Results 1 to 15 of 15
Thread: turbo compressor housing is leaking boost
    buffalo ny
    328is, civic
    well, i finally got around to doing a boost leak test on my car since i noticed some an oily residue around my turbos compressor bolts. well, after about 10-15psi the turbo compressor where it bolts/clocks to the turbos center section is leaking boost like crazy.
    Now i remember hearing that there is a sealer you can put on the turbo to seal it up where the compressor housing meets the turbo. anyone else ever have this problem? i wanna head back to the dyno and push this turbos limits but not with massive boost leaks like this.
    1005whp/831wtq little bit of low boost pump gas magic...
    Dec 2008
    Earth
    none
    I'd unbolt it clean it up and put it back together and make sure thoes bolts are tight, they may have loosened up over time. As far as sealer, i've never herd of anything...
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    Many compressors are supposed to have an o-ring seal there, and for some reason don't.
    If nothing else, just use some Import Grey RTV(very sparingly) to seal it up.
    Aug 2003
    Asheville NC
    2013 x1, 99 cherokee
    with the way my turbo is clocked one of the bolts is right on the oil return fitting so i was forced to leave it out.
    I'm going to be pressure testing the system this weekend, and i hope it does not leak, because if it does, i'm not sure what option i have...
    Luke
    03 330i
    buffalo ny
    328is, civic
    bolts are all tight. Its a precision sc61 and there is no o-ring that i know of. Im just gunna clean it up and apply a very small layer of high temp copper rtv. its amazing how much air leaks outta this thing going from 10psi to 20psi. id say this is a major boost leak. Now my ebc has a slight leak as well, maybe some super glue on the nipple or something will help that. back to the dyno this weekend hopefully for some new numbers.
    Def's Avatar
    Aug 2002
    SW22, Volt
    Superglue doesn't fill in cracks well. Clean the surfaces well and a little JB weld will fix up a boost leak.
    buffalo ny
    328is, civic
    Quote Originally Posted by Def View Post
    its not realy a crack per say. its where the vacuum nipple sticks out from the ebc. its not a huge leak, so i may not realy worry about it. The turbo is now sealed up and no longer leaking however we will have to see after a few heat cycles.
    Apr 2025
    Kenya
    Bmw 535i
    Turbo not building boost even at 6900 rpm
    I am having similar issue on my psr 6866A topmount turbo and psr external 45mmm wstegate controlled by a 3port mac wired to my reflex plus module. i cannot build boost above 10psi even at 80% WGDC and i remember one compressor bolt could not be tightened fully due the turbo oil return line at the bottom all other bolts are tightened where could the issue be?... All intercooler piping has been checked waiting for a boost leak check... Please share some troubleshooting tips
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Did it make more than 10psi before? Have you tried bypassing the MAC valve? Is the MAC valve hooked up correctly? Are you certain? Is your Reflex Plus wired correctly? Are you certain? Is your inlet cheap silicone hose that is collapsing under the suction?
    Jan 2021
    Ny
    94e36, 00e39 532it turbo
    Sounds like your missing the fire ring on your external Wastegate.
    Jun 2005
    New England
    That would be easy to test
    Mar 2003
    Hell Hole, NC
    325i
    Also check your overboost settings.
    Apr 2025
    Kenya
    Bmw 535i
    Quote Originally Posted by Sio2crew View Post
    My mechanic insists he installed it but it looks like I might have to to take the manifold apart since its installed in a tight location
    The turbo inlet is open, no hoses. How to bypass the mac valve? Yes we rechecked the reflex wiring to the mac controller and it is fine
    https://datazap.me/u/ctheuri/topmoun...39-40-41-42-43
    Jun 2005
    New England
    Did it ever work properly? Is this a problem that occurred on an otherwise working car or is this a turbo install that is not working as hoped?
    Apr 2025
    Kenya
    Bmw 535i
    well this is pronlem with trusting some mechanics...found the external wastegate valve seat missing and the smoke test revealed a leak on the lpfp pressure sensor connection on the intake manifold
    u were right found missing
