i have the tool you may borrow it with a deposit + spicy chicken sandwich
Great! Sent PM.
anyone have a BMW balljoint removal tool for an e39?
EDIT: Member "kbsilver" rents this tool for 25$ ($100 deposit required). The tool comes complete with other tools necessary to complete the balljoint replacement on an E39.
This bad boy:
I've got a water pump pulley tool, 32/36mm wrench and compression tester to loan.
PM me for info on properly working AC and CEL for your S54 or M54 swapped car.
Air bag reset tool!!! need one next month
seriously need an airbag reset tool
If anyone has an impact/air tools/super human strength, I have a set of Vorshlag camber plates waiting to go in.
If I could borrow or if anyone wants to assist in the install, it would be much appreciated.
anyone got a 3/8 torque wrench
Need RTAB tool for e36, thanks.
Just keeping it reliable and looking decent.
I have the full set of sirs tools for rear subframe bushing removal\installation.
this will work on e30, e24, e28, e32 and z3.
may work on other models as well.
Tony
85 635CSI Euro
89 325IS
98 M3 (sold)
87 535is (sold)
01 m coupe (sold)
Hey Guys, I'm looking to do the Single vanos seal & O-ring fix...
I'm looking to rent/borrow the tools needed:
I'm going to try to do the job the week after Petit Lemans, so if anyone has these I could meet you at the race
- CAMSHAFT LOCKING FIXTURE
- TOP DEAD CENTER PIN
- VANOS TURNING WRENCH
- CHAIN TENSIONER LOCK PIN
Thanks for your time.
98 318ti - SOLD
93 325is - Daily Driver
Hello, I'm looking to borrow someones SRS reset tool for my 98 M3. I'll gladly send you a shipping label, deposit and then return the tool to you when I'm done. I'm local (up in Cumming) and I can pick up (or just use real quick) if close where I can run out on lunch. If you have one that I can borrow, please pm me or email me at jcardin at automationdirect dot com.
SOLD - 1998 M3 - Whiteline FSB, Koni Struts, Eibach Prokit, Swapped Tophats, Poly RTAB, 17x9 X 4, Sparco strut bar
1996 LS400 - Stock
That rocks. Thanks. I looked through some of your old posts but couldn't find out where your shop is in Atlanta.
1996 LS400 - Stock
I am new this forum. I am performing a head gasket job on 1997 BMW 328i. I am in need of a T60 head bolt socket to remove head bolts. Does anyone have this?
Thanks,
Patrick
678-376-6110
millerfleet2@aol.com
Can anyone code?
like key fob windows up, auto lock doors, etc?
Anybody have the locking collar tool for Bilstein strut inserts?
It would be great if I could find one of these up the GA400 corridor, but I'll take what I can get.
Anyone have a timing belt roller for an e30?
'84 318i
'99 M3 'vert(wifey's)
'88 535i
'05 ZHP
'05 X3 6-sp sport pkg unicorn
Need a 32 mm open end wrench. It needs to be skinny/a bicycle wrench because its needed to get my radiator fan nut off. Thanks.
what type of car and where are you located?
87 e30. Kennesaw
And if anyone has one, feel free to call/text me at 770-634-2308
