Results 1 to 3 of 3
Thread: Auxiliary Cooling fan 525ia m50
    Aug 2022
    BMW e34 she my love
    BMW E34 M50 1990
    Hello guys.
    What's the difference between the F10 and E34 fans?
    Which one is better for the E34?
    Jan 2005
    Japan
    11/88 E32 750iL
    E34 fan fits 100% on E34, size, design, power and also the electr. connectors. Compare F10 fan motor vs E34 fan motor wattage, probably your E34 fuses would pop fast, otherwise the wires would melt. Quick check tells us that the one from F10 has 400W and the E34 one ~250W-270W depending on maker. For example E34 fan 64541392913 dia is 380 mm, it is used on some models E24, E32, E34, E36, even E31 8 series M62, M60, M70, M73, S70, so it should be fine for your E34 525iA. Use E34 parts on your E34 and you will have no problems
    Aug 2022
    BMW e34 she my love
    BMW E34 M50 1990
    shogun
    Thank you, it was just a thought.
