Results 1 to 3 of 3
Thread: Fuel pump or fuel pump control unit?
    May 2025
    Marin County, CA
    e93 2011
    Angry Fuel pump or fuel pump control unit?
    e93 with a history of water intrusion and damage
    A month ago it stalled after a 30 min drive while I was in slow city stop-and-go driving, and showed a symbol of the car up on a lift.
    Mechanic said fault codes 6292 and 6293. Replaced the battery due to the battery being undersized and end of life.
    During short drives around town while I regained trust, I had no problems so I thought the battery solved the issue.
    But the other day again after 30 min of driving in slow in-city driving it stalled again. This time no fault codes.
    Mechanic said he hit the fuel tank with a rock while it was stalled and it restarted. Mechanic did visual inspection of control unit and saw no water damage. Mechanic says replace the fuel pump.
    I'm still really skeptical because of the history of water damage, and I've heard from other mechanics that the control unit is far more frequent a fix on these cars than the fuel pump itself.
    I thought I would ask this group to see if anyone has any strong suggestions. I can't afford to fix both.
    Thank you.
    Jul 2010
    Whitby, ON, Canada
    335GT & Z3 M Roadster
    Is it running no. If so, I'd take a spray bottle and start spraying the control module and see if it craps out
    Sent from my SM-F956W using Tapatalk
    My Rides:
    2016 f34 335GT stage2+ MHD FBO, custom carbon throughout!
    2000 Z3M
    too many upgrades to mention
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    It could be the EPKM module (fuel pump module) over heating. Once the module cools down, the car will start, but 30 minutes later it will over heat and the car won't start. It happened to me on a highway. I called a tow truck and right when the tow truck was pulling up, I did a last attempt to start the car and it started. I was 4 miles form home so I made it.
  1. Coding in Oklahoma City for Fuel Pump Control Unit
    By blt4me in forum 2004-2010 (E60,E61)
    Last Post: 12-15-2017, 02:40 PM
  2. Fuel pump & left fuel sender unit
    By Twistytee in forum 1991 - 1999 (E36)
    Last Post: 06-13-2017, 07:51 PM
  3. 2008 328i Fuel Pump/ control unit covered under SULEV warranty?
    By dreamteam in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 05-10-2017, 03:06 PM
  4. need fuel pump and fuel sending unit
    By georgese30 in forum E30 Parts Classifieds
    Last Post: 11-24-2012, 03:23 PM
  5. Can Engine Get Damaged from Fuel Starvation from Fuel Pump Failure?
    By dave162 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-11-2003, 01:15 PM
