That's pretty awesome
Sent from my moto z4 using Tapatalk
-Andrew Mensah
Thanks guys!!! I sure do miss drifting!!! It was the most fun i'll ever have, i'm excited to get back into it one day. But for now, my family has taken priority. My wife and I are very busy with classes, certifications, training, raising our one year old, saving for our own house, etc.
I am still posting in the forced induction section here. If anyone wants to check it out, we've been busy super-charging my brother's e36 ti.
Hi . I fitted an M50B25 NV motor in my e46, however the motor is sitting almost an inch to the back. So now I can't bolt on the gearbox support bracket because it ain't lining up. I wanted to fit my e46 mounts, but it doesn't bolt to m50 block. I was thinking of drilling and tapping thread for gearbox bracket to fit. But I don't know if it's pushing against the prop also. Need help please
I think motor mount arms may be installed incorrectly. double check that first. e46 motor mount arms use different bolt holes than the e36 arms
I used my e36 motor arms but motor must still come forward so I can bolt on the gearbox support bracket. What can I do?
Hi man im currently swapping a rebuilt s52 into a 2000 328i from my understanding it should bolt up easy but you mentioned you have had success using a stock wiring harness can you go into more depth please thank you
also adapters like these exsist but im not sure if this would require a s52 harness https://www.condorspeedshop.com/prod...arness-adapter
do you still have the e46 body-side and engine harness wiring in tact? are you planing on using that to run the s52? alpina ran a 3.4L s52 in an e46 sedan and IIRC they just used stock e46 harness minus a vanos solenoid sensor plug and a quick reflash on e46 DME.
if you still have all the e46 wiring in tact, easiest route would be to just copy alpina. I would first check with a tuner that is capable or check with your current tuner and make sure that is something they can do.
next easiest would be to use an adapter, as you mentioned, to adapt s52 engine harness to the e46 body harness.
If you are gong full race-car, I would recommend just re-pinning an s52 body side x20 connector for your specific application. that is what i have covered in this thread.
I do still have the e46 harness intact I havent started the swap yet as I still drive the car. Also could i ask for the link from the alpina post. also what are the sdvantages of repinning the harness over using the adapter or original engines harness
the only real advantage of re-pinning the harness would be ease of diagnostics/trouble-shooting.
I definitely recommend using all the e46 stuff that you can. That way all the electronics on the chassis will be happy, cluster being most important.
Not easy to find any Alpina info and unfortunaley, I don't have much information for you on how easy the e46 engine harness installs on an s52. There are people that have done this, and i think maybe one or two of those guys commented somewhere in this thread. maybe you can get in contact with them.
I have been out of the loop a bit on BMW's but i think condor speed shop makes a few different wiring harness adapters. you could also try contacting them and see if they have anything to offer you.
I'm really hoping you can easily use e46 engine wire harness to run the s52, after reflashing e46 DME obviously.
just noticed the link you posted to condor speed shop. that harness will work, just need an aftermarket temp gauge
Really ? I know this post is old but i had no idea a single vanos could be run on ms43!! Are you able to give any info if you’re still active on here!!
Hey im currently doing this swap but had no idea i could keep the ms43! Are you able to share how you made this work if youre still active on here ?
