Page 5 of 5 FirstFirst 12345
Results 101 to 122 of 122
Thread: Long 740
  1. #101
    Jan 2016
    Houston
    tbd
    Quote Originally Posted by purplecty View Post
    Damn why? The car looks perfect now with the new shocks and BG springs...
    I said all that, but I keep going back and forth, it rides great, feels good, but I would like back to be a bit highter, and the front maybe a bit lower. similar to H&R stage 2 but without the harshness.
    Looking to buy
  2. #102
    IL
    2000 740i sport
    Quote Originally Posted by Lamer321 View Post
    I would have kept oe sport springs in the back
  3. #103
    Jan 2016
    Houston
    tbd
    I don't believe the IL's had sport springs in the rear?
    Looking to buy
  4. #104
    IL
    2000 740i sport
    Oh yeah forgot you're in an iL...
  5. #105
    Jan 2016
    Houston
    tbd
    installed new rear upper arms:
    bad ones:
    also what is this for? its threaded on the inside. found next to the rear exhaust mount.
    and I saw this on my lower arm bushings, does this mean they are bad?
    Looking to buy
  6. #106
    CT
    E38
    bad ones:
    Those rear upper arms make all the difference, don't they? Make sure to get her aligned.
    I'm tuned into the lower bushing thing - I was under the impression that they never wear out, especially since I've never even seen a new one for sale.
    E38 M Sport 6 Speed MANUAL
  7. #107
    Jan 2016
    Houston
    tbd
    alignment is on the list for tomorrow during lunch.
    and now that I replaced the uppers, It feels like the back end moves side to side a bit when turning over bumps. maybe something else is bad. I didn't see or find anything that looked bad though.
    Looking to buy
  8. #108
    CT
    E38
    I think that's what happens when your rear toe is wonky. I had that on the bad side I replaced when I did the M Sport struts and shocks. Even on my way to the alignment, it stepped out over bumps until it was nicely aligned.
  9. #109
    Jan 2015
    Tempe, AZ
    1995 540i/6
    It could also be your rear wheel carrier bushings/ball joints, they've been known to allow side-to-side movement when they're bad.
    1995 540i 6-speed - Thread
  10. #110
    Jan 2016
    Houston
    tbd
    Quote Originally Posted by shanecarmaster1 View Post
    alignment is happening tomorrow. maybe that will tell me more.
    Quote Originally Posted by dannyzabolotny View Post
    is there a way for me to determine this? jack it up and shake/push/pull the wheel?
    Looking to buy
  11. #111
    Jan 2016
    Houston
    tbd
    Zionsville radiator installation
    Radiator install went great, total of about 6hrs start to finish. including replacing the alternator. Huge shout out to TxDarth for install help. made things a million times easier.
    It took 2.5 gallons of coolant to fill the system. I'm guessing there was plenty still left in the engine as I did not drain it completely. I "burped" the system by squeezing the hoses to fill it up. and get the air out. then after test drive, cranked heater up to full and ran for a few minutes, the heater core took about 1" worth of coolant from the expansion tank. Drove it to work this morning, no issues!
    Here are some wiring pics (Similar to TxDarth, just not bolted to the radiator shroud, instead I secured everything to the brake cooling duct)
    Next time I am under there I will clean up the wiring with more zip-ties. I only just realized how messy that looks.
    NOTE: MY BLUE ARROW DESCRIPTION IS INCORRECT. THE YELLOW WIRES GO TO THE FUSE, THEN THE FUSE GOES TO THE 12V SUPPLY AS SHOWN IN THE DIAGRAM ABOVE. THE ORANGE WIRES GO STRAIGHT TO THE 12V SUPPLY BYPASSING THE FUSE. I DOESN'T MATTER IF THEY BYPASS THE FUSE BECAUSE IF THE FUSE OPENS, THEN THE RELAYS WILL OPEN AND THE ORANGE WIRES WILL NOT TRANSMIT POWER TO THE FAN....
    NOTE: AGAIN HERE, THE YELLOW WIRE GOES TO THE FUSE, AND THEN TO THE RELAYS. THE ORANGE WIRE GOES TO THE RELAY CONTACTS (ONE FOR EACH RELAY)
    Looking to buy
  12. #112
    IL
    2000 740i sport
    Ooohh I like your engine bay!
  13. #113
    Jan 2016
    Houston
    tbd
    just screwed in my tow hook.....looks as though the started has crapped out on me.
    I turn the key to START and all i hear is one click, then cold blistering silence.
    Had to get a jump yesterday from work. grabbed the multimeter out this morning, battery shows 12.0 volts with engine off (which I thought was a bit low). I called AAA to jump me so I can go get another battery, cant get a jump start! and the starter still only clicks once. AAA guy says battery tested good and its probably the starter. so now waiting for a two truck to bring me to a shop to replace either battery or the starter, hopefully not both...
    Looking to buy
  14. #114
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    I think your wiring diagram is off on the low speed relay - contacts are switched. The low speed would not work correctly as shown. The sensor feed should go to the relay coil not the contacts as shown. It would probably blow the fuse if you actually wired it this way.
    The high speed looks OK...
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
  15. #115
    Jan 2016
    Houston
    tbd
    Bought a new starter ($744 isntalled) BOSCH OEM. Missed work on Friday because of it.
    On a more sad note, I am looking to sell. I will be moving to Dubai for 6 Months at a minimum and would like to get this car to an enthusiast. I have posted a Panjo add here, please pass the word and PM me for any questions.
    https://www.panjo.com/buy/2001-bmw-e...l-sport-333068
    Looking to buy
  16. #116
    Jan 2005
    Sugarland Texas
    97 Artic Silver
    Sorry to revive such an old thread guys. I recently acquired this car and I am so glad to have seen all the information on the car!
    Currently has 203k miles and still running strong.
    Lamer321 I had a few questions for you about the car. Hope your still active on the boards!
    I'll post a pic soon
  17. #117
    Houston, Texas
    1995 Dinan 740il
    Don't know about Lamer321's whereabouts but I'm surprised that Silvio sold it. I've never (really) seen the car but understand it to be in great condition -- even tried to get my son to buy it but Silvio had already grabbed it. Didn't realize it had so many miles though.
  18. #118
    Jan 2005
    Sugarland Texas
    97 Artic Silver
    Quote Originally Posted by Grady in Texas View Post
    Is Silvio a board member? Not sure if he was the previous owner who I purchased he car from as we didn't talk much about forums. Although after reading the thread I have a few questions maybe Lamer will be able to help me out with since he knows this car so well.
    I have a imola red that I am currently prepping for s62 swap. I wanted to drive one around for a while to see the difference after the build is complete.
    My shop has already build one and this will be our second build. The imola is a shorty but I figured I should be able to recognize the difference of overall handle and performance spending enough time behind the wheel.
    Unfortunately the imola was purchased with a blown motor so I have not has a chance to drive it or experience the car prior to starting the build. Chassis has only 124k miles and is in overall great condition.
    I am a previous m5 owner and recently my car got totaled during the ice roads we experienced in Texas. Summer tires and Icy bridge do not mix 😢. I purchased the car back from the insurance and will be using it as the donor.
    Once we are complete with that we plan to convert this one to Manual.
    Should be exciting!
    1994 BMW 540i/Auto/Alpine White/Dove Grey/Eibach/KYB/BB Triflow/M Par Stagged/
  19. #119
    Jan 2005
    Sugarland Texas
    97 Artic Silver
  20. #120
    Houston, Texas
    1995 Dinan 740il
    Silvio owns Silvio's Auto House in Midtown (Tuam St). I have never seen him post here. He bought the car from Lamer but may have flipped it.
    Good luck with the conversion.
  21. #121
    Jan 2016
    Houston
    tbd
    Quote Originally Posted by Inspiredm3 View Post
    Hello InspiredM3.
    I was just pondering about this car and thought I would try to log in try to find it. looks like you found me back in 2018. Any chance you still have it? Curious how its going.
    Looking to buy
  22. #122
    Feb 2009
    KC North, MO, USA
    1996 740iL
    He last signed in to the forum in 2020. Do you still have the VIN for the car somewhere? I've had luck using a VIN in Google to find it's current location, and sometimes the owners name.
  1. Long drive in my 740
    By Avec in forum 1988 - 1994 (E32)
    Last Post: 08-10-2012, 09:37 AM
  2. Tappet noise from 740 after long layup
    By neoman in forum 1995 - 2001 (E38)
    Last Post: 11-25-2010, 08:04 PM
  3. wierd sound from engine after long drive
    By 94_325is in forum 1991 - 1999 (E36)
    Last Post: 03-06-2001, 10:25 AM
  4. Check this out - coolest thing in a long while!
    By Anfanger in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-06-2001, 02:15 AM
  5. HIOP race-tec positive displacement supercharger (long)
    By DMD///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-06-2001, 12:28 AM
