Results 1 to 3 of 3
Thread: Dash asking for CODE, Car won't crank or start, Will deleting EWS fix this?
    Jun 2019
    Kentucky
    95 325i, 2001 740iL
    Basically title, have a 2003 540i msport. Car sat for a really long time, went to start it up to pull it into the garage for a transmission swap and new timing chain guides and it won't start. The dash says CODE ----. After some googling, it looks like normally you would be able to interact with this 'code' through the onboard radio unit.. but this is where things get bad, I do not have the oem original unit. I have an aftermarket unit. To make matters worse, I don't even know what the original unit was if I wanted to buy a replacement because the previous owner removed it and put in the aftermarket unit.
    I am looking into ebay to find a service to flash my dme with an update that removes EWS, this would be the cheapest option to start with.
    Tomorrow I will try booting up INPA and will attempt to re sync DME to EWS.
    I really just want to be able to get the car running lol even if the fix isn't perfect.
    Jun 2019
    Kentucky
    95 325i, 2001 740iL
    UPDATE: I put key in position 1, waited 10 minutes, then it started. I drove about 15 minutes getting the 2 years of rust off the rotors and then I brought it back home. When I tried to start it again, no CODE ---- on dash and it started right away.
    Mar 2025
    Scarsdale, NY USA
    1997 328ic
    I have 1997 328i convertible. Recently got a new battery and all working fine. I took for several drives over several days. However, the radio would not work. I pressed the "code" button and was asked to enter a 4-digit number. The problem is that the only code I have is 2 letters and 6 numbers. Now the car won't crank. I called my mechanic, who did not have a solution. I called the local BMW dealer's service desk and that mechanic was out today. I will try your method tomorrow, as I was tied up today, got picked up, and left the car where is was (in a parking lot). Any ideas greatly appreciated.
  1. Replies: 8
    Last Post: 09-10-2017, 12:18 PM
  2. Car won't crank, dash won't light up.
    By zcct04 in forum 1991 - 1999 (E36)
    Last Post: 02-07-2015, 08:51 PM
  3. Wow code P0600 no comm link car won't crank!
    By BigBoy38 in forum 1995 - 2001 (E38)
    Last Post: 12-27-2012, 03:27 PM
  4. Reinstalled Cluster, car won't crank/start
    By Febi Guibo in forum 1983 - 1991 (E30)
    Last Post: 02-11-2006, 11:11 PM
  5. Need help ASAP!! Car won't crank
    By Timberwolf in forum 1983 - 1991 (E30)
    Last Post: 07-21-2004, 02:54 PM
