Results 1 to 18 of 18
Thread: E36 Axle Compatibility
    Jan 2015
    NYC
    1994 325is
    I've been searching for a long time about this and I can't find a definite answer. I have also looked on real oem for part numbers but everything is different. I'm wondering what non-m e36 axles are compatible with each other? So would 318 axles fit in a 325? And would 318ti axles fit in a 325?
    I know 325 and 328 axles differ in diameter but are a direct swap. And that m3 axles won't swap unless you change your diff output flanges. But besides that I'm lost. Any help would be appreciated.
    Apr 2013
    Kelowna, Bc, canada
    1995 BMW M3 coupe
    318, 325, and 328 all share the hub side spline, but the flanges on the diff are different. 325 and 328 are the same, 318 is much smaller. So if you're putting a medium case diff in your car, you'll need 325 or 328 axles. Driveshaft bolt patten is the same for all non m cars aswell (4 bolt flange)
    Jan 2015
    NYC
    1994 325is
    Thank you for the fast reply
    Dec 2019
    US
    1997 328i
    Will 96 m3 axles fit into a 97 328i diff and hub?
    fairfax,va, usa
    2 E30s and a maxima
    No.
    Aug 2008
    Lakeland Florida
    1999 328ic , 2002 325xi
    E36 M3 Axles have bigger CV joints and don't clear non-M trailing arms. They also use a bigger pattern diff side stub axle so you need those to bolt the axles up to the diff.
    Dec 2019
    US
    1997 328i
    So if i put after market trailing arms on with the diff to the m3 i should be good?
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    who makes aftermarket trailing arms? or do you mean like URO or something
    instagram @andyitslit
    Dec 2019
    US
    1997 328i
    I belive SPC makes one for a true coilover setup in the rear as well as wisefab and revshift. Dont quote me i could be misinformed.
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    I don't think SPC has one. Wisefab's looks to be for rally. anyway we don't know depends on clearance
    Dec 2019
    US
    1997 328i
    Thanks for the help ill keep you updated on my progress.
    Nov 2020
    Naperville,il
    318ti
    Quote Originally Posted by Mikestokman View Post
    So then would you put the e36 325i axles or e30? I have a 96 318ti with a 3.73 lsd but I’m not sure what axles to get and what to make sure the hub side splines are the same
    Aug 2011
    Los Angeles
    my brother's ti
    Quote Originally Posted by Erock890 View Post
    3.73lsd from an e30 in your ti? medium case right? then you need 6 cyl e30 axles
    fairfax,va, usa
    2 E30s and a maxima
    318ti axles are specific to the E36 318. E30 axles are too short.
    Feb 2025
    Manteca,CA
    1992 BMW 325i E36 sedan
    Will 91 325 take 96 328is axles?
    Regina, Sask, Canada
    82 320i 89 325i
    Quote Originally Posted by E36maark View Post
    check the part numbers in realoem to be certain.
    Aug 2011
    Los Angeles
    my brother's ti
    yes they should bolt on. real oem may show you the specs of the hubs but may not tell you if the part numbers are interchangeable. im assuming its a 91 e36
    Feb 2025
    Manteca,CA
    Quote Originally Posted by E36M3LX View Post
    Thank you! I know 328is axles are comparable to m3 axles stronger and better than stock 325i axles to run for high power applications I just didn't know if they would bolt on or not. Now I know!
  1. E36 Fs: E36 axles, pair $70 shipped obo
    By sweet e36 pimp in forum Drivetrain & Transmission Parts
    Last Post: 03-26-2010, 12:31 PM
  2. E36 Axles, $225 Shipped.
    By schwarzIIe36 in forum BMW Parts For Sale
    Last Post: 04-11-2005, 07:14 PM
  3. Rear e36 axles for sale
    By mrbobolina in forum BMW Parts For Sale
    Last Post: 12-22-2004, 03:24 PM
  4. E36 OBC Compatibility (basic vs.deluxe computer)
    By cybertoyz in forum 1991 - 1999 (E36)
    Last Post: 11-30-2003, 09:55 PM
  5. will a CD changer from an older e36 be compatible?
    By Lynch in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-20-2002, 11:06 PM
