is another story. The heater connectors are deep under the seat. Take your time with all of the connectors and never pull them apart by pulling on the wires. It helps to tip the seat forward while disconnecting. I was able to tip the seat forward by wedging my shoulders between the seat and the carpet behind it while I was disconnecting.
    H. This is where an extra set of hands comes in handy. Carefully lift the seat off of the front studs and out of the car. I found it to be easiest to do this with the seat back fully reclined. This can be done solo in a pinch. I personally did it by myself, and I am not all that strong. Take your time. It is very easy to scratch things with the seat brackets while removing the seat (hence the towels ).
    I. Take the seat someplace where you can lay the seat out without damaging the leather (carpet works well).
    Dec 2005
    Sarasota, FL
    98 M Roadster
    II. Disassemble the seat
    This is the part where you realize why BMW charges $200+ per seat to replace the seat belt guide.
    A. Remove the two plastic plugs at the bottom of the rear plastic shell. You can either pry them out from the top with a slotted screwdriver, or slide the screwdriver behind the plastic shell, next to the plugs, and twist the screwdriver so that it pushes the plug out. This method results in MUCH less damage to the area around the plug. I figured this out after the first one .
    *Note the electrical connections in the bottom center. This is where they are on the driver seat.
    With any luck, your plug won't be too banged up.
    B. With the plugs removed, lay the seat down on its front. Lift the bottom of the plastic shell and pull it towards the top of the seat. I wrapped a thick towel around the bottom edge of the shell and gave it a couple taps with a rubber mallet to get it loose. There are plastic hooks on the shell (circled) that snap onto the seat (circled). Once the hooks slide free, remove the shell and set it aside. The nylon portion of the seat skin is now exposed.
    Before you can unzip the seat cover, you will need to remove the yellow sensor. Be VERY careful with this sensor, as it is not very sturdy and could be easily damaged. There are two funky-looking expanding plugs holding the sensor onto the seat frame.
    C. Using a small screwdriver, push the black center portion in towards the seat. Don't worry about it popping out the back of the plug, as it will just fall to the floor.
    Once the center is popped out, just wiggle the plug out of the seat.
    D. Using diagonal cutters, clip the zip-tie holding the sensor wire to the seat frame.
    E. Unhook the bottom of the seat back skin by finding the plastic channel at the bottom of the seat back where the front of the seat hooks together with the back.
    You can unhook the two sides by reaching under the plastic channel and rolling the plastic strip downwards and out of the channel.
    F. With the channel unhooked, you can now unzip the back. Needle nose pliers help if you have a hard time with the zipper.
    Dec 2005
    Sarasota, FL
    98 M Roadster
    G. Unhook the leather straps around the lower seat frame cross brace. These are just tucked behind the brace, so just wiggle them free.
    H. Push the plastic channel and leather tabs through the crack in the seat.
    I. Begin pulling the seat skin up off the bolsters to reveal more of the back.
    J. Unhook the nylon straps along the frame of the seat. These straps are stitched in to the vertical seams of the front of the seat. When the straps are pulled tight and attached to the frame, they hold the seat skin in the right shape.
    Each strap is held to the frame by a "hog ring". You can open these rings up by forcing a screwdriver into the overlapping part and twisting it open. Needle nose pliers help turn the run on the frame so you can get the strap loose. I believe there are 5 of these rings per side of the seat. Make sure you don't damage the straps, as the seat will look like crap if you can't hook them back to the frame when you're done.
    Here is where I ran into serious problems. The bottom strap is hooked to the frame behind the crossmember where the yellow sensor was mounted. I couldn't reach these rings, so I couldn't pull the cover up all the way. Because of this, I had to do the rest of the operation by sliding my arms up the skin and working blind. This is the worst possible way to do it, and my hands were screwed up for a couple days after. I will continue the how-to assuming that I had been able to get those straps loose and do everything right.
    Get all of the straps free of the seat frame and pull the seat skin off of the seat.
    Dec 2005
    Sarasota, FL
    98 M Roadster
    K. With the skin off of the seat, you can get to the snap-rings that hold what's left of your seat belt guides onto the skin. Use a screwdriver and/or pliers to pull the snap-rings off of the posts that go through the seat skin.
    L. Replace the guides with new ones. These run around $20 each from the BMW dealer, and come with everything you need.
    M. Reassemble the seat by pulling the skin back on and feeding the straps back through the holes in the padding. Make sure to get all of them hooked back to the frame. Everything else just goes in reverse of how you took it apart.
    When putting the seats back in the car, make sure that you bundle the wires up so they don't interfere with the movement of the seat.
    That pretty much covers it. If you haven't done this before, make sure you set aside a couple hours to do it. Also, remember that you cannot drive the car until both seats are done (airbag sensors, remember?).
    There are several guides to this floating around, and I took on my job using those. I found that they covered the major points of the procedure, but missed many of the little details that made the job particularly nasty. Plus, none of them were illustrated .
    I hope someone finds this useful, I would have liked to have had it when I did the job myself.
    HI
    '00 M Coupe
    holy crap. Impressive work. You have to be the most helpful member that has come around in a while. Although I think if my sb guides ever broke, I'd just get new seats
    Dec 2005
    Sarasota, FL
    98 M Roadster
    I wouldn't blame you. I was so beat up after my 2-day battle with mine that buying new seats would have seemed like a really good idea.
    Jun 2008
    FL
    2015 435i ZHP
    this is a major pain in the rear, i quit after 2 days of trying to do this.
    Jul 2003
    NC
    00 MCoupe - 04 Lexus RX330 - 90 325i
    Quote Originally Posted by Jshkrauss
    RLY Extremely nice work and attention to detail. How many did you consume?
    Dec 2005
    Sarasota, FL
    98 M Roadster
    Quote Originally Posted by ///MDex
    After finishing the seats, several.
    Jan 2006
    Kings Park,NY
    1998 M Roadster
    What is the yellow sensor for ? I noticed one of the push pins that hold mine to the drivers seat was missing !
    Dec 2005
    Sarasota, FL
    98 M Roadster
    The sensor is connected to the seat movement harness. I have no idea what it really does, but I would definitely make sure you have it properly attached. You could probably rig up a zip-tie if you don't want to pick up another plug.
    Jan 2006
    Kings Park,NY
    1998 M Roadster
    Moon yellow sensor
    Quote Originally Posted by Vinci
    Did a search on BMRfest and some how the yellow sensor stops the seat motor from going back to far the when the back hits the rear hump , Useless IMHO.
    Dec 2005
    Sarasota, FL
    98 M Roadster
    I figured that it was related to that, but I didn't want to tell you to not to worry about it, in case it was airbag-related. Thanks for the confirmation!
    Anaheim, California
    1998 ///M Roadster
    I am going to try superglue on mine. I'll let you know how it turns out.
    Los Angeles, CA
    1997 Alpine White M3
    M Coupes dont have SB guides
    Dec 2005
    Sarasota, FL
    98 M Roadster
    Oh yeah? Well, I can get a horrible sun burn on long drives. Beat that.
    Los Angeles, CA
    Nice write-up though, I'd be pretty wary to take my seat out, let alone disassemble it
    gj
    Jan 2002
    Québec City
    '21 X3 M40i, '13 Abarth
    Excellent write-up!
    2021 Phytonic Blue/Cognac BMW X3 ///M40i
    1999 Cosmos Black/Dove Grey BMW ///M3 convertible - 5 speed - SOLD
    2005 Atlantic Blue Pearl/Taupe Leather Subaru Legacy 2.5 GT Wagon - 5 speed
    - SOLD
    2014 Tenorite Grey/Black Mercedes-Benz GLK 250 - bone stock.
    2013 Bianco/Rosso Abarth 500c - 5 speed
    2016 Oxford White/Grey Ford Transit 250 Powerstroke 148 MR (DIY RV conversion)
    Boise, ID
    00 M Roadster
    Thanks for the great write-up and pictures.
    Honolulu
    No more BMWs :(
    Awesome post Vinci! Sooo happy that Coupe owners do not need to deal with these things.
    997 Carrera 2S..the choice of 2 out of 3 Top Gear presenters.
    Dec 2005
    Finland
    Z3 2.8 Roadster '98
    That IS a great writeup! I just noticed recently, that the one on my driver's seat is cracked, so I might have to do this sooner or later. BTW, which seats are those? I would assume they are facelift-model ///M-sport seats? As they seem to be a bit different from my ///M-sport seats and I haven't seen that kind before..
    Dec 2005
    Sarasota, FL
    98 M Roadster
    Anaheim, California
    1998 ///M Roadster
    I superglued my cracked seatbelt guide and it seems to be holding up well. I have only had it on for less than a week so only time will tell. You can't even see the crack once it is glued because the seat belt covers it up.
    Dec 2005
    Summerville, SC
    2001 M Roadster
    Superglued mine the day I got it (New Year's Eve). Working well so far.
    Benjy Lafond
    2001 M Roadster - Oxford Green / Oregon Beige
    Dec 2004
    Boston, MA
    M3, MZ3, 348TS, Chevelle
    I tried Loc-Tite-ing my guides together, but they only lasted about 2 or 3 days... Maybe I'll try some other adhesives before trying to tackle an actual replacement or, lol, buying new seats! :-P
    BMW M3 - Ferrari 348 - Chevrolet Chevelle
