Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
Thread: Blown M52b28?
  1. #26
    Feb 2010
    Texas
    01 530i
    SG & 328, from what I’ve read and researched the subframes are the same on all e39’s. You would have to swap output shafts though. Check out Stück’s e39 thread, good stuff in there.
    My plan for my turbo e39 is either m5 diff or 540i diff with wavetrac or quaife.
  2. #27
    Virginia
    97' m52 turbo
    I'm not really concerned about the diff or making huge power out of a 5 series.
    But it would be nice to make it a bit more quick. Maybe in the 300-400 HP range. Probably low 3's
    at this point I'm going to try to source a used m52b28 or plan on pulling the head
  3. #28
    Mar 2016
    Australia
    e30 318i, 135i
    unhook the PCV drain from the dipstick and plug both ends. Its common for the PCV valve to fail and start sucking oil up from the dipstick. I had this exact issue and after doing this, and running the car about 30mins, all the smoke was gone.
    quick and easy to test
  4. #29
    Frederick, MD
    '87 e30, '02 e39 Dinan
    Quote Originally Posted by 328iFun View Post
    I agree with this, my best solution was a 50 shot of nitrous.
    Capital Driving Club Car # 102
    How to turbo your car:
    Step one. Install ecu and learn to tune and or have it tuned.
    Step two. Install injectors and retune.
    Step three. Install turbo parts and bits. get it running with out leaks. DO NOT DRIVE IT. Idling should be ok
    Step four. Retune car
    Step five enjoy
  5. #30
    Mar 2016
    Australia
    e30 318i, 135i
  6. #31
    Virginia
    97' m52 turbo
    Quote Originally Posted by ba114 View Post
    Thanks for the upload.
    Did the car feel sluggish as well?
    Reason I ask is because I drove the car on the road and it felt it like it was running on 5 cylinders (it wasn't missing) but it just didn't have the 90's I6 grunt that I'm used too. But this very could oil on the plugs preventing spark
    Been awhile since I've played with the car trying to get my E36 squared away. I really wanna take it to the track.
  7. #32
    Mar 2016
    Australia
    e30 318i, 135i
    i couldnt tell you if it was sluggish. I only moved it in and out of the garage. With all that oil though im sure it would have been missing all over the place.
  8. #33
    Virginia
    97' m52 turbo
    Pulled the ICV tube yesterday and let it run for a good 30 minutes. Still smoke, revved the engine and it started missing horribly. Guessing another plug has been fouled
  9. #34
    Mar 2016
    Australia
    e30 318i, 135i
    I don't understand why you pulled the ICV? Idle Air Control Valve (IACV)?
    If you mean you pulled the PCV drain and plugged both sides, then you've probably eliminated a failed pcv from the equation as 30 minutes and you should have seen a reduction in smoke.
  10. #35
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Big problem with E39 is no easy way to get an LSD in there
    Easy or not depends on your definition, but definitely cheap to put a NSD (non-slip differential) in there!
  11. #36
    Virginia
    97' m52 turbo
    Yes, meant PCV.
    Car started missing after 30 minutes, ran worse.
    If I can source a motor for a reasonable price I'll swap it in.
    Pretty set on piston damage
  1. m52b28 with blown head gasket
    By sacbmwdriver in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-12-2009, 11:52 PM
  2. Blown, you need to see this and EVERY1 Else!!!!!
    By outkastaliens in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-01-2001, 08:45 PM
  3. Kevlar, Re: Blown's Autometer Tach
    By TurboBMW3 in forum 1991 - 1999 (E36)
    Last Post: 03-01-2001, 12:28 AM
  4. Welcome back BLOWN, how's the car?
    By ///MCubed in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-28-2001, 03:22 PM
  5. ATTN: Blown or anyone who knows how to contact him!
    By Joey325i in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-27-2001, 01:40 AM
