Yes...I am going to build an E46 track/daily car....I love the wagon! Basically I am selling ALL my other cars and assorted car toys, aka parts pieces from all the previous car projects... Since I am going to errrr have the wagon as my car in a few months Wife gets a "red and tan interior" 325i....
Project:
Rear E46M3 subframe/diff/brakes whole meal deal (bought, on way)
BBK...Have..Alcon UUC front kit, upgrade rear to Alcon later
M54B30 motor, with a Six speed...looking for ZHP combo...
AST Shocks/Springs, with E46M3 aftermarket sway bars...
Subframe reinforcement kit for the rear...
assorted E46M3 body parts, Bumper, mirrors etc...M tech rear bumper..
More than likey it will be a longer term project but I remeber the posting a few months back about making a E46 Touring track/daily driver...
I would like to turbocharge it later on.
ANy thoughts?
Gary Gray
If you can take it apart you can make it faster!
Yeah i though about an S54...Maybe have to see..an M54B30 is pretty dam cheap though! Try 2500 bucks complete ready to drop in....I can turbo the M54B30 and make a reliable 400at the crank pop a motor no big deal buy a new one and swap it
8500rpm redline would be cool though...
This is scary...I actually kinda like the steptronic in it....Its nice to smack into D and just bumble down the road Scary...
Gary Gray
S54 touring done by Rogue:
I've seen it in person twice, it's awesome!
M2CS 6-spd
Cool project! How do you compare the potential of the E46 vs the E36? I have read that the unibody of the E46 is stiffer, but the car weighs more. How is the suspension geometry for lowering? I have heard the E36 has problems as it is lowered, but haven't heard that on the E46. My current E36 M3 has more performance than my ZHP (acceleration and cornering), but I liked the ZHP better.
The E36 and E46 essentially share the same suspension design. For the most part, the same weaknesses and same pluses. The E46 has a slightly better starting point (wider track, etc), but there's not a huge difference.
The E46 is definitely heavier in street car form...in race car form, I'm not sure there's as big of a difference.
The E46 Wagon is actually lighter than the E46M3
The wider track makes a huge diffrence...Not to mention you can stick WAY more rubber under the E46.
And a wagon on track passing Porsches....How cool would that be
Gary Gray
I miss my wagon.... *sigh*
-jeff conner
dreaming of an ///M3 Wagon........
I give you the gratuitous wheel lift shot, with some lovely flowers as a backdrop...
I just bought Groner's wagon that he built for his son. It's been on the track a few times. UUC BBK, Biltein PSS9 coilovers, etc. It's my wife's daily now but I really enjoy driving it. Wouldn't mind getting it out for a track day just for fun.
Before
Now
And her old e34 wagon with me doing a hotlap at TWS
1988 M3 Track Rat - 1989 325iC M50 Vert - 1993 525i supercharged 5-speed touring - 2006 330i
There are a couple of 335i twin-turbo motors (N54?) out there (at least one on eBay for $15k buy it now with transmission). That would be pretty cool and you'd have 350hp available immediately! Its probably lighter than the S54, too, since its all alloy block (aluminum/magnesium). Just put a BIG oil cooler on it!
-Anthony Magagnoli
#80 BMW M235i Racing - Pirelli World Challenge TC - 2017 Rookie of the Year
Rooster Hall Racing / FCP Euro
'87 BMW SpecE30 #007 - 2012 NASA SpecE30 NATIONAL CHAMPION
'08 BMW "130i" 6MT, '01 Z3 3.0i Coupe 5MT
'88 Pontiac Fiero GT 5MT (my childhood dream car!)
Send Your Teens to Street Survival
Drive Faster Now
How is this project progressing? I am also considering an eventual engine/trans upgrade for my sport wagon.
I would like to sort out what I am going to use for a differential and disassemble the rear end one time. Remove the OEM sub-frame, install the reinforcing kit, install M3 rear sub-frame and install a LSD.
I have a Quaife installed in my turbo 2002 and am leaning towards keeping the original 3.46 gear set but install a Quaife insert. If I add the 6-speed it should be a nice setup since the non-M motors do not rev quite as high.
Going slow. I am in the process of selling "stuff" but I have put the alcon brakes on the front and some 18inch wheels. Also have some shocks/springs i am looking into made by D2 racing. You can lower the car and not loose travel.
Sway bars probably in a month.
I've looked into swapping a complete E46M3 rear into the car to get the LSD and shorter gear set.
Probably do the M54B30 swap in the winter, with a six speed.
Gary Gray
yes,
height and preload, and single adjustable rebound and compression with one knob, they make front double adjustable units now for E36/E46. 60mm springs.
I'm going to try a set they look nice. I have read mixed reviews on them.
Gary Gray
Basically you get the ability to run the car low and retain the shock travel so you don't go around bouncing on the bump stops or bottoming the shock out. Such as when you run a standard coil over set up with the threaded body of the shock doing double duty, lowering and ride height.
With the shock body movable in the lower mount you can adjust the ride hieght with the lower section to what you want, low etc. And you don't loose any travel since you are not using the spring height to lower the car.
I think its far more important for a street car since most race cars really don't need 5-6inches of travel.
That's my take on it. i know in the Miata world mazda designed the bump stops to act as part of the suspension they have very little travel when lowered especially the 89-97 cars. Rough roads make them bonce all over the dam place.
Gary Gray
The M54B30 is horrendously unreliable on track for what it's worth. You'll very much need to find a used TCK oil pump.
2011 M3 Sedan
2006 GMC Sierra 2500HD LBZ
1999 323i GTS2
1995 M3 - S50B32/S6S420G/3.91
1990 325is
1989 M3 - S54B32/GS6-37BZ
Hers: 1996 Porsche 911 Turbo
Hers: 1989 325iX
I have a source for new pumps modified similar(3 bolts in a triangle then one in the middle) to the TCK ones(which aren't made anymore), they're $800 though. If anyone's interested PM me...
I wouldn't say it's "horrendously unreliable on track", I've yet to have any problems with it that made me miss track time. I did have the 3 oil squirters that failed, otherwise it's just been small sensors occasionally going out.
i plan to go through it and fix a few things, like the oil pump problem. A guy on E46 fanatics is building a full bore race M54B30. I'm not looking for ultra high rpm out of it. End goal is turbocharged. Probably won't rev it past 6800rpm.
It will probably only see the track 2-4 times per year. if gas prices keep heading north I may skip the turbo and just be happy with it NA
Every BMW motor I have ever tracked has some kind of "issue" M10/M20/M30 family break rocker arms which sucks since the head has to come off to repair it, S14's spin bearings, kill cam trays, blew up two, early S50's valve retainer problems, S52 oil nuts fall off...
if it was a race car I might go overkill on the rebuild but its not a full bore race motor.
Are you tracking the IX ? If so how does it do?
Gary Gray
Way back when, I tracked the xi once. It was a hoot, but getting point bys was a huge pain in the ass. Loaded (m3+instructor) it was 4200+lbs. and so it was challenging to convince folks in M cars that it was faster than them.
Unfortunately, I sold it when I bought the '04 M3. Should never have bought that car and I should've kept the xi. Oh well.
2011 M3 Sedan
1999 323i GTS2
1990 325is
Hers: 1989 325iX
