Results 1 to 5 of 5
Thread: Temperature control panel.
    Feb 2009
    Olyphant, Pa
    2000 740i--944
    My temp. control panel greenlights stopped working. Any help on a fix for this ?
    Feb 2009
    KC North, MO, USA
    1996 740iL
    I had one that flashed on and off for a few years and eventually all the lights went completely out. Controls still worked fine. I took it apart, cleaned the internals and I want to say I reseated a few connections on the board but nothing helped. I was parting the same model year at the time so I swapped the IHKAs. This fixed the issue and supplying power to module in the parts car gave the same result, no lights.
    Someone smarter than me may be able to look at the circuit board and find the issue. This is an internal issue with the module, as opposed to a fuse/power problem.
    Feb 2009
    Olyphant, Pa
    2000 740i--944
    Can you tell me how the IHKA control comes out?
    Feb 2009
    KC North, MO, USA
    1996 740iL
    I've only done it on a '96 model. If you have NAV, I believe the screen has to come out first. On the early model, DIY's showed to remove the cupholder but I was able to remove one of the switches below the IHKA and pull it forward as I recall.
    Feb 2009
    Olyphant, Pa
    2000 740i--944
    Thanks. Where do you find the DIY's ?
  1. Temperature control panel.
    By atr42nz in forum 1995 - 2001 (E38)
    Last Post: 09-16-2024, 09:18 PM
  2. Temperature control panel!!!!!!!!!!!!
    By M3AVUS in forum 1992 - 1999 M3 (E36)
    Last Post: 07-15-2005, 05:55 AM
  3. Need HELP ! Temperature Control Module not working
    By JLee in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-04-2001, 04:07 PM
  4. Still Need AC/Heating Control Panel Advice
    By flybarons in forum 1991 - 1999 (E36)
    Last Post: 05-23-2001, 12:42 AM
  5. AC/Heater Control Panel Advice
    Last Post: 05-20-2001, 08:16 PM
