Page 8 of 9 FirstFirst 123456789 LastLast
Results 176 to 200 of 206
Thread: Racing track performance ECU DME 96-99 E36 MS41.1
  1. #176
    Feb 2009
    Arizona
    1998 e36
    Quote Originally Posted by jorgetiny View Post
    My car runs and idles perfect
    great
  2. #177
    Jul 2016
    Los Angeles
    97 Alpine M3/4/5
    Sent you a PM
  3. #178
    Mar 2011
    Kingston ,Jamaica
    1997 328i turbo
    Also sent you a pm
    Sent from my SM-G960U1 using Tapatalk
  4. #179
    Jul 2020
    Arlington, VA
    1998 M3 Sedan
    PM'd
  5. #180
    Feb 2009
    Arizona
    1998 e36
    Quote Originally Posted by 72beetle View Post
    PM'd
    Replied
  6. #181
    Feb 2019
    Lafayette, LA
    98 528i & 540i/ 06 550i
    Sent you a PM?
  7. #182
    Aug 2020
    Olivehurst
    BMW 528i
    K i got into the forum. Where do i pm you at?
  8. #183
    Feb 2009
    Arizona
    1998 e36
    replied
  9. #184
    Texa$
    All of them.
    so if I decided to do some kind of m50tu/m52/m54 hybrid...this is the hot setup i hear?
  10. #185
    May 2012
    los angeles ca
    1997 m3/4/5
    Got one of these ecu’s about over a month ago just haven’t had the time to leave a comment. Install flawless, car fired right up! Great product! You know what your doing and I’m very happy with the results of the cars performance. Can’t wait to buy another car and get another ecu/chip from you thanks again!
    P.s the best part about is that my emissions here in California are no longer a problem
  11. #186
    Jul 2003
    Spring, TX
    E36 328is, E39 M5
    Bought this ECU tune from you a few years ago... can't remember exactly when... 2015? Ran great for many years but recently it started acting strange. High cold idle, over 2,000 rpms, that took a long time to settle down. Drop and rise... drop and rise... drop and rise. Then when it does lower idle at about 700 rpms, it runs slightly rough for about 2 minutes and then will smooth out for about 30 secs... then rough again for 2 minutes. Very strange behavior. I swapped the stock DME back in and it runs normal again. Cold idle about 1600 rpms, settles at about 630 rpms and smooth.
    Any thoughts on this? I haven't opened it up but willing to stick my nose in it.
    Lime Rock Park... the most fun you can have in a mile and a half.
  12. #187
    May 2021
    Rhode Island
    2003 330ci
    Sorry if you mentioned this before... I would have PM'd you but the system wont let being a new member. Will this work on a 2003 330ci? Tired of chasing a cat problem when I already have two new cats and 4 new o2 sensors...
  13. #188
    Feb 2009
    Arizona
    1998 e36
    Quote Originally Posted by onesikM View Post
    Thank you.
  14. #189
    Jun 2021
    Westchester
    E36 m3
    Can you flash software for forced induction?
  15. #190
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by AvusBlue84 View Post
    Quote Originally Posted by RIBMW View Post
    I don’t believe he does either, but I can help both of you.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  16. #191
    Jul 2012
    Herndon, VA
    98 M3/4/5, RIP 528e
  17. #192
    Apr 2015
    Tennessee
    1998 BMW 328i
    Quote Originally Posted by Hallatauer View Post
    I had this issue, traced Mine to a ripped air hose running from iac to intake boot.
    Sent from my SM-G975U using Tapatalk
  18. #193
    Feb 2009
    Arizona
    1998 e36
    Quote Originally Posted by 95maxrider View Post
    Subscribing for future reference
    Still got plenty
  19. #194
    Apr 2009
    monterey park , california
    1993 325is s52 6 spd
    Quote Originally Posted by hakentt View Post
    Still got plenty
    Would this be a drop in replacement if i have ms41.1 ??
  20. #195
    Oct 2022
    Chicago IL
    1991 BMW 318is
    Hi, I’m new to forum, I’m searching someone who can program ecu for my e30, with m54b30 engine swap. DME MS43
    Thanks in advance
  21. #196
    Feb 2009
    Arizona
    1998 e36
    Quote Originally Posted by arsenik55 View Post
    Thanks in advance
    I can do it
  22. #197
    Feb 2009
    Arizona
    1998 e36
    I got more
  23. #198
    Feb 2023
    CT
    1989 325i Vert
    so this would be 100% plug and play with a full m52b28 harness and adapter to an e30? I would not need a new key and transmitter? would have PM'd but new on the form
  24. #199
    Feb 2009
    Arizona
    1998 e36
    Quote Originally Posted by sdegray View Post
    plug and play, no key no transmitter
  25. #200
    Dec 2023
    Texas
    Z3
    Im interested in buy one. Could you email me at jrshrrchr@gmail.com? Im too new to PM. Thanks in advance!
