Results 1 to 13 of 13
Thread: BMW E31 Part Numbers: The hard to find, odd and downright handy..
    Aug 2008
    Earth
    8/88 750iL
    This could be a good thread.
    850CSi euro calipers:
    fr: 34112227116
    fl: 34112227115
    rr: 34212227510
    rl: 34212227509
    850CSi euro rotors:
    Rear: 34216767062 (shared with E38 740/750)
    Front, r: 34112227736 (also E34M5 3.8)
    Front, l: 34112227735 (also E34M5 3.8)
    1989 BMW 750iL (prod 08/88) (vin: 2768675)
    Gone but not forgotten: 1994 BMW 740iL (prod 10/11/1993) (vin: *DE89667) 6spd swap, 2001 BMW 740i Sport
    Oct 2002
    Cold Snowy North
    Misc.
    850CSi rear rotors are NOT shared with the 740. Only the 750iL. They were used on some 740 Protection cars, but the vast majority (>99%) use a different disk.
    Mark850's Avatar
    Mark850 is offline Life begins at 145mph.... Moderator
    Nov 2007
    Philadelphia,Pa.
    91 850i/'67 Nova SS
    Post all part numbers for available parts here. PART NUMBERS W/ DESCRIPTION ONLY! All other non part number posts will be deleted..
    Example---> Headlight Housings:
    01 Housing L 1 06/1992 63128354543
    01 Housing R 1 06/1992 63128354544
    It is good but i think the Advanced reply should be used instead of quick post, This way we can take advantage of the "Title description" on top of the post, The name of the part numbers being described could be listed there like The example above!
    Thanks to Omar for the GREAT IDEA.....
    1991 850i,80k miles,Wokke2000 Software,M3 Style Trunk Lip Spoiler,35% Tint,Zimmerman Cross Drilled Rotors,Limiters Disabled,1.5 inch Drop,AC Schnitzer Lower Front Spoiler,Mark850 design Roof Spoiler,HRE Comp90 Wheels 19x11.5 & 19x9.5, 295/30/19 245/35/19, Dinan Stage 2 Adjustable Sway Bars.
    South Jersey
    '92 850i/6-Euro Wannabe
    REAR SPRINGS:
    Mtechnic: 33 531 1 138 738
    Mtechnic with trailer hitch option (stiffer): 33 531 1 138 739
    Nov 2009
    Yadkinville, NC
    1994-850ci/325i 2006-X3
    Staggered M-Parallel wheels:
    18 x 8 inch front 36-11-2-227-631
    18 x 9.5 inch rear 36-11-2-229-730 (new number)
    Aug 2008
    Earth
    8/88 750iL
    Ick, M-pars. It's all about M System II's
    8JX17 ET:10 - 36112227438
    9JX17 ET:19 - 36112227439
    Arlington, Virginia
    E31, E38, E39
    Battery Harness Protector Cap
    61 13 1 383 905
    Lighting modules wire harness protector caps (they are slightly different in size, BMW never makes anything easy.)
    61-13-1-383-901
    61-13-1-383-903
    South Jersey
    CSI REAR SPRINGS
    33 53 2 227 719
    CSI SWAY BARS
    Front -
    31 35 2 227 364
    rubber bushings (2)
    31 35 2 227 365
    Support brackets (2)
    31 35 1 131 622
    Rear -
    33 55 2 227 321
    rubber bushings (2)
    33 55 2 227 322
    33 55 1 129 195
    EURO ROTOR DUST SHIELDS
    Front -
    34 11 1 159 917 -left
    34 11 1 159 918 -right
    Rear -
    34 21 1 157 937 -left
    34 21 1 161 482 -right
    EARLY 6spd MANUAL TRANSMISSION EML (Not CSI)
    12 71 1 729 746
    City Of Angels
    911 + E31
    VCV valve aka 'Volume Control Valve' for V12 M70:
    Cylinder 1-6 ----> 11-15-1-718-713
    Cylinder 7-12 ---> 11-15-1-718-642
    While replacing, one should also replace all the hoses associated with the VCV:
    Valve cr grommet - 11-15-1-715-844
    VCV valve hoses - 11-15-1-720-390
    VCV valve hoses - 11-15-1-720-391
    VCV valve hoses - 11-15-1-720-392
    VCV valve hoses - 11-15-1-720-393
    South Jersey
    E31 Upper Control Arm bushes Upgrade from E34 M5
    31 12 2 226 528
    Jan 2005
    Japan
    11/88 E32 750iL
    Listed NOT under E32 and E31! But the M70 engine needs it
    http://www.bilder-speicher.de/080116...ting-page.html
    2 x 12521737668 MAF connector old number was 1718126 PLUG HOUSING 7-POL
    usually the inner ring breaks
    http://www.bimmerboard.com/members/mino/RIMG0128.JPG
    16 PLUG HOUSING 7-POL 1 12521737668 $13.28
    Part Cross-reference, Part 12521737668 (PLUG HOUSING) was found on the following vehicles:
    E30 324d SEDAN, Euro,E30 324td SEDAN, Euro,E30 324td TOURING, Euro,E30 316i COUPE, Euro, E30 316i TOURING, Euro,E30 316i SEDAN, Euro
    E30 318i SEDAN, Euro, E30 318i COUPE, Euro, E30 318i TOURING, Euro,E30 318i CONVERTIBLE, Euro, E30 320i TOURING, Euro,E30 325i TOURING, Euro
    E30 325ix TOURING, Euro
    E34 525i SEDAN, U.S., E34 524td SEDAN, Euro, E34 518i SEDAN, Euro, E34 520i SEDAN, Euro, E34 525i SEDAN, Euro, E34 525td TOURING, Euro
    E34 525td SEDAN, Euro, E34 525tds TOURING, Euro, E34 525tds SEDAN, Euro
    E36 316i SEDAN, Euro, E36 318i SEDAN, Euro. E36 325td SEDAN, Euro, E36 325tds SEDAN, Euro
    Z1: Details on Z1 Z1 Z1 ROADSTER, Euro
    M70 850, maybe also others: oil pipes automatic transmission to transmission cooler:
    Bracket Oil Pipe 17201712210 Only with automatic transmission
    Hex Bolt 07119913575 M6X30 Only with automatic transmission
    Spacer 17227798686 D6 Only with automatic transmission
    Hex nut with plate 07129946302 BM6 Only with automatic transmission
    correct: as shown here for the E36 http://bmwfans.info/parts/catalog/E3...l_air_cooling/
    NOT the one shown here as number 13 in the pic for the E31 850, that is wrong!
    http://bmwfans.info/parts/catalog/E3...n_oil_cooling/
    Memphis, TN
    1995 BMW 840
    Picture of M3 Style Trunk Lip
    Mark850,
    Do you have a picture of the rear of your car showing the Trunk Lip Spoiler?
    bimmerman44
    Quote Originally Posted by Mark850 View Post
    Jan 2005
    Japan
    11/88 E32 750iL
    old number was 1718126. Latest part number is 12521737668, Listed NOT for E32 and E31!!!!16 PLUG HOUSING 7-POL 1 12521737668
    E30: 324d, 324td, 316i, 318i, 320i, 325i, 325ix
    E34: 525i, 524td, 518i, 520i, 525i, 525td, 525tds
    E36: 316i, 318i, 325td, 325tds
    Z1: Z1 ROADSTER, Euro
    picture http://www.bilder-speicher.de/show.p...08011611783169
    Special thanks to my parts specialist of my dealer in Germany, he extra ordered 1 plug for me from Munich and sent me the pics. Part number of the plug which goes onto the EML throttling valve is position 21 8 POL. 12521714053.
    A bit confusing as there are engines mentioned which do not have a EML DK, E31 is not mentioned at all, but look at the pics. http://www.realoem.com/bmw/showparts...12&fg=31&hl=31
    Here the pics
    http://s71.photobucket.com/user/shog...ml?sort=4&o=16
    http://s71.photobucket.com/user/shog...ml?sort=4&o=17
