Page 5 of 5 FirstFirst 12345
Results 101 to 102 of 102
Thread: Garagistic Steering Coupler Install & Review
  1. #101
    Dec 2018
    Indiana
    00 M Roady '22 Lexus RC
    As I have stated before, I measured an inch from top dead center of the steering wheel, each way before the wheels moved. After I upgraded the steering shaft, when the steering wheel moved, the wheel moved. It does make a difference.
  2. #102
    Apr 2020
    Ontario, Canada
    Early '99 Z3 M52TU2.8
    Quote Originally Posted by zellamay View Post
    Apparently they will .... but when? In response to my inquiry, Matt at Garagistic wrote this on April 9th:
    "I really am not sure when we will have a Z3 R&D car here …. I do not have a way of giving you a definitive timeline as to when it well happen"
    Now that Hoyt has road-tested the "Clagwell", I might get impatient and make one. (I don't think it's patent-infringement if I just make one for myself). I've recently replaced ball joints and sway bar end links, so now I (think I ) notice the play in the steering. I'm not sure because the car is so much quicker-responding than any other car I've owned, yet I play with the wheel and think it could be tighter.
    The Clagwell is patent free. Aluminum is easy to work. I used a coping saw for wood to cut it to shape and cleaned it up with files.
    Try this with your steering. Turn the wheel quickly back and fourth an inch or two while driving at speed. You will definately notice a rubbery response. The poly coupler eliminates that.
    Quote Originally Posted by IndianaRoadster View Post
    Definitely.
  1. Steering coupler installation
    By mgbrv8 in forum 1983 - 1991 (E30)
    Last Post: 02-05-2018, 12:41 AM
  2. Steering coupler/guibo install, review......
    By por911 in forum 1991 - 1999 (E36)
    Last Post: 09-05-2012, 12:40 AM
  3. installing steering coupler- tips?
    By Roktgr in forum 1991 - 1999 (E36)
    Last Post: 06-06-2011, 08:51 PM
  4. Accessory Steering Wheel Instal.
    By Uber328 in forum 1991 - 1999 (E36)
    Last Post: 07-18-2002, 06:50 PM
  5. Infinity Basslink Install and Review
    By crash in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-16-2001, 11:22 AM
