Page 67 of 70 FirstFirst ... 17425758596061626364656667686970 LastLast
Results 1,651 to 1,675 of 1742
Thread: 2017 what did you do to your e38 today?
  1. #1651
    Jun 2013
    Toronto, Ontario
    '95 740i
    You need to get that rocker fixed before it fills up with too much crap!
    || 1995 740i || M60B40 || DUDMD || ̶o̶r̶i̶e̶n̶t̶ ̶b̶l̶u̶e̶ Mercedes Brilliant Blue Metallic || Style 168 Wheels 1" Spacers ||
  2. #1652
    Aug 2015
    Oconomowoc, Wisconsin
    01 750il, E38/9 Parts
    Quote Originally Posted by Jamos View Post
    Will do, it's on a very long to-do list
    Sent from my Nexus 6P using Tapatalk
    --- 750il Maintenance/Restoration Thread --- E38/9 Parts Cars --- YouTube Channel ---
  3. #1653
    honolulu
    2000 740i sport
    Well it wasn’t today - but Friday I installed poly bushings on my front suspension. For those who’ve said in the past that a lowered e38 rides like a truck after swapping the rubber for the poly I can only respond with - i’m 10-20 good buddy - i’m Gone ...
  4. #1654
    Aug 2015
    This car is starting to actually look good
  5. #1655
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Quote Originally Posted by ColtonBH View Post
    Looks great! What did you end up doing for wheels? Hard to tell from the angle. Mpars?
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
  6. #1656
    Aug 2015
    Quote Originally Posted by clarkitect View Post
    Thanks! Still not a great angle, but they're Breyton Flames off of my old e39, they need to be refinished but don't look terrible from a distance, much better than stockers
  7. #1657
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    It looked way better with original turn lights
    Instagram.com/nordmanmg
    Your current situation is not your final destination
  8. #1658
    Aug 2015
    Quote Originally Posted by NordmanMg View Post
    Well, considering the lens fell off one side of the stock set shortly after I got home that's not an option. I don't like the orange, I would've preferred a lighter tinted clear set, but a member had this set for sale very reasonable so I went with these. I still like these better than orange
  9. #1659
    Aug 2015
    Stockton, Calif.
    1999 740Il,1999 Corvette
    My windshield washers have never worked since purchase so I decided today to find out why. I could hear the pump working so I pulled the cowl vent off and disconnected the hoses to the spray nozzles. No water from the hoses? I had gotten a pump from a wreck weeks earlier so I swapped it out. Now I had water to the nozzles but the plastic hose to the right one was cracked.I ended up cutting off about 5 inches of plastic hose and slipped on vacuum hose. Now they work! Tomorrow I will insert a sewing needle into the nozzles to align them better to the windshield. The nozzles pivot like an eye socket so I can align them evenly left to right.
  10. #1660
    Mar 2013
    Sonora, ca
    2001 740il
    Quote Originally Posted by luauboy View Post
    Where did you get the bushing from?
  11. #1661
    Mar 2013
    Sonora, ca
    2001 740il
    Quote Originally Posted by carnut1947 View Post
    Black 1/4 in. Plastic hose that’s available at any hardware store works perfect to replace the plastic lines did my entire hood with it couple of years ago and no issues looks stock also
  12. #1662
    Aug 2013
    Finland
    1999 540i M-sport
    Seven went to sleep yesterday. Just on time!
    Ahead is 24hours of non-stop snowing.
    But now I can park E39 again on two spots
    Отправлено с моего SM-G935F через Tapatalk
    -E34 M60B40 + Tremec TKO 600 (sold)
    and sadly no old BMW anymore, only high powered Seat Leon Cupra 4Drive as a daily driver.
  13. #1663
    Oct 2003
    New Jersey
    E36 M3 / 991.2 911
    Got all my 750il parts in for a brake swap in a few weeks.
  14. #1664
    IL
    2000 740i sport
    Quote Originally Posted by jaysonx View Post
    Do you need the caliper brackets too? What brand of rotors?
    Sent from my SM-N910T3 using Tapatalk
  15. #1665
    Oct 2003
    New Jersey
    E36 M3 / 991.2 911
    Quote Originally Posted by purplecty View Post
    They came with both front and rear brackets. I went with the duralast rotors since I got 20% off and free shipping. Painted the hubs myself with high temp paint.
  16. #1666
    IL
    2000 740i sport
    I was about to say the corrosion protection looked great. Where did you get the calipers?
  17. #1667
    Oct 2003
    New Jersey
    E36 M3 / 991.2 911
    Thanks! Autozone for the fronts, rock auto for the rears. Purchased online.
    I shopped a lot of places, inventory seems to be really low on them.
  18. #1668
    IL
    2000 740i sport
    How much did you pay for the pkg?
  19. #1669
    Franklin, Va
    01 750 Sport "Angel"
    I don’t see the brackets in your picture that purple is talking about. Are you sure you got them? He is talking about the brackets that the calipers mount to that usually stay with the car.
  20. #1670
    Aug 2015
    Put my T-stat on, now I don't have to drive in high gears to keep the car from underheating
  21. #1671
    Oct 2003
    New Jersey
    E36 M3 / 991.2 911
    Quote Originally Posted by Chief Jimbo View Post
    They are fully assembled in the pic. Here is the caliper and bracket.
  22. #1672
    Feb 2009
    Pikesville, MD
    '01 740i Sport, '13 Volt
    Finally got the new rear inner wheel well liners in. Those things are stiff in the cold and hard to get shoved all the way up in there at the lip of the flare. But a huge difference... the old ones had gotten quite brittle and just pulled out in tiny pieces.
  23. #1673
    Apr 2017
    Hampton va
    95 740i, 89 735i,
    Quote Originally Posted by Chris V View Post
    Think that's my next move, all 4
  24. #1674
    Mar 2013
    Sonora, ca
    2001 740il
    6.5 hour drive to Las Vegas for me today, last trip with the 4.4 last time I do this with a speed limiter.
  25. #1675
    NYC
    99 IL/13 SXT/04 Audi A4
    Bought a MK4 on eBay for $130 dollars score
    El Cid 1999 IL
    DUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
  1. 2016 what did you do to your e38 today?
    By 1badturboe38 in forum 1995 - 2001 (E38)
    Last Post: 01-01-2017, 07:03 PM
  2. 2015 What did you do to your E38 today?
    By Mayorchuck in forum 1995 - 2001 (E38)
    Last Post: 01-06-2016, 03:36 PM
  3. 2014 What did you do to your E38 today?
    Last Post: 01-01-2015, 03:13 PM
  4. What did you do to your E38 today???
    By kooljess in forum 1995 - 2001 (E38)
    Last Post: 01-30-2014, 12:28 AM
  5. What did you do to your E36 today?
    By Eurodriver in forum 1991 - 1999 (E36)
    Last Post: 01-09-2008, 08:54 PM
