Results 1 to 10 of 10
Thread: need radio help please!
    May 2019
    Texas
    2001 BMW e46 Sedan
    (for starters, photos with flash are pre-wiring, darker photos are post-wiring) alright so i received the car like this. I have a 325i from 2001 and the radio would turn on, but i couldnt read a thing because the display was scrambled (but on) and i had no sound no matter what i pressed or turned. I went to a place that parts out cars, grabbed a couple radios, and a radio harness. I used cable connectors to connect the new one to the car and by the end i have a couple extra cables. I say what the heck, toss on my orig. radio, no display, no sound (mind you orig. did not have push to turn on). so i try the other radios, one is a cassette one that has all of my same cords in the car, turn on display, get “disabled” sign. okay, i try the other radio i purchased. cd player, but a newer one with a cable i dont have and also missing a cable i do have. turn it on, disabled. im at a dead end right now and could use the help! thanks.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    Are we talking about original BMW radio's here? I am guessing so because you keep getting the "disabled" on the screen. You would need to program in the new radios, as they are coded by the vin number.
    Of course you could also look at getting a Kenwood with an adaptor to fit in there as well.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    May 2019
    Texas
    2001 BMW e46 Sedan
    how would i go about doing that?
    dworthy's Avatar
    Nov 2010
    Progman, ISTA or similar program to code the radio. You can check with a local dealership = $$$ or a Indy =$$, perhaps a local BMW chapter mechanic = $
    Darin
    Current:
    Past:
    M-Flight Member
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    E46 radio does not need programming to work. It says "disabled" because it is not receiving the k-bus signal. Does your instrument cluster work normally?
    Sent from my S61 using Tapatalk
    Mar 2015
    west chicago il
    Also can't see pictures
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Yep, swapped many OEM radios in my car trying to get one with perfect display and never needed coding.
    Quote Originally Posted by randy72877 View Post
    May 2019
    Texas
    2001 BMW e46 Sedan
    okay so i have a different instrument cluster in right now. my original one all worked besides the gauges, so i switched it for another one for now, but this one the center display at the bottom doesnt switch when i press the button on my turning signals. ill have to put mine back in and see if it’ll get the radio working again.
    May 2019
    Texas
    2001 BMW e46 Sedan
    Quote Originally Posted by bmwdefence View Post
    I plan on sending my orig. cluster to a guy who can fix the gauges (refer to previous thread on my acc), so this other one is just what im using for now since it gets the job done.
    Mar 2015
    west chicago il
    The cluster not working correctly is also a symptom of a k-bus failure. Go to www.bmwgm5.com and read about the k-bus and the symptoms of no k-bus communication. If that is what your car is doing, there is also helpful diagnostic info.
  1. E36 Radio Help Please...NEED CODE
    By Dust559 in forum 1991 - 1999 (E36)
    Last Post: 04-03-2014, 07:39 PM
  2. E36 325is Needs Radio..Help Please
    By GTRSv in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 10-12-2010, 08:14 AM
  3. I need Radio help PLEASE
    By jamesthebikeguy in forum 1996 - 2003 (E39)
    Last Post: 05-31-2007, 12:12 AM
  4. Experts! I need your help please.
    By Bratik in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-03-2002, 02:31 AM
