Results 1 to 4 of 4
Thread: First time INPA / BMW tools user. Please help! INPA reads ECU, but no other modules.
    Sep 2010
    Atlanta, GA
    2008 Mazda RX8
    Good day,
    I have a 2003 Z4 3.0 with a miscalibrated steering angle sensor after some suspension component changes and an alignment.
    I'm using a K-DCAN cable from Amazon with a switch connected to a Intel Macbook running Windows 10 on Bootcamp.
    I've had success with the same setup running BMW Scanner 1.4, but am struggling to get up and running with INPA now that I need to do more than simple diagnostics.
    I installed the software using Mike's Easy installer. I have the drivers set to COM1, latency on "1", verifying that it looks fine on Device Manager.
    What's more, I can read engine codes (although my submenus - and the code explanations - are still in German).
    When I go to E85 -> Chassis -> DSC MK60, I get two error messages (depending on which way my switch is flipped on the cable).
    "IFH-0009: NO RESPONSE FROM CONTROLUNIT. Program will be stopped!"
    or
    "IFH-0010: DATATRANSMISSION TO CONTROLUNIT DISTURBED. Program will be stopped!"
    Danke in advance for any advice / troubleshooting tips you can share.
    Jul 2004
    Houston, TX
    36 Cylinders
    Bridge pins 7&8 on the K+DCAN cable using the switch on the cable.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Sep 2010
    Atlanta, GA
    2008 Mazda RX8
    Thank you! I tried with the switch in both positions, but I’ll test with a multimeter to see if it’s bridging when switched.
    Sep 2010
    Atlanta, GA
    2008 Mazda RX8
    Interesting - pins 7/8 do not have continuity in either switch position. Is that normal?
  1. Where can I find my BMW Radio Code? Please Help
    By no_j0kes in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-09-2019, 12:14 PM
  2. Replies: 2
    Last Post: 08-11-2015, 07:46 AM
  3. First BMW 95' 525i Please HELP
    By mrthrowpole in forum 1988 - 1996 (E34)
    Last Post: 10-29-2010, 11:47 PM
  4. first bmw ever owned PLEASE HELP
    By 733irookie in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-03-2010, 09:30 PM
  5. First time on BMW, need help!!!!
    By thehaole in forum 1999 - 2006 (E46)
    Last Post: 04-19-2007, 11:47 PM
