― George Orwell
Yeah, that car was great ... went a long way for me in racing it was chassis # 00097, so very early build as well. The s50 in it was never build beyond what you did ... I think ~245 rwhp if I recall. After I sold it, it got an LS6 put in and became a drift car ... I'm sure it's still kicking around somewhere!
― George Orwell
Ok, WTF? IMO, (yes, it's my opinion) what's the big deal with all motor? Who the hell cares other than bench racing?
1.) You aren't going to want to drive a full on 400hp K24 in a street car or any race motor. They don't make squat for power where you actually use it. They don't idle well, they won't pass emissions.
2.) just put a turbo on it and call it a day. You can make 450hp and still have some torque, and be way faster than the chassis needs. Or... Put in a LS1 and make 500 cheap, reliable Hp that's lighter than the M5x anyway.
If you have a garage queen you aren't going to be ripping out the engine anyway, and if it's a normal $10k? M3, who cares what's in it?
to me there is something special about naturally aspirated. Some people like chocolate, some people like vanilla, but at end of day its all ice cream.
I have both — modded E90 M3 that makes its power by revving to 8600 and has a relatively low and flat torque curve, and a modified turbo E36 M3 that peaks in the 6000-6500 range and ramps up fast to very high torque and then drops off. The turbo is a lot more exciting.
I’d like to try the compromise — a large displacement V8 that makes big power and pretty good torque naturally aspirated. An LSx swap into some car could be in my future. I might also consider an E60 M5, which is not a torque monster but does have a lot more power than my E90 M3. Maybe I would stroke the S85 if I came across a good deal or found a car with one.
Honestly, if you're at the point where you're thinking LS swap for point and shoot power, at what point does it make sense to just get a Tesla. Too much power and it's less fun. I barely ever get to tach out my E90 M3.
2011 M3 Sedan
2006 GMC Sierra 2500HD LBZ
1999 323i GTS2
1995 M3 - S50B32/S6S420G/3.91
1990 325is
1989 M3 - S54B32/GS6-37BZ
Hers: 1996 Porsche 911 Turbo
Hers: 1989 325iX
Having owned a stock e39 M5, and an e36 M3 with the basic normal mods (M50 manifold, tune, intake boot), I would say over and over again that the M3 is more fun to rev out and wring power out of. The M5 was faster, but it wasn't as raw. The screaming NA I6 is where it is at. Every one is entitled to their opinion, you may think the e36 is underpowered. In my opinion, the roughly 260 crank horsepower I'm making feels perfect for the chassis.
I’d want more like the 321 hp of a Euro M3. An S54 swap will do that and with some mods get to about 400 hp, or 350 rwhp.
To that point, I drove a friend's Mustang GT350 with the 5.2 liter "flat-plane" crank, 8,250 rpm redline. Cool car. However, the power was not where you want it for a street car. You had to rev the crap out of it and low end torque was lack luster to say the least. My dad's Alfa Romeo 4C is a much more fun car (even though it's "missing" a pedal). IMO, there is such a difference between a fun street car v. dedicated track/race car.
Exactly. Which is why no one is dumping money into developing S52s. Why spend $20k to end up no better off than a stock motor that is readily available for $3k in decent condition? If you want to spend money building an engine, build an S54 and get pretty insane results. Building an S52 is a stupid waste of money under nearly any circumstance.
2011 M3 Sedan
1999 323i GTS2
1990 325is
Hers: 1989 325iX
I think the total cost of an S54 conversion ends up being a lot more than $3k. I have seen higher mileage S54 for $3-4k, but there is more to it than buying the motor and some don’t want the hassle.
2011 M3 Sedan
1999 323i GTS2
1990 325is
Hers: 1989 325iX
A proper s54 swap is going to be 7k or more. A s54 is 3-4K . Rod bearings, vanos fixes, oil pump chain, and other knickknacks 1,500-2k . Labor 1,200 to 3k. Proper exhaust 600-1200. Pnp swap parts 500-900.
Hello get the picture?
You sell the s52 for 1,500-2,500
― George Orwell
Have you ever priced out engine work on an S52? $10k and you'll still be at least 50hp short of that stock S54 with an exhaust and the right tune. And you'll have a motor that probably will have a fraction of the lifespan of that used S54. And when that S54 blows up, you can find a replacement and swap it out in a weekend. When that S52 blows up, well, gotta find a hole in your engine builder's schedule and another $10k, and you'll get your car back on the road 6-12 months later.
2011 M3 Sedan
1999 323i GTS2
1990 325is
Hers: 1989 325iX
LOL I would submit it isn't "hard", it's expensive. 😜
I mean I feel like it wouldn't be far off. You'd probably spend $3.5-4.5k on the head including cams. Probably hard to get a good header these days? But let's say you get one, maybe $1k. HFM, Big Bore throttle body, adding an intake, Maybe like another $1k or so plus exhaust.. Plus the refresh of your head gasket, studs, anything else there. And depends on who's doing the work. DIY would of course save money... as usual. But I'd say for sure a high-hp S52 build probably wouldn't be much cheaper than S54, especially given the results would be very different, you can't rev as high, it'll be highly modified and high strung. And anything that breaks will be 'modified' so you'll have to replace as such.
I think the S54 is a much more sensible option... yes it costs more, but it is meant to live at the power levels it produces, so it 'should' be a safer more reliable motor.
Just my take.
Raceland euro ss rep has worked great for me, and several other track guys.
― George Orwell
It’s expensive to build an S54. A used one might be comparable to building an S52, but when you have to maintain and repair the S54 you will spend more. Valves need periodic adjustment, vanos has more expensive issues. I fully built an S52. Have about $4k in the bottom end and about $4500 in the top end. Plus the turbo system, driveshaft, transmission, clutch, differential, axles.... it would have cost more if I did all this to an S54.
Call me crazy but i much prefer the way the s52 revs and delivers power, the s54 has always felt very blocky to me, leas emotional if that makes any sense.
