Hello, I have a 2002 745Li, n62b44. I'm installing the Eaton m122h supercharger. And I'm trying to find if there is any tuning software available for this DME.? I believe it's the me 9.2. I need. software that's capable of not only tuning fuel and timing, but also tuning the throttle body.
I know this throttle body acts as a fail safe in case something goes wrong with the valtronic. Originally I thought that's all it did. Until I noticed that it also has a map sensor in the intake manifold. So I did some research, and found out that the map sensor and throttle body work as a closed loop system to control a small amount of vacuum in the intake so that the PCV system and some of the emissions systems work.
With the supercharger I need to increase manifold vacuum at idle and light engine loads. The throttle body will be mounted on the intake of the supercharger. So having the supercharger in a vacuum when not needed for boost increases it's efficiency. Otherwise it will try to produce boost which the valvetronic system will not like
Sent from my 2201117TG using Tapatalk
